voynut23
(Wojtek Rudko)
May 14, 2024, 7:04pm
1
Hi you all,
I am a bit in panic as I cannot connect to my openhab web interface any longer. No changes were made. The Windows server it is running on just has been offline for a while. I can acces the folder and OpenHab shows as running under Windows services. restartetd the macjine a couple times. No solution.
Is there any way I can get my configuration out of the openhab folder with all bindings, things, items, scripts and widgets?
rlkoshak
(Rich Koshak)
May 14, 2024, 7:54pm
2
What does openhab.log say?
voynut23:
There’s a backup.bat file under $OH_HOME/runtime/bin. That will back up everything you need.
Or you can just grab the conf and userdata folders.
voynut23
(Wojtek Rudko)
May 14, 2024, 8:26pm
3
The log says a lot, I guess…
STATUS | wrapper | 2024/05/14 21:20:59 | → Wrapper Started as Service
STATUS | wrapper | 2024/05/14 21:21:01 | Launching a JVM…
INFO | jvm 1 | 2024/05/14 21:21:04 | Wrapper (Version 3.2.3) http://wrapper.tanukisoftware.org
INFO | jvm 1 | 2024/05/14 21:21:04 | Copyright 1999-2006 Tanuki Software, Inc. All Rights Reserved.
INFO | jvm 1 | 2024/05/14 21:21:20 | 21:21:20.271 [Start Level: Equinox Container: e540dba5-59a0-4aa6-ad5a-acbb77d4e979] ERROR org.apache.felix.configadmin - Failure setting up dynamic configuration bindings
INFO | jvm 1 | 2024/05/14 21:21:20 | java.io.IOException: Unexpected token 78; expected: 61 (line=0, pos=177)
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.apache.felix.cm.file.ConfigurationHandler.readFailure(ConfigurationHandler.java:700) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.apache.felix.cm.file.ConfigurationHandler.readInternal(ConfigurationHandler.java:305) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.apache.felix.cm.file.ConfigurationHandler.read(ConfigurationHandler.java:268) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.apache.felix.cm.file.FilePersistenceManager._load(FilePersistenceManager.java:651) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.apache.felix.cm.file.FilePersistenceManager.load(FilePersistenceManager.java:592) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.apache.felix.cm.impl.DynamicBindings.(DynamicBindings.java:53) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.apache.felix.cm.impl.ConfigurationManager.(ConfigurationManager.java:158) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.apache.felix.cm.impl.ConfigurationAdminStarter.activate(ConfigurationAdminStarter.java:74) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.apache.felix.cm.impl.DependencyTracker.(DependencyTracker.java:92) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.apache.felix.cm.impl.Activator.start(Activator.java:114) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:818) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at java.security.AccessController.doPrivileged(AccessController.java:569) [?:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:810) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:767) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1032) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:371) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.container.Module.doStart(Module.java:605) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.container.Module.start(Module.java:468) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:20 | at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | 21:21:20.849 [Framework Event Dispatcher: Equinox Container: e540dba5-59a0-4aa6-ad5a-acbb77d4e979] ERROR Events.Framework - FrameworkEvent ERROR
INFO | jvm 1 | 2024/05/14 21:21:21 | java.util.zip.ZipException: Exception in opening zip file: V:\openhab\userdata\cache\org.eclipse.osgi\63\0.cp\lib\geronimo-osgi-locator.jar
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:356) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.storage.bundlefile.ZipBundleFile.doOpen(ZipBundleFile.java:51) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.storage.bundlefile.CloseableBundleFile.internalOpen(CloseableBundleFile.java:140) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.storage.bundlefile.CloseableBundleFile.lockOpen(CloseableBundleFile.java:78) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.storage.bundlefile.CloseableBundleFile.getEntry(CloseableBundleFile.java:274) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathEntry.loadManifest(ClasspathEntry.java:230) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathEntry.(ClasspathEntry.java:77) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.ModuleClassLoader.createClassPathEntry(ModuleClassLoader.java:267) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.createClassPathEntry(ClasspathManager.java:343) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.getClasspath(ClasspathManager.java:295) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.addStandardClassPathEntry(ClasspathManager.java:213) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.addClassPathEntry(ClasspathManager.java:205) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassPathEntry(ClasspathManager.java:188) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.buildClasspath(ClasspathManager.java:166) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.(ClasspathManager.java:94) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.EquinoxClassLoader.(EquinoxClassLoader.java:54) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.BundleLoader.createClassLoaderPrivledged(BundleLoader.java:345) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.BundleLoader.getModuleClassLoader(BundleLoader.java:262) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.EquinoxBundle$1.run(EquinoxBundle.java:653) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.EquinoxBundle$1.run(EquinoxBundle.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.security.AccessController.doPrivileged(AccessController.java:318) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.EquinoxBundle.getModuleClassLoader(EquinoxBundle.java:646) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.EquinoxBundle.getResource(EquinoxBundle.java:588) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.apache.servicemix.specs.activation.Activator.register(Activator.java:58) ~[org.apache.servicemix.specs.activation-api-1.2.1-1.2.1_3.jar:1.2.1_3]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.apache.servicemix.specs.locator.Activator.start(Activator.java:70) ~[org.apache.servicemix.specs.activation-api-1.2.1-1.2.1_3.jar:1.2.1_3]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.apache.servicemix.specs.activation.Activator.start(Activator.java:46) ~[org.apache.servicemix.specs.activation-api-1.2.1-1.2.1_3.jar:1.2.1_3]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:818) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.security.AccessController.doPrivileged(AccessController.java:569) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:810) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:767) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1032) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:371) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.container.Module.doStart(Module.java:605) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.container.Module.start(Module.java:468) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | Caused by: java.util.zip.ZipException: Invalid CEN header (invalid extra data field size for tag: 0xbfef at 55)
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.util.zip.ZipFile$Source.zerror(ZipFile.java:1762) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.util.zip.ZipFile$Source.checkExtraFields(ZipFile.java:1282) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.util.zip.ZipFile$Source.checkAndAddEntry(ZipFile.java:1229) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.util.zip.ZipFile$Source.initCEN(ZipFile.java:1701) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.util.zip.ZipFile$Source.(ZipFile.java:1479) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.util.zip.ZipFile$Source.get(ZipFile.java:1441) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.util.zip.ZipFile$CleanableResource.(ZipFile.java:718) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.util.zip.ZipFile.(ZipFile.java:252) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.util.zip.ZipFile.(ZipFile.java:181) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at java.util.zip.ZipFile.(ZipFile.java:195) ~[?:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.framework.util.SecureAction.getZipFile(SecureAction.java:342) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | … 43 more
INFO | jvm 1 | 2024/05/14 21:21:21 | 21:21:21.098 [Framework Event Dispatcher: Equinox Container: e540dba5-59a0-4aa6-ad5a-acbb77d4e979] ERROR Events.Framework - FrameworkEvent ERROR
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.storage.bundlefile.BundleFile.getResourceURL(BundleFile.java:142) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathEntry.findResource(ClasspathEntry.java:213) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalResourceImpl(ClasspathManager.java:421) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalResourceImpl(ClasspathManager.java:401) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalResource(ClasspathManager.java:372) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalResource(ModuleClassLoader.java:327) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.BundleLoader.findLocalResource(BundleLoader.java:911) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.BundleLoader.findResource(BundleLoader.java:693) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.loader.ModuleClassLoader.getResource(ModuleClassLoader.java:205) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | at org.eclipse.osgi.internal.framework.EquinoxBundle.getResource(EquinoxBundle.java:590) ~[org.eclipse.osgi-3.18.0.jar:?]
INFO | jvm 1 | 2024/05/14 21:21:21 | … 35 more
rlkoshak
(Rich Koshak)
May 14, 2024, 8:38pm
4
In the future use code fences when posting logs or code.
code goes here
Based on those errors something got corrupted in the openHAB folders. It’s hitting at least one config file that is malformed and at least one jar file it cannot open.
Take a full backup of the entire openhab folder.
Then clear the cache by deleting the contents of the userdata\cache and userdata\tmp folders (do not delete those two folders themselves, just everything in them).
Restart OH. It may take longer than normal to start up since it will need to reach out and redownload all the installed add-ons.
If that doesn’t fix it you’ll need to reinstall OH and restore from backup.
voynut23
(Wojtek Rudko)
May 14, 2024, 10:53pm
5
Unfortunately no success with cleaning the cache. Installed openhab on a different Windows Server from scratch. All working. Now, is there an easy way to get at least my widgets out of the old installation?
You can backup your openHAB config on the old system and restore it on the new system, see Tips and Tricks | openHAB .
