I’m not sure if this is the right category for this or not. I’d appreciate it if someone could point me in some direction to get OpenHab going again. After probably a month without making a single change, most of the functions in my openhab instance quit working one evening, especially anything zwave. No things show up in paper UI, but the things config file is there. I was on 2.2, but did a sudo apt-get update etc. Below is a snippet of log right after reboot after the upgrade. I also have a zip file of the full log prior to upgrading, but it was blocked.
- Platform information:
- Hardware: Pi 3
- OS: raspian
- Java Runtime Environment: Java SE Runtime Environment (build 1.8.0_161-b12)
- openHAB version:2.2.0
2018-07-31 21:57:25.825 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'America/Vancouver'.
2018-07-31 21:57:25.851 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '47.938559,-122.293247'.
2018-07-31 21:57:25.858 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_US'.
2018-07-31 21:57:43.371 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.7:8080
2018-07-31 21:57:43.386 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.7:8443
2018-07-31 21:58:12.234 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'hillst.rules'
2018-07-31 21:58:12.965 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'AEON.rules'
2018-07-31 21:58:13.060 [ERROR] [eclipse.smarthome.model.rule.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule.runtime
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1102) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1520) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1006) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:859) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:749) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) ~[?:?]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1361) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:894) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1248) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$1(FeaturesServiceImpl.java:1147) ~[?:?]
2018-07-31 21:58:13.294 [ERROR] [lipse.smarthome.model.script.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.script.runtime
at org.apache.felix.scr.impl.manager.ComponentContextImpl.<init>(ComponentContextImpl.java:80) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:858) ~[?:?]
