Hi everyone! it’s exciting being part of this community. I have recently started playing with Openhab on a Tinkerforge RedBrick (default setup). As a first experiment I wanted to stream some live temperature data on a Influx database I have setup on a remote sever.
It all looks great if it wasn’t that I cannot read the temperature data on the database. When I query the DB I can only see the items names but not the actual value.
This is the openhab settings I am using:
Influx binding:
org.openhab.persistence.influxdb-1.9.0-SNAPSHOT.jar
openhab.config
folder:items=10,items
folder:sitemaps=10,sitemap
folder:rules=10,rules
folder:scripts=10,script
folder:persistence=10,persist
persistence:default=influxdb
chart:provider=default
logging:pattern=%date{ISO8601} - %-25logger: %msg%n
tcp:refreshinterval=250
tinkerforge:hosts=localhost
tinkerforge:temperature.uid=zuG
tinkerforge:temperature.type=bricklet_temperature
tinkerforge:temperature.slowI2C=False
tinkerforge:relay_heating.uid=rzB
tinkerforge:relay_heating.type=dual_relay
tinkerforge:relay_heating.subid=relay1
influxdb:url=http://databaseip:8086
influxdb:user=openhab
influxdb:password=tf
influxdb:db=openhab
influxdb:retentionPolicy=autogen
influxdb.persist
Strategies {
everySecond : "0/1 * * * * ?"
everyFiveSeconds : "0/5 * * * * ?"
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
default = everyChange
Items {
temperature : strategy = everyChange
opensensor.items
Number temperature “Room Temperature [%.2f]” { tinkerforge=“uid=zuG” }
Number Thermostat “Setpoint [%.1f °C]”
Switch DualRelay1 “Heating” { tinkerforge=“name=relay_heating” }
Switch Heating “Heating On/Off”
When I query the database this is what I can read:
{“results”:[{“series”:[{“name”:“measurements”,“columns”:[“name”],“values”:[[“DualRelay1”],[“Thermostat”],[“temperature”]]}]}]}
Which are the actual items but not the value (i.e. temperature value)
I am sure is something stupid but I couldn’t really find a solution this this. Any ideas?
Thanks a lot!
