- Platform information:
- Hardware:x86 64bit
- OS: ReadyNas Linux nas 4.4.91.x86_64.1 #1 SMP Tue Oct 10 14:55:58 PDT 2017 x86_64 GNU/Linux
- Java Runtime Environment: openjdk version “1.8.0_202”
OpenJDK Runtime Environment (Zulu 8.36.0.1-CA-linux64) (build 1.8.0_202-b05)
OpenJDK 64-Bit Server VM (Zulu 8.36.0.1-CA-linux64) (build 25.202-b05, mixed mode) - openHAB version: 2.4.0 release build
- Issue of the topic: From time to time I run into the issue that suddenly events seems not be processed anymore. For example from DSMR and Astro.
2019-02-19 12:37:03.238 [vent.ItemStateChangedEvent] - P1_Actual_Production changed from 0.727 to 0.691
2019-02-19 12:37:03.243 [vent.ItemStateChangedEvent] - P1_Actual_PowerProductionsL1 changed from 0.363 to 0.352
2019-02-19 12:37:03.249 [vent.ItemStateChangedEvent] - P1_Actual_PowerProductionsL2 changed from 0.113 to 0.104
2019-02-19 12:37:03.252 [vent.ItemStateChangedEvent] - P1_Actual_PowerProductionsL3 changed from 0.247 to 0.233
2019-02-19 12:37:13.234 [vent.ItemStateChangedEvent] - P1_Actual_Production changed from 0.691 to 0.663
2019-02-19 12:37:13.267 [vent.ItemStateChangedEvent] - P1_Actual_PowerProductionsL1 changed from 0.352 to 0.345
2019-02-19 12:37:13.272 [vent.ItemStateChangedEvent] - P1_Actual_PowerProductionsL2 changed from 0.104 to 0.099
2019-02-19 12:37:13.280 [vent.ItemStateChangedEvent] - P1_Actual_PowerProductionsL3 changed from 0.233 to 0.223
While binding keeps generating events:
2019-02-19 12:39:23.368 [DEBUG] [mr.internal.handler.DSMRMeterHandler] - Updating state for channel emeter_equipment_identifier to value E0026000018049615
2019-02-19 12:39:23.371 [DEBUG] [mr.internal.handler.DSMRMeterHandler] - Updating state for channel emeter_delivery_tariff1 to value 11192.174 kWh
2019-02-19 12:39:23.374 [DEBUG] [mr.internal.handler.DSMRMeterHandler] - Updating state for channel emeter_delivery_tariff2 to value 6655.920 kWh
2019-02-19 12:39:23.376 [DEBUG] [mr.internal.handler.DSMRMeterHandler] - Updating state for channel emeter_production_tariff1 to value 5758.373 kWh
2019-02-19 12:39:23.379 [DEBUG] [mr.internal.handler.DSMRMeterHandler] - Updating state for channel emeter_production_tariff2 to value 12353.344 kWh
2019-02-19 12:39:23.381 [DEBUG] [mr.internal.handler.DSMRMeterHandler] - Updating state for channel emeter_tariff_indicator to value 0002
2019-02-19 12:39:23.384 [DEBUG] [mr.internal.handler.DSMRMeterHandler] - Updating state for channel emeter_actual_delivery to value 1.218 kW
2019-02-19 12:39:23.386 [DEBUG] [mr.internal.handler.DSMRMeterHandler] - Updating state for channel emeter_actual_production to value 0.000 kW
2019-02-19 12:39:23.388 [DEBUG] [mr.internal.handler.DSMRMeterHandler] - Updating state for channel emeter_power_failures to value 6
Please let me know when I can diagnose this a bit deeper.
I start openHab with start.sh as root while testing as it does not start when I try to run as openhab user with “sudo su -s /bin/bash -c ‘./start.sh’ openhab”. Also when running in systemd the problem happens.
Not sure how to attach a tgz, my config can be found here: Unique Download Link | WeTransfer
