It’s not ‘the system’ to kill the cube but the cube to hang up (it even does so for some people without OH being connected).
You should enable exclusive connection (no polling) and cease to use the MAX! interface.
And as you should move OH2 anyway, maxcube lockups seem to happen less often with the OH2 binding.
Hi
I struggled with Cube about a year, migration to OH2 improved situation only a little. The biggest improvement (actually for a couple of weeks) was turning off the Cube, and migration to Homegear as a controller and CC1101 868 MHz tranceiver as a radio interface. RF module is connected to SPI bus of Raspberry running OH, so at this moment everything works completely stable (unlike the cube).
Configuration (pairing of thermostats, linking in groups) you have to do from homegear console, and then OH2 has a binding for homegear - it automatically detects devices, exposes them as things etc.
Hi Markus, it looks like there is no enhancement to the maxsystem. Your hints are exacly what I always did. Most topics inside forums go around to remove the cube and use another RF-gateway. I’ll have to face with it. Thx. Ralf.
