- Platform information:
- Hardware: RPI3 typeB
- OS: openhabian
- Java Runtime Environment: openjdk version Zulu 8.50.0.259-CA-linux_aarch32hf) (build 1.8.0_272-b17
- openHAB version: openHAB 2.5.10-1
- Issue of the topic:
I kindly ask for help after I done the followings:
Since the openHAB Cloud Connector was not working anymore I tried to implement the solution explanied here because I was not able to unintsall the addon via UI:
[SOLVED] myopenhab.org says "Your openHAB is not online." - #3 by candrea. After I have executed the commands from the solution :
sudo systemctl stop openhab2
sudo openhab-cli clean-cache
sudo systemctl start openhab2
I got the following error messages:
- If logs where generated please post these here using code fences:
2022-11-02 13:03:15.470 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-mqttbroker, openhab-binding-onewiregpio, openhab-persistence-mapdb, openhab-ui-homebuilder, openhab-binding-mqtt, openhab-transformation-map, openhab-ui-basic, openhab-ui-classic, openhab-ui-habmin, openhab-ui-habpanel, openhab-ui-paper, openhab-binding-gpio1': Error:
Error downloading mvn:javax.xml.bind/jaxb-api/2.2.12
Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.habmin/[2.5.0,2.6)
Error downloading mvn:com.sun.xml.bind/jaxb-core/2.2.11
Error downloading mvn:com.sun.xml.bind/jaxb-impl/2.2.11
Error downloading mvn:javax.activation/activation/1.1.1
Now I can’t see any installed binding in kraft console:
openhab> bundle:list
START LEVEL 100 , List Threshold: 50
ID │ State │ Lvl │ Version │ Name
19 │ Active │ 80 │ 5.3.1.201602281253 │ OSGi JAX-RS Connector
20 │ Active │ 80 │ 2.8.2.v20180104-1110 │ Gson: Google Json Library for Java
21 │ Active │ 80 │ 18.0.0 │ Guava: Google Core Libraries for Java
22 │ Active │ 80 │ 27.1.0.jre │ Guava: Google Core Libraries for Java
23 │ Active │ 80 │ 1.0.1 │ Guava InternalFutureFailureAccess and InternalFutures
24 │ Active │ 80 │ 3.0.0.v201312141243 │ Google Guice (No AOP)
25 │ Active │ 80 │ 4.8.35.v20190528-1517 │ ClassGraph
26 │ Active │ 80 │ 3.18.1.GA │ Javassist
29 │ Active │ 80 │ 3.5.5 │ JmDNS
31 │ Active │ 80 │ 1.0.0 │ Units of Measurement API
33 │ Active │ 80 │ 1.1.0.Final │ Bean Validation API
35 │ Active │ 80 │ 2.0.1 │ javax.ws.rs-api
36 │ Active │ 80 │ 2.9.2 │ Joda-Time
37 │ Active │ 80 │ 0.5.8 │ Jollyday
38 │ Active │ 80 │ 3.2.0.v201101311130 │ ANTLR Runtime
40 │ Active │ 80 │ 1.1 │ Commons Exec
41 │ Active │ 80 │ 2.2.0 │ Commons IO
42 │ Active │ 80 │ 2.6 │ Commons Lang
51 │ Active │ 80 │ 4.2.7 │ Apache Karaf :: OSGi Services :: Event
66 │ Active │ 80 │ 1.4.7.1 │ Apache ServiceMix :: Bundles :: xstream
69 │ Active │ 80 │ 4.14.0 │ Apache XBean OSGI Bundle Utilities
70 │ Active │ 80 │ 4.14.0 │ Apache XBean :: Classpath Resource Finder
71 │ Active │ 80 │ 2.12.0.v20160420-0247 │ EMF Common
72 │ Active │ 80 │ 2.12.0.v20160420-0247 │ EMF Ecore
73 │ Active │ 80 │ 2.5.11.202011291921 │ openHAB Add-ons :: Bundles :: Shelly Binding
74 │ Active │ 80 │ 2.11.0.v20160420-0247 │ EMF Change Model
75 │ Active │ 80 │ 2.12.0.v20160420-0247 │ EMF XML/XMI Persistence
76 │ Active │ 80 │ 2.0.0 │ Californium (Cf) Element Connector
77 │ Active │ 80 │ 3.10.400.v20190516-1504 │ Common Eclipse Runtime
78 │ Active │ 80 │ 2.0.0 │ Californium (Cf) Core
107 │ Active │ 80 │ 0.8.0.v20190822-0801 │ org.eclipse.lsp4j
108 │ Active │ 80 │ 0.8.0.v20190822-0801 │ org.eclipse.lsp4j.jsonrpc
109 │ Active │ 80 │ 2.19.0.v20190902-0728 │ Xtend Runtime Library
110 │ Active │ 80 │ 2.19.0.v20190902-0728 │ Xtend Macro Interfaces
111 │ Active │ 80 │ 2.19.0.v20190902-0737 │ Xtext
112 │ Active │ 80 │ 2.19.0.v20190902-0952 │ Xtext Common Types
113 │ Active │ 80 │ 2.19.0.v20190902-0737 │ Xtext IDE Core
114 │ Active │ 80 │ 2.19.0.v20190902-0737 │ Xtext Utility
115 │ Active │ 80 │ 2.19.0.v20190902-0952 │ Xbase Model
116 │ Active │ 80 │ 2.19.0.v20190902-0952 │ Xbase Generic IDE Services
117 │ Active │ 80 │ 2.19.0.v20190902-0728 │ Xbase Runtime Library
132 │ Active │ 80 │ 1.9.6 │ MIME streaming extension
134 │ Active │ 80 │ 7.1.0 │ org.objectweb.asm.commons
135 │ Active │ 80 │ 7.1.0 │ org.objectweb.asm.tree
136 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Core
137 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Audio
138 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: OAuth2Client
139 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Binding XML
140 │ Active │ 90 │ 2.5.0 │ openHAB Core :: Bundles :: Boot
141 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Configuration Core
142 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Configuration Discovery
143 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Configuration mDNS Discovery
144 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Configuration Dispatcher
145 │ Active │ 75 │ 2.5.0 │ openHAB Core :: Bundles :: Configuration XML
146 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Ephemeris
147 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: ID
148 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Console
149 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Console for OSGi runtime Karaf
150 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: HTTP Interface
152 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Monitor
153 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Network I/O
154 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: REST Interface
155 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Audio REST Interface
156 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: REST Interface :: Core
157 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: REST mDNS Announcer
158 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: REST JAX-RS Optimizations
159 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Sitemap REST Interface
160 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: SSE Interface
161 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Voice REST Interface
162 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: mDNS Service
163 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Karaf Integration
164 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Core
165 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Items
166 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Item IDE
167 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Items Runtime
168 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Language Server
169 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Persistence
170 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Persistence IDE
171 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Persistence Runtime
172 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Rules
173 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Rule IDE
174 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Rules Runtime
175 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Script
176 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Script IDE
177 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Script Runtime
178 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Sitemap
179 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Sitemap IDE
180 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Sitemap Runtime
181 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Thing
182 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Thing IDE
183 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Model Thing Runtime
184 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Persistence
185 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Scheduler Service
186 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Semantics
187 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: JSON Storage
188 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Thing
189 │ Active │ 75 │ 2.5.0 │ openHAB Core :: Bundles :: Thing XML
190 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Transformation Service
191 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: UI
192 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: UI Icon Support
193 │ Active │ 80 │ 2.5.0 │ openHAB Core :: Bundles :: Voice
194 │ Active │ 80 │ 2.5.10 │ openHAB UI :: Bundles :: Dashboard UI
203 │ Active │ 80 │ 1.4.0 │ ThreeTen-Extra
204 │ Active │ 80 │ 1.0.3 │ Units of Measurement Common Library
205 │ Active │ 80 │ 1.0.10 │ Units of Measurement Implementation for Java SE
openhab>
Please let me know if I can fix this issue!
Thank you!
Marian
