- Platform information:
- Hardware: aarch64 with 32 bit kernel/4gb/30GB
- OS: Debian 10.8
- Java Runtime Environment: openjdk 11.0.9.1 2020-11-04
- openHAB version: 3.0.2
I have configured an outgoing MQTT channel of type switch
using the test.things
file and connected it to a Switch item in the main UI. I specified transformationPatternOut
to convert the item state to a complex json message using the MAP transformation with the file foo.map
. According to the documentation the transformation should map the values ON
and OFF
, this works until I restart openHAB. Sometimes after a restart of openHAB the values change to 1
and 0
. After a restart of the raspberry pi the values are ON
and OFF
again.
Currently I use 1
and 0
in the map file, which works until I restart the raspberry pi, then I get the following log message Could not transform 'OFF' with the file 'foo.map'...
. However changing the map file to ON and OFF does not work because then after a restart of openHAB I get Could not transform '0' with the file 'foo.map'...
test.things
Thing topic MySwitches "MySwitches " {
Channels:
Type switch : Unit1 "Unit 1" [ commandTopic="foo", transformationPatternOut="MAP:foo.map" ]
foo.map
1={"message":"testa"}
0={"message":"testb"}
I can switch between ON/OFF and 0/1 by restarting openHAB and the raspberry pi respectively.
