openHAB Startup Errors - BasicUI Circular References, Bindings
Raspbian GNU/Linux 9 (stretch)
Linux 4.14.62-v7+
Raspberry Pi 3 Model B Rev 1.2
openHAB 2.3.0-1 (Release Build)
0 apt updates available.
java -version
openjdk version "1.8.0_152"
OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, mixed mode, Evaluation)
I did search the Community for references to these kinds of errors. However, they were almost two years old and referred to fixes that would have come out in earlier openHAB versions (e.g. 2.1 and 2.2). As I am running openHAB 2.3, I thought it warranted me posting this as a new issue.
openHAB log - attached due to post character count limits
Parsed openHAB.pdf (234.7 KB)
I’m not sure if these log errors are related, but as they always occur during the service startup, I have included them.
Also, there might be other items in the log that I was not able to capture in this post. I say this only because I cannot ā€œgrepā€ the log without including the ā€˜-a’ option. It appears that there are some binary (non-printable text) elements in the log. Perhaps this is in conjunction with the encoded PNG, but I would have thought that the encoding would only include text.
I also find that if I want to restart openHAB, I need to stop the service, wait several seconds, and then start openHAB. Otherwise I get BasicUI error 503 errors. I found a post that gave this hint and that it might be due to Jetty startup errors. I include this side note here as it’s also related to BasicUI.
Even though I have these errors in the log, everything appears to function normally (BasicUI, MQTT, & MQTTITUDE/OwnTracks). I just want to resolve any lingering issues as I am now ā€œstabilizingā€ my environment with not imminent plans to add any more automation components.
Regards.
Mike
Those logs are common on start up, its items or rules that are trying to run before OH can finish starting up. Nothing to worry about there.
I can’t provide much info on the Circular Ref issue. I rebooted my Oh yesterday and looking thru my logs I have nothing similar. Best of luck and hope you find a solution soon.
The Home Builder circular reference is fixed in 2.4.0-SNAPSHOT with:
Does the Home Builder fix apply to BasicUI? Or is there something in the log that points to Home Builder?
The issue for which the PR was created has the same ā€œcircular referenceā€ logging as your log:
I don’t know if it also solves the other stack traces.
Thx. I’ll give this a try after I get a good backup.
Is there a way for me to introduce a delay in the startup prior to having my user declared elements load?
Not that I’m aware of, hopefully the bug fix will be soon.
I cloned my 2.3.0-1 openHABian environment and took the plunge. I ran openhabian-config and updated to the latest SNAPSHOT - 2.4.0~20180929001318-1 (Build #1375)
I still have the circular reference error.
2018-09-29 00:20:25.784 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-09-29 00:20:25.980 [ERROR] [org.apache.felix.scr                ] - bundle org.apache.felix.scr:2.1.2 (39)Circular reference detected trying to get service {org.openhab.ui.dashboard.DashboardTile}={service.id=333, service.bundleid=200, service.scope=bundle, component.name=org.openhab.ui.basicui.internal.BasicUIDashboardTile, component.id=215}
 stack of references: ServiceReference: {org.openhab.ui.dashboard.DashboardTile}={service.id=333, service.bundleid=200, service.scope=bundle, component.name=org.openhab.ui.basicui.internal.BasicUIDashboardTile, component.id=215}
ServiceReference: {org.openhab.ui.dashboard.internal.DashboardService}={frontail.link-imageurl=data:image/png;base64,{ENCODED PNG}, service.bundleid=181, service.scope=bundle, openhabiandocs.link-name=openHABian Help, openhabiandocs.link-url=https://www.openhab.org/docs/installation/openhabian.html, frontail.link-url=http://openHABianPi:9001, component.name=org.openhab.dashboard, component.id=216, frontail.link-name=openHAB Log Viewer, service.pid=org.openhab.dashboard}
java.lang.Exception: stack trace
	at org.apache.felix.scr.impl.ComponentRegistry.enterCreate(ComponentRegistry.java:481) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.enterCreate(BundleComponentActivator.java:735) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:845) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) ~[?:?]
	at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) ~[?:?]
	at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:662) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2304) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.prebind(DependencyManager.java:419) ~[?:?]
	at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1576) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1014) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:899) ~[?:?]
	at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:863) ~[?:?]
	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) ~[?:?]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) ~[?:?]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) ~[?:?]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) ~[?:?]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
	at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468) ~[?:?]
	at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:103) ~[?:?]
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529) ~[?:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) ~[?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) ~[?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) ~[?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:984) ~[?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1011) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[?:?]
	at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:161) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1116) ~[?:?]
	at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:997) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1025) ~[?:?]
	at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:964) ~[?:?]
Log continued in next reply due to 32K character limit…
2018-09-29 00:20:26.307 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.11:8080
2018-09-29 00:20:26.259 [WARN ] [org.eclipse.smarthome.ui.basic      ] - FrameworkEvent WARNING - org.eclipse.smarthome.ui.basic
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:?]
	at java.lang.Thread.run(Thread.java:748) ~[?:?]
2018-09-29 00:20:26.373 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.11:8443
