Hi to all,
is there any way to install OH3 on NAS like this :
Could be something like Synology?
I’m not developer, I’m only user of OH3, and i have this older nas to resuscitate!!
Hi to all,
It’s runs a custom variant of linux so you might be able to. You’ll need to have a google how to install/run custom Linux packages on it and use the Linux apt get installation from the docs
Many thanks, I found this :
https://github.com/hn/seagate-blackarmor-nas
I will try it in the next weeks…
thanks !
YES - WE - DO - IT !!!
In recent days we managed to install Debian on NAS220, then we added “sudo” etc … the only problem now is that we can’t install Zulu11 … we followed the tutorials indicated in the documentation … we will try again in the next days …
Thanks for the advice!
We are not able to find a right java version compatible with armel cpu on NAS220… someone have ideas or exeperience? who already install OH on NAS220?
thanks
Just looking.. Debian seems to have an openjdk present which might work..
Does azul arm 32bit SF not work?
I already try in the last days.. now i get thie error :
tebraxin@debian:~$ sudo apt-get -yq install gnupg curl
E: dpkg was interrupted, you must manually run ‘sudo dpkg --configure -a’ to correct the problem.
tebraxin@debian:~$
this command will block the nas and needs to restart its..
Yeah I’m not a Linux guru sorry, I haven’t the foggiest.
