Issue of the topic: Fresh install of openHAB 2.3.0, its running but it does not listen to port 8080 or 8443, it listens to no port what so ever, if I try to use openhab-cli console it asks me for a user but openhab:habopen is not working, the /var/log/openhab2/openhab.log tells me Lockacquuired Setting startlevel to 100
Please post configurations (if applicable): NONE, Fresh install
If logs where generated please post these here using code fences:
If I start sudo openhab-cli start --debug I can see an error Error in initialization script: /var/lib/openhab2/etc/shell.init.script: /var/lib/openhab2/etc/shell.init.script
And still no port bind to 8080 or 8443
Ports that come from openHAB are 5005 which states the openhab-cli is “Listening for transport dt_socket at address: 5005”
I tried to reinstall openHAB 2.3.0 5 times from scratch via apt, everytime deleted all config, all old files, even with restart etc. still no success.
Just that you know, I am not a noob to openHAB I have setup over 20 instances of openHAB. Started with openhab 1.7/1.8 so I am familiar with the installation procedure. Manual, APT, Docker and openHABian are nothing new to me.
I did not mean to make you feel bad or anything, just wanted to let you know this ain’t the first time for me
I am always happy if someone from the community is trying to help, that’s one of the best things about this community.
That’s very wrong, alone the fact that you try to help and already contributed to the community makes you a valuable member of this project! So I encourage you to keep helping even if someone like me seems a bit sassy (sorry for that )
