[ I also posted this over on souliss google group ]
I recently got the souliss e02_LYT8266_WIFI_BULB example working on my lyt8266’s (after uploading the erase example). I can connect to them from the soulissApp and change colors, turn them on/off, dim, etc. However I can not send them actions from the openhab binding. I seem to be able to receive data from them however (D99, D98).
versions:
arduino studio 1.6.5
souliss 7.1.1
esp board configs: 1.6.5-1160-gef26c5f
compiled and uploaded on windows 10
openhab 1.8.3
souliss binding 1.8.3
raspberry pi 3 running raspbian
lyt8266 1 - GW with 192.168.70.160 IP
lyt8266 2 - peer with dhcp IP
as mentioned souliss app works (“flash” and “sleep” don’t seem to work but I’m going to guess that’s unrelated)
next config files:
//home.item
//souliss devices
Color RGB_LytBulb_1 "RGB LytBulb 1" <slider> {souliss="T16:0:0", autoupdate=false}
Number RGB_LytBulb_1_health "Health Node 0 [%1d]" <keyring> {souliss="D98:0:998"}
String RGB_LytBulb_1_LH "Update Node 0 [%1$td.%1$tm.%1$tY %1$tk:%1$tM:%1$tS]" <keyring> {souliss="D99:0:999"}
Color RGB_LytBulb_2 "RGB LytBulb 2" <slider> {souliss="T16:1:0", autoupdate=false}
Number RGB_LytBulb_2_health "Health Node 1 [%1d]" <keyring> {souliss="D98:1:998"}
String RGB_LytBulb_2_LH "Update Node 1 [%1$td.%1$tm.%1$tY %1$tk:%1$tM:%1$tS]" <keyring> {souliss="D99:1:999"}
//home.sitemap
Frame label="lyts" {
Colorpicker item=RGB_LytBulb_1
Text item=RGB_LytBulb_1_health
Text item=RGB_LytBulb_1_LH
Colorpicker item=RGB_LytBulb_2
Text item=RGB_LytBulb_2_health
Text item=RGB_LytBulb_2_LH
web screenshot of sitemap
#openhab.cfg
################################ Souliss Binding ######################################
# For ITEM defination in file .item like {souliss=<Typical>:<nodeID>:<slot>:[<bit>]}
souliss:IP_LAN=192.168.70.160
souliss:USER_INDEX=71
souliss:NODE_INDEX=134
# SERVERPORT - Leave empty for casual port
#souliss:SERVERPORT=
# Time in mills - min 50
#souliss:REFRESH_DBSTRUCT_TIME=600000
#souliss:REFRESH_SUBSCRIPTION_TIME=120000
#souliss:REFRESH_HEALTY_TIME=60000
#souliss:REFRESH_MONITOR_TIME=500
#souliss:SEND_DELAY=1500
#souliss:SEND_MIN_DELAY=100
#souliss:SECURE_SEND_TIMEOUT_TO_REQUEUE=5000
#souliss:SECURE_SEND_TIMEOUT_TO_REMOVE_PACKET=30000
#grep receiveCommand excerpt.log
2016-09-25 01:46:41.794 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_1 = 117.96610169491527,74.68354430379746,30.980392156862745 - Typical: 0x16
2016-09-25 01:46:43.445 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_1 = 239.0769230769231,82.27848101265823,30.980392156862745 - Typical: 0x16
2016-09-25 01:46:44.877 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_1 = 354.70588235294116,86.07594936708861,30.980392156862745 - Typical: 0x16
2016-09-25 01:46:46.402 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_1 = 354.97536945812806,85.65400843881856,92.94117647058823 - Typical: 0x16
2016-09-25 01:46:47.485 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_1 = 132.0618556701031,81.85654008438819,92.94117647058823 - Typical: 0x16
2016-09-25 01:46:48.461 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_1 = 241.0404624277457,72.9957805907173,92.94117647058823 - Typical: 0x16
2016-09-25 01:46:49.191 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_1 = 241.20805369127518,73.0392156862745,80 - Typical: 0x16
2016-09-25 01:46:53.715 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_2 = 115.87155963302753,85.49019607843137,100 - Typical: 0x16
2016-09-25 01:46:54.634 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_2 = 238.86792452830187,83.13725490196079,100 - Typical: 0x16
2016-09-25 01:46:55.905 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_2 = 351.98275862068965,90.98039215686275,100 - Typical: 0x16
2016-09-25 01:46:56.966 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_2 = 58.90909090909091,86.27450980392156,100 - Typical: 0x16
2016-09-25 01:46:58.434 [INFO ] [.o.b.s.internal.SoulissBinding] - receiveCommand - RGB_LytBulb_2 = 17.142857142857142,2.7450980392156863,100 - Typical: 0x16
The log output seems extremely verbose, so heres a gist of /var/log/openhab/openhab.log while I attempt to change the color for both lytBulb1 and lytbulb2 5-7 times each (which i believe you’ll see above and in the gist)
lastly here are some screenshots of souliss app working as i think it should (to verify my typical, node, slot settings) https://imgur.com/a/eqnQh
Any thoughts would be greatly appreciated!
thank you
-Rich
