Openhab upgrade
  • Platform information:
    • Hardware: iMAC 2010 16 GBram
    • OS: os Sierra
    • Java Runtime Environment: penjdk 17.0.8 2023-07-18 LTS
      OpenJDK Runtime Environment Zulu17.44+15-CA (build 17.0.8+7-LTS)
      OpenJDK 64-Bit Server VM Zulu17.44+15-CA (build 17.0.8+7-LTS, mixed mode, sharing)
    • openHAB version: 4
  • Issue of the topic: update 4 to 4.1
openHAB 4.x update script
Making Temporary Directory
Downloading openHAB 4.1.0-SNAPSHOT…
curl: (60) SSL certificate problem: certificate has expired
More details here: https://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a “bundle”
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn’t adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you’d like to turn off curl’s verification of the certificate, use
the -k (or --insecure) option.
HTTPS-proxy has similar options --proxy-cacert and --proxy-insecure.
Download failed, version 4.1.0-SNAPSHOT does not exist.
If you believe this to be an error, please check the openHAB website. (www.openhab.org)
I do not understand how to renew thr cacert. What to do here, Please help.
Try this security - App / curl still getting certificate expired error due to expired Let’s Encrypt certificate - Ask Different (stackexchange.com)
