Java Runtime Environment: which java platform is used and what version
openHAB version: 2.2.0
Issue of the topic:
I did a “normal” upgrade of openhab 2.2 yesterday. After that the system was broken and i’m not able to get it starting again.
I can’t get into karaf to check the log but when i do a “systemctl status openhab2” the outcome is alway somewhat different.
[14:00:04] root@openHABianPi:/etc/apt/apt.conf.d# systemctl status openhab2
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; disabled; vendor preset: enabled)
Active: active (running) since Fri 2017-11-24 14:00:04 CET; 15s ago
Docs: http://docs.openhab.org
https://community.openhab.org
Process: 7103 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=0/SUCCESS)
Main PID: 7247 (java)
Tasks: 25 (limit: 4915)
CGroup: /system.slice/openhab2.service
└─7247 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/
Nov 24 14:00:14 openHABianPi karaf[7247]: org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.zwave [12]
Nov 24 14:00:14 openHABianPi karaf[7247]: Unresolved requirement: Import-Package: com.google.common.collect
Nov 24 14:00:14 openHABianPi karaf[7247]: at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
Nov 24 14:00:14 openHABianPi karaf[7247]: at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
Nov 24 14:00:14 openHABianPi karaf[7247]: at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1600) [?:?]
Nov 24 14:00:14 openHABianPi karaf[7247]: at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
Nov 24 14:00:14 openHABianPi karaf[7247]: at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
Nov 24 14:00:14 openHABianPi karaf[7247]: at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
Nov 24 14:00:14 openHABianPi karaf[7247]: at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
Nov 24 14:00:14 openHABianPi karaf[7247]: at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
and another one is:
[14:01:19] root@openHABianPi:/etc/apt/apt.conf.d# systemctl status openhab2
Active: active (running) since Fri 2017-11-24 14:01:01 CET; 46s ago
Process: 7427 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=0/SUCCESS)
Main PID: 7570 (java)
Tasks: 23 (limit: 4915)
└─7570 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/
Nov 24 14:01:01 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
The last one doesn’t give a error, but i’m still not able to ssh to karaf or visit the website.
The “could not resolve binding” is also different every time.
I’ve tried the following:
*apt remove openhab2 and after that reinstall > no succes
*apt install openhab2=20117… from the 16 of november > no succes
*clear cache an userdata > no succes
what else can i try?
Please post configurations (if applicable):
Items configuration related to the issue
Sitemap configuration related to the issue
Rules code related to the issue
Services configuration related to the issue
If logs where generated please post these here using code fences:
Please take a look at your /var/lib/openhab2/etc/org.openhab.addons.cfg and /ect/openhab2/services/addons.cfg, maybe there are some quotes where they shouldn’t be. (see Jetty update, Karaf 4.1.3 upgrade and full LSP support and following.)
Double checked it and everything is fine there.
Also removed the local bindings from the addon folder as that may also poduce a error (found that on the forum)
I found a log file in /var/lib/openhab2/cache.
the first file is with no files in the addon-folder.
!SESSION 2017-11-24 14:00:14.344 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_151
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=arm, WS=gtk, NL=en_US
!ENTRY org.openhab.binding.squeezebox 4 0 2017-11-24 14:00:14.346
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.squeezebox [10]
!ENTRY org.openhab.binding.dsmr 4 0 2017-11-24 14:00:14.478
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.dsmr [11]
Unresolved requirement: Import-Package: gnu.io
!ENTRY org.openhab.binding.zwave 4 0 2017-11-24 14:00:14.486
!STACK 0
!ENTRY org.eclipse.smarthome.io.transport.upnp 4 0 2017-11-24 14:00:14.521
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.transport.upnp [13]
Unresolved requirement: Import-Package: org.jupnp
The next log-file is with files in the addon folder.
!SESSION 2017-11-25 16:23:50.465 -----------------------------------------------
!ENTRY org.openhab.binding.squeezebox 4 0 2017-11-25 16:23:50.490
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.squeezebox [14]
!ENTRY org.openhab.binding.dsmr 4 0 2017-11-25 16:23:50.505
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.dsmr [15]
!ENTRY org.openhab.binding.zwave 4 0 2017-11-25 16:23:50.530
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.zwave [16]
!ENTRY org.eclipse.smarthome.io.transport.upnp 4 0 2017-11-25 16:23:50.547
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.transport.upnp [17]
also a log output from the latest apt updat (1098):
2017-11-25 20:09:03.811 [WARN ] [url.mvn.internal.AetherBasedResolver] - Error resolving artifact org.jline:jline:jar:3.5.1: [Could not find artifact org.jline:jline:jar:3.5.1 in openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.2/)]
java.io.IOException: Error resolving artifact org.jline:jline:jar:3.5.1: [Could not find artifact org.jline:jline:jar:3.5.1 in openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.2/)]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:720) [4:org.ops4j.pax.url.mvn:2.5.3]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:659) [4:org.ops4j.pax.url.mvn:2.5.3]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:600) [4:org.ops4j.pax.url.mvn:2.5.3]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:567) [4:org.ops4j.pax.url.mvn:2.5.3]
at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:47) [9:org.apache.karaf.features.core:4.1.3]
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60) [9:org.apache.karaf.features.core:4.1.3]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Suppressed: shaded.org.eclipse.aether.transfer.ArtifactNotFoundException: Could not find artifact org.jline:jline:jar:3.5.1 in openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.2/)
at shaded.org.eclipse.aether.connector.basic.ArtifactTransportListener.transferFailed(ArtifactTransportListener.java:39) [4:org.ops4j.pax.url.mvn:2.5.3]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:355) [4:org.ops4j.pax.url.mvn:2.5.3]
at shaded.org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:67) [4:org.ops4j.pax.url.mvn:2.5.3]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$DirectExecutor.execute(BasicRepositoryConnector.java:581) [4:org.ops4j.pax.url.mvn:2.5.3]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector.get(BasicRepositoryConnector.java:249) [4:org.ops4j.pax.url.mvn:2.5.3]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads(DefaultArtifactResolver.java:520) [4:org.ops4j.pax.url.mvn:2.5.3]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:421) [4:org.ops4j.pax.url.mvn:2.5.3]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:246) [4:org.ops4j.pax.url.mvn:2.5.3]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:223) [4:org.ops4j.pax.url.mvn:2.5.3]
at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:294) [4:org.ops4j.pax.url.mvn:2.5.3]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:705) [4:org.ops4j.pax.url.mvn:2.5.3]
Caused by: shaded.org.eclipse.aether.resolution.ArtifactResolutionException: Error resolving artifact org.jline:jline:jar:3.5.1
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:444) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:246) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:223) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:294) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:705) ~[?:?]
... 12 more
2017-11-25 20:09:03.866 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.karaf.features.internal.util.MultiException: Error:
Error downloading mvn:org.jline/jline/3.5.1
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:84) ~[?:?]
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72) ~[?:?]
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:375) ~[?:?]
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:372) ~[?:?]
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:187) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:291) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:287) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1248) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$1(FeaturesServiceImpl.java:1147) ~[?:?]
Suppressed: java.io.IOException: Error downloading mvn:org.jline/jline/3.5.1
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:77) [9:org.apache.karaf.features.core:4.1.3]
Caused by: java.io.IOException: Error resolving artifact org.jline:jline:jar:3.5.1: [Could not find artifact org.jline:jline:jar:3.5.1 in openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.2/)]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:720) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:659) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:600) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:567) ~[?:?]
at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:47) ~[?:?]
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60) ~[?:?]
... 7 more
... 7 more
I must say I do not have any good idea. I agree with aether that org.jline is not there but why does your installation looks there and does my installation not look there?
I hope others can help you? Maybe @Benjy knows it or knows who to mention.
While searching i found another topic that sayd to do a apt purge. Unfortunatly that also removed my backup so i just removed everything and did a upgrade from openhabian “jessie” to “stretch”.
After that i did a new installation of openhab2 (1098) and that started normal.
The only problem i now still have is that i’m not able to log in to karaf.
Is there something changed in the login procedure?
changed the password as stated in the openhab-documentation (sudo sed etc…).
but whenever i do ssh -p 8081 openhab@localhost it asks for the password but whatever i try it asks three times for a password, and than three times for password “openhab@localhost” and then fails.
It’s an completly different question i know, so if neccesary i’ll open a new topic.
