Openhab on raspberry: owfs connection issue
I’m trying to spin up openhab app on the raspberry 2, and have some troubles reaching port 4304 for connecting to owfs server with my 1-wire devices on it.
Here is what I’m getting from telnet
[quote]pi@raspberrypi:~ $ telnet 127.0.0.1 4304
Trying 127.0.0.1…
telnet: Unable to connect to remote host: Connection refused
[/quote]
Here is my config file
[quote]pi@raspberrypi:~ $ cat /etc/owfs.conf
! server: server = 127.0.0.1:4304
######################### OWFS ##########################
mountpoint = /mnt/1wire
allow_other
####################### OWHTTPD #########################
http: port = 2121
####################### OWFTPD ##########################
ftp: port = 2120
####################### OWSERVER ########################
server: port = 127.0.0.1:4304
[/quote]
Here is openhab starting output
[quote]pi@raspberrypi:/opt/openhab $ sudo ./start.sh
Launching the openHAB runtime…
osgi> 2016-05-30 14:28:13.177 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.1).
2016-05-30 14:28:41.345 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-05-30 14:28:43.079 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2016-05-30 14:28:47.651 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘db4o.persist’
2016-05-30 14:28:53.265 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘exec.persist’
2016-05-30 14:28:53.425 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘logging.persist’
2016-05-30 14:28:53.746 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘rrd4j.persist’
2016-05-30 14:28:54.636 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘demo.items’
2016-05-30 14:29:18.871 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘demo.sitemap’
2016-05-30 14:29:26.595 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model ‘demo.script’
2016-05-30 14:29:49.421 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2016-05-30 14:29:55.708 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /classicui/openhab.app
2016-05-30 14:30:05.548 [INFO ] [.service.AbstractActiveService] - NTP Refresh Service has been started
2016-05-30 14:30:06.656 [INFO ] [.p.rrd4j.internal.RRD4jService] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = 0 items(s) =
2016-05-30 14:30:07.492 [ERROR] [o.o.b.o.i.c.OneWireConnection ] - Couldn’t connect to owserver [IP ‘127.0.0.1’ Port ‘4304’]:
2016-05-30 14:30:07.524 [WARN ] [o.o.b.o.i.c.OneWireConnection ] - Inital connection to owserver failed![/quote]
And this is how I start owfs
[quote]sudo /opt/owfs/bin/owfs -c /etc/owfs.conf --i2c=ALL:ALL --allow_other /mnt/1wire
sudo /opt/owfs/bin/owhttpd -c /etc/owfs.conf --i2c=ALL:ALL --allow_other /mnt/1wire
sudo /opt/owfs/bin/owserver -c /etc/owfs.conf–i2c=ALL:ALL --allow_other /mnt/1wire[/quote]
However, port 2121 (used for owhttpd) works pretty well, so I’m able to see my devices through the browser.
Please advise. Thanks!
Case closed, there was syntax error in owserver start command, correct one is here
sudo /opt/owfs/bin/owserver -c /etc/owfs.conf --i2c=ALL:ALL --allow_other /mnt/1wire
Thanks.
