Hi !
Has anyone found out the Openhab MQTT State Topic for the new Shelly Pro 4PM?
I just can’t get it.
Switching ON/OFF per switch works via MQTT.
The only thing that bothers me is the feedback whether the switch is ON/OFF.
Thank you!
Hi !
Thank you!
I am also searching for the correct State Topic for Shelly Plus/Pro.
My Thing so far:
label: Stallgasse-1
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:f1323ff450
channels:
- id: Stallgasse_1_0
channelTypeUID: mqtt:switch
label: Lichtschiene Bar
description: ""
configuration:
commandTopic: shellies/stallgasse-1/rpc
stateTopic: shellies/stallgasse-1/relay/0
off: '{"method":"Switch.Set","params":{"id":0,"on":false}}'
on: '{"method":"Switch.Set","params":{"id":0,"on":true}}'
- id: Stallgasse_1_1
label: Lichtschiene Stallgasse
description: ""
configuration:
stateTopic: shellies/stallgasse-1/relay/1
off: '{"method":"Switch.Set","params":{"id":1,"on":false}}'
on: '{"method":"Switch.Set","params":{"id":1,"on":true}}'
- id: Stallgasse_1_2
label: Schotterweg
description: Aussen Schotterweg
configuration:
stateTopic: shellies/stallgasse-1/relay/2
off: '{"method":"Switch.Set","params":{"id":2,"on":false}}'
on: '{"method":"Switch.Set","params":{"id":2,"on":true}}'
- id: Stallgasse_1_3
label: Pferdebox
description: Pferdebox
configuration:
stateTopic: shellies/stallgasse-1/relay/3
off: '{"method":"Switch.Set","params":{"id":3,"on":false}}'
on: '{"method":"Switch.Set","params":{"id":3,"on":true}}'
Hi! My solution:
Hope it helps anybody
- id: Relay3
label: Relay3
description: ""
configuration:
commandTopic: shellies/shellypro4pm-84cca87d86bc/rpc
formatBeforePublish: '{"src":"MQTT","method":"Switch.Set", "params":{"id":3,"on":%s}}'
stateTopic: shellies/shellypro4pm-84cca87d86bc/events/rpc
transformationPattern: JSONPATH:$.params.switch:3.output
off: "false"
on: "true"
Now the complete Solution
