After installing openhab2 on a Raspberry Pi, I realise that it opens port 40545. Why? - and what is it used for?
that’s most likely a client connection to/from your system (not necessarily OH2).
lsof -i :40545
netstat -atn |grep 40545
(apt-get install lsof if needed)
Thank you !
The port number varies and it is only open, when openhab2 is started – also no web-clients connected
When openhab2 is closed (systemctl stop openhab2) the port is not open!
I am usng the following bindings:
MQTT
Astro
YahooWeather
Sendt fra Mail til Windows 10
it could be the connection to the broker
check with lsof and you will identify the processes involved in the connection.
example:
root@homer:/var/lib/openhab2# lsof -i :35295
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
mosquitto 26086 mosquitto 6u IPv4 10183621 0t0 TCP localhost:1883->localhost:35295 (ESTABLISHED)
java 26395 openhab 46u IPv6 10182498 0t0 TCP localhost:35295->localhost:1883 (ESTABLISHED)
OH (java process) has initiated (port 35295) a tcp connection to the broker (port 1883)
OH is not listening to this port but it’s using it to establish the connection to the MQTT server
the process is ‘java’
more info:
pi@raspberrypi:~ $ systemctl status openhab2
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: active (running) since ons 2017-07-26 06:26:54 CEST; 5min ago
Docs: http://docs.openhab.org
https://community.openhab.org
Process: 19375 ExecStop=/usr/share/openhab2/runtime/bin/stop (code=exited, status=0/SUCCESS)
Main PID: 22055 (karaf)
CGroup: /system.slice/openhab2.service
├─22055 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
└─22334 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtim...
pi@raspberrypi:~ $ sudo netstat --tcp --listening --programs --numeric
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:2121 0.0.0.0:* LISTEN 602/owhttpd
tcp 0 0 127.0.0.1:46511 0.0.0.0:* LISTEN 22334/java
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 22334/java
tcp 0 0 127.0.0.1:4304 0.0.0.0:* LISTEN 579/owserver
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 791/sshd
tcp 0 0 0.0.0.0:8087 0.0.0.0:* LISTEN 1005/ow2mqtt-web
tcp 0 0 0.0.0.0:8443 0.0.0.0:* LISTEN 22334/java
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 436/mosquitto
tcp 0 0 0.0.0.0:1884 0.0.0.0:* LISTEN 436/mosquitto
tcp 0 0 127.0.0.1:8101 0.0.0.0:* LISTEN 22334/java
pi@raspberrypi:~ $ sudo systemctl stop openhab2
pi@raspberrypi:~ $
And lsof:
pi@raspberrypi:~ $ lsof -v :35919
lsof version information:
revision: 4.86
latest revision: ftp://lsof.itap.purdue.edu/pub/tools/unix/lsof/
latest FAQ: ftp://lsof.itap.purdue.edu/pub/tools/unix/lsof/FAQ
latest man page: ftp://lsof.itap.purdue.edu/pub/tools/unix/lsof/lsof_man
constructed: Sat May 5 09:58:04 UTC 2012
constructed by and on: buildd@build00.raspbian.lan
compiler: cc
compiler version: 4.6.3 (Debian 4.6.3-1.1+rpi2)
compiler flags: -g -O2 -fPIE -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -D_FORTIFY_SOURCE=2 -DLINUXV=32012 -DGLIBCV=213 -DHASIPv6 -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -DHAS_STRFTIME -DLSOF_VSTR="3.2.12" -O
loader flags: -L./lib -llsof -fPIE -pie -Wl,-z,relro -Wl,-z,now
system info: Linux build00.raspbian.lan 3.2.12-mx5 #1 PREEMPT Mon Mar 26 15:04:12 PDT 2012 armv7l GNU/Linux
Anyone can list all files.
/dev warnings are disabled.
Kernel ID check is disabled.
pi@raspberrypi:~ $
lsof -i :46511 (or any other port)
got it - see above ![]()
I saw that (strange) 46511 listening port from OH… but you posted the output of the version (-v) of lsof (not the select) (-i)
pi@raspberrypi:~ $ lsof -i :35919
revision: 4.86
compiler: cc
pi@raspberrypi:~ $
the port has changed then
netstat first to identify it, then lsof to see the processes.
(no need to use -v. this will only post the version)
tcp 0 0 127.0.0.1:35919 0.0.0.0:* LISTEN 30301/java
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 30301/java
tcp 0 0 0.0.0.0:8443 0.0.0.0:* LISTEN 30301/java
tcp 0 0 127.0.0.1:8101 0.0.0.0:* LISTEN 30301/java
pi@raspberrypi:~ $
ok… this is strange…
netstat -atn |grep 35919
please ![]()
(edit: switch to root first to avoid using sudo everytime)
sudo su
then use lsof (it might be that the user pi doesn’t have the permissions to execute lsof…i don’t remember)
yes
there is also a port 8101???
By the way - I am using Zulu SDK embedded as java
that’s normal. that’s the openHAB console ssh port.
8080 = jetty http
8443 = jetty https
8101 = karaf ssh
additional bindings will open up additional listening ports (e.g. Homekit, etc, etc)
Did a few more tests:
Uninstalled all bindings - ghost still there
Uninstalled Zulu java SDK
Installed Oracle SDK - ghost still there
My conculsion - openhab2 must create the open port.
I just hate having open ports not accounted for!!
I checked trafic with wirshark - no trafic on the ghost port at all
what does netstat -atn |grep <port#> show?
root@raspberrypi:~# netstat -atn |grep 41577
tcp 0 0 127.0.0.1:41577 0.0.0.0:* LISTEN
root@raspberrypi:~#
ok… i can’t image what this could be…
it seems to be coming from the OH2 java process
but there are no connections to this listening port
it is bound to the localhost only, so no remote connections are allowed
but… something is raising this port and I can’t figure it out.
OH2 & O/S versions?
Ok Thank you for your effort
regards
Erik
------ Original Meddelelse ------
