Openhab SoundCloud Binding (NEW)
openHAB SoundCloud Binding
A community binding that connects openHAB to SoundCloud.
Search tracks, view cover art and stream audio directly to a Chromecast — all from a single MainUI widget.
Feedback welcome in the openHAB community forum.
Features (v1.2.3)
  • Search tracks by keyword — results appear instantly in the widget list
  • Cover art at 500 × 500 px displayed alongside title and artist
  • Stream URL resolved automatically to a direct MP3 link (progressive format, Chromecast-compatible)
  • Chromecast integration built into the widget — select a Chromecast, press Play
  • Volume slider for real-time Chromecast volume control
  • Pause / Stop / Mute buttons mapped to the correct Chromecast binding channels
  • Playback state channel (PLAYING / PAUSED / STOPPED)
  • OAuth 2.0 authentication — authorise once in the browser, tokens are stored and auto-refreshed
Screenshot 2026-05-19 033922
Screenshot_20260519_033512_openHAB
Requirements
Requirement Notes
openHAB 5.1.3 or newer older versions are not supported
Java 21+ bundled with openHAB 5.x
SoundCloud API credentials register an app at soundcloud.com/you/apps — free for personal/home use
openHAB Chromecast Binding optional, required for cast functionality
Installation
1. Download the JAR
Download org.openhab.binding.soundcloud-1.2.3.jar from the latest release and copy it to your openHAB addons/ folder.
openHAB detects and loads the bundle automatically — no restart needed. Check Settings → Bindings to confirm it appears.
2. Install the widget
  1. In the openHAB MainUI open Developer Tools → Widgets
  2. Click the + button → import
  3. Paste the content of soundcloud_search.yaml (also in the release assets)
  4. Save
3. Build from source (optional)
git clone https://github.com/pierrecinema/openhab-soundcloud-binding.git
cd openhab-soundcloud-binding
mvn clean package -DskipTests
# copy target/org.openhab.binding.soundcloud-1.2.3.jar to your addons/ folder
Configuration
Thing
Add a Thing in Settings → Things → + → SoundCloud Account, or create conf/things/soundcloud.things:
Thing soundcloud:account:myaccount "SoundCloud" [
    clientId     = "YOUR_CLIENT_ID",
    clientSecret = "YOUR_CLIENT_SECRET",
    redirectUri  = "http://YOUR_OPENHAB_HOST:8080/soundcloud/callback"
Parameter Required Description
clientId :white_check_mark: Client ID from soundcloud.com/you/apps
clientSecret :white_check_mark: Client Secret from your registered app
redirectUri :white_check_mark: Must match exactly what is registered in your SoundCloud app
webClientId optional Internal SoundCloud web client ID for api-v2 (default value included)
OAuth authorisation
After the Thing is created it goes OFFLINE and prints an authorisation URL in the log. Open the URL in any browser, log in to SoundCloud and grant access. The binding stores the tokens automatically and the Thing goes ONLINE. Tokens are refreshed in the background — you only need to authorise once.
Items
Create conf/items/soundcloud.items (or add via the UI):
// Player
String   SC_TrackID       "Track ID"        { channel="soundcloud:account:myaccount:player#track-id" }
String   SC_Title         "Titel [%s]"      { channel="soundcloud:account:myaccount:player#title" }
String   SC_Artist        "Artist [%s]"     { channel="soundcloud:account:myaccount:player#artist" }
String   SC_ArtworkURL    "Cover [%s]"      { channel="soundcloud:account:myaccount:player#artwork-url" }
Number   SC_Duration      "Dauer [%.0f s]"  { channel="soundcloud:account:myaccount:player#duration" }
String   SC_StreamURL     "Stream URL [%s]" { channel="soundcloud:account:myaccount:player#stream-url" }
String   SC_State         "Status [%s]"     { channel="soundcloud:account:myaccount:player#playback-state" }
String   SC_CCTarget      "CC Target [%s]"  { channel="soundcloud:account:myaccount:player#chromecast-target" }
// Search
String   SC_Query         "Suche [%s]"      { channel="soundcloud:account:myaccount:search#query" }
String   SC_Results       "Ergebnisse [%s]" { channel="soundcloud:account:myaccount:search#results" }
For Chromecast, you also need the items from the Chromecast Binding already linked to your Chromecast thing. The widget uses these directly — no additional items need to be created manually.
Tag your Chromecast playuri items with Chromecast so the widget discovers them automatically:
String MyChromecast_PlayURI "Chromecast Wohnzimmer" [ "Chromecast" ] { channel="chromecast:chromecast:abc123:playuri" }
Widget setup
Add the soundcloud_search widget to a page and configure the following properties:
Property Required Description
queryItem :white_check_mark: String Item → search#query
resultsItem :white_check_mark: String Item → search#results
trackIdItem :white_check_mark: String Item → player#track-id
streamUrlItem String Item → player#stream-url
titleItem String Item → player#title
artistItem String Item → player#artist
artworkItem String Item → player#artwork-url
stateItem String Item → player#playback-state
chromecastTargetItem String Item linked to player#chromecast-target — stores the selected Chromecast (e.g. SC_CCTarget)
chromecastTag Tag on your Chromecast playuri items (default: Chromecast)
Note: Pause, Stop, Volume and Mute are routed via four fixed proxy items (SC_CC_Control, SC_CC_Stop, SC_CC_Volume, SC_CC_Mute) and a routing rule — see Chromecast routing rule below. No per-device configuration is needed in the widget.
Channel reference
Channel Type R/W Description
player#track-id String RW Write a track ID to load it; reads back the current track ID
player#playlist-id String W Write a playlist ID to load its first track
player#title String R Current track title
player#artist String R Current track artist / uploader
player#artwork-url String R 500×500 px cover art URL
player#duration Number R Track duration in seconds
player#stream-url String R Direct MP3 URL (resolved via api-v2 transcodings)
player#playback-state String RW PLAYING / PAUSED / STOPPED
player#chromecast-target String RW Name of the selected Chromecast playuri item
search#query String W Send a search term
search#results String R JSON array: [{id, title, artist, artwork, duration}, …]
Chromecast workflow
  1. Search — type a term and press Enter
  2. Select a track — tap a result to load cover, title, artist and stream URL
  3. Select a Chromecast — tap a chip at the bottom of the card (discovered automatically via item tags)
  4. Press Play — the stream URL is sent directly to the selected Chromecast
  5. Volume / Mute / Pause / Stop — dedicated buttons and slider in the widget
The widget’s Pause, Stop, Volume and Mute buttons always send to four fixed proxy items (SC_CC_Control, SC_CC_Stop, SC_CC_Volume, SC_CC_Mute). A JS rule reads which Chromecast is currently selected and forwards the command to the correct device-specific item.
Why is a rule needed?
Widget expressions can only use fixed item names. They cannot dynamically look up which control item belongs to the currently selected Chromecast. The routing rule bridges this gap — one rule handles all devices, no per-device widget configuration required.
Planned for v1.3: This logic will move into the binding itself, eliminating the need for any rule.
Setup
Step 1 — Create the four proxy items (once, in Settings → Items or via .items file):
Player SC_CC_Control "SoundCloud CC Control"
Switch SC_CC_Stop    "SoundCloud CC Stop"
Dimmer SC_CC_Volume  "SoundCloud CC Volume"
Switch SC_CC_Mute    "SoundCloud CC Mute"
Also create the target item and link it to the binding channel:
String SC_CCTarget "SoundCloud CC Target" { channel="soundcloud:account:myaccount:player#chromecast-target" }
Step 2 — Create the routing rule in Settings → Rules → + (ECMAScript 2021, triggered by command on each of the four proxy items):
var triggerItem = event.itemName;
var cmd         = event.receivedCommand.toString();
var targetName  = items.getItem('SC_CCTarget').state;
if (!targetName || targetName === 'NULL') return;
// Map each Chromecast playuri item to its control items.
// Add a new entry here whenever you add a Chromecast device.
var MAPPING = {
  'BuroCast_Play_URI': {
    control : 'BuroCast_Media_Control',
    stop    : 'BuroCast_Stop',
    volume  : 'BuroCast_Volume',
    mute    : 'BuroCast_Mute'
  'Hifigruppe_Play_URI': {
    control : 'Hifigruppe_Media_Control',
    stop    : 'Hifigruppe_Stop',
    volume  : 'Hifigruppe_Volume',
    mute    : 'Hifigruppe_Mute'
  // Add more devices here:
  // 'YourDevice_Play_URI': { control: '...', stop: '...', volume: '...', mute: '...' }
var map = MAPPING[targetName];
if (!map) { logger.warn('SC Router: no mapping for ' + targetName); return; }
var destName = null;
if      (triggerItem === 'SC_CC_Control') destName = map.control;
else if (triggerItem === 'SC_CC_Stop')    destName = map.stop;
else if (triggerItem === 'SC_CC_Volume')  destName = map.volume;
else if (triggerItem === 'SC_CC_Mute')    destName = map.mute;
if (destName) {
  items.getItem(destName).sendCommand(cmd);
  logger.info('SC Router: ' + triggerItem + ' → ' + destName + ' (' + cmd + ')');
Configure the rule triggers as Item Command on: SC_CC_Control, SC_CC_Stop, SC_CC_Volume, SC_CC_Mute.
Step 3 — Configure the widget:
  • chromecastTargetItem = SC_CCTarget
  • All other Chromecast props: leave empty
Adding a new Chromecast
  1. Tag the device’s playuri item with Chromecast — it appears automatically as a chip in the widget
  2. Add one entry to the MAPPING object in the routing rule with the item names for control, stop, volume and mute
Roadmap
Version Status Description
v1.0.x :white_check_mark: done Core binding: search, track load, stream URL via api-v2
v1.1.x :white_check_mark: done Widget: search results list, track selection, cover art
v1.2.x :white_check_mark: done Chromecast integration: chip selection, play/pause/stop/mute/volume
v1.3.x planned Auto-cast when track changes (no manual Play press needed)
v1.4.x planned Playlist queue: next / previous track navigation
v1.5.x planned Progress bar / elapsed time display
v2.0.0 planned Submit to openHAB add-ons repository
Known limitations (Alpha)
  • Only the first track of a playlist is played (queue not yet implemented)
  • Stream URLs are time-limited by SoundCloud and expire after some time; reloading the track generates a fresh URL
  • The SoundCloud API requires a registered app — streaming is only available when a valid Client ID / OAuth token is configured
You may be ready for this now, but if not when you are ready you should post this to Marketpalce > Bundles (and the widget to Marketplace > Widgets, and the rule as a tempalte under Marketplace > Rule Tempaltes). Follow the template there for each post.
Doing so will allow users to install the add-on, widget, and rule from MainUI → Add-on store just like official add-ons. This makes it much easier for your users to get up and running.
Unforutnately a singel bundle that includes everything in one post isn’t possible yet.
Never mind. I see you are way ahead of me.
Thanks for posting!
Hier der Update-Post:
Update: v1.2.8 — mehrere Bugs behoben
Nach den ersten Tagen im Einsatz wurden folgende Probleme gefunden und gefixt:
v1.2.5 — OAuth Token-Refresh Der Refresh-Token-Aufruf enthielt einen Parameter den SoundCloud ablehnt (redirect_uri ist beim Refresh-Grant laut RFC 6749 optional — SoundCloud antwortet mit HTTP 400 wenn er trotzdem mitgeschickt wird). Behoben.
v1.2.6 — Auth-URL war nach Fehler nicht sichtbar Wenn die Autorisierung fehlschlug, wurde die Auth-URL im Thing-Status sofort von einer Fehlermeldung überschrieben. Zusätzlich: wenn der Refresh fehlschlägt aber der Access-Token noch gültig ist, bleibt das Thing jetzt ONLINE und versucht den Refresh nach 5 Minuten erneut — statt sofort in OFFLINE zu gehen.
v1.2.7 — Suchergebnisse blieben beim alten Künstler hängen Zwei parallele Suchanfragen konnten sich gegenseitig überschreiben (Race Condition). Die ältere, langsamere Antwort traf manchmal nach der neueren ein. Behoben mit Generation-Counter — veraltete Antworten werden verworfen. Außerdem werden die alten Ergebnisse jetzt sofort geleert wenn eine neue Suche startet.
v1.2.8 — Token lief nach Neustart ab Nach einem openHAB-Neustart wurde der nächste Refresh immer auf 59 Minuten ab jetzt geplant — unabhängig vom tatsächlichen Alter des Tokens. War der Token schon 50 Minuten alt, lief er 10 Minuten später ab während der Refresh erst in 59 Minuten geplant war. Das Binding speichert jetzt den exakten Ablaufzeitpunkt und berechnet beim Start die verbleibende Restlaufzeit korrekt.
Download: v1.2.8 Release JAR einfach in den addons/-Ordner kopieren — openHAB lädt automatisch nach.
Passt das so oder soll ich etwas kürzen/anpassen?
English please!
Update: v1.2.8 — Several bugs fixed
After the first few days in production the following issues were found and resolved:
v1.2.5 — OAuth token refresh The refresh token request included a parameter that SoundCloud rejects (redirect_uri is optional in a refresh grant per RFC 6749 — SoundCloud returns HTTP 400 if it is sent anyway). Fixed.
v1.2.6 — Auth URL was not visible after a failure When authorisation failed, the auth URL in the Thing status was immediately overwritten by an error message. Additionally: if the refresh fails but the access token is still valid, the Thing now stays ONLINE and retries the refresh after 5 minutes — instead of going OFFLINE right away.
v1.2.7 — Search results stuck on the previous artist Two concurrent search requests could overwrite each other (race condition). The older, slower response sometimes arrived after the newer one. Fixed with a generation counter — outdated responses are discarded. Old results are also cleared immediately when a new search is started.
v1.2.8 — Token expired after a restart After an openHAB restart the next refresh was always scheduled 59 minutes from now, regardless of how old the existing token actually was. If the token was already 50 minutes old it would expire 10 minutes later while the refresh was still planned for 59 minutes out. The binding now stores the exact expiry timestamp and calculates the true remaining lifetime correctly on every startup.
Download: v1.2.8 Release Drop the JAR into your addons/ folder — openHAB picks it up automatically, no restart needed.
change to beta status
Features (v1.2.9)
