Openhab Z-Wave Problem - maybe easy fix
Hey guys, I’ll Try to keep this short.
I installed openhab previously on /opt/openhab and then installed z-wave server via:
wget -q -O - http://razberry.z-wave.me/install | sudo bash
Zwave server worked great and it showed up as GREEN color in putty under /opt/openhab
I could control my devices and everything.
I then had to re install openhab in a different directory for debug purposes with mosquitto, into /opt/work
PROBLEM IS, I can’t get Z-wave to install in that directory, and work so that I can access it successfull, like before.
It keeps installing in /opt , and inside that newly created directory I can find then “green” z-way-server
I’m doing something wrong somehow from when I first set it up in my initial installation, I just can’t figure out what the problem is.
thanks for all the help, I’ve been searching and can’t find out why.
Travis
