Since this is obviously an OS related problem, I’d search for answers there. A simple search using the message you got will return lots of help.
OpenHAB isn’t even started on your system and OpenHAB is no OS.
In this case I’d save all needed config files and use them after the reinstall!
If this situation arised because of a SD card problem, you’d have the saved data anyway.
Thanks for your help. I couldn’t even read the USB flash drive so I couldn’t get any files from there so I had to get a new drive.
I guess I ought to make backups more frequently.
I’ve got a question that you or someone else may be able to answer.
If I get a few spare USB sticks, can I just copy (in my PC) the contents of the one on my PI to the spares so if I get a corrupt drive again, I can just swap them out (rather than re-install openHAB from the backup?)
If so, would it be as simple as:
Stop openHAB service (if actually running)
Remove USB flash stick
Copy contents on PC (drag and drop) to new drive.
Re-insert drive.
Start openHAB service
Or do I have to do some more of that command line stuff?
I had the same issue after having perfectly working system and went to apply fixes/permissions i got in the same problem. i could repeat this multiple times until i figured out the problem. running stable OH3 fresh or upgraded from OH2
