Installed 2.5 on top of my 2.3 installation on my Pi 3
2.3 was manual and 2.5 was package install.
Managed to get the 2.5 up and running but only if I used open-cli start,
if I used systemctl start openhab2.service it would start the 2.3 instance and it would run fine.
I could run either version but to resolve this, and get 2.5 to start normally I deleted the older systemd openhab2.service file that was causing 2.3 to start
now when 2.5 starts, it crashes while starting.
here is the result of the systemctl status command
pi@raspberry:~ $ sudo /bin/systemctl status openhab2.service
β openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: active (running) since Fri 2019-10-25 23:46:58 EDT; 829ms ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Process: 19616 ExecStop=/usr/share/openhab2/runtime/bin/karaf stop (code=exited, status=1/FAILURE)
Main PID: 19723 (karaf)
CGroup: /system.slice/openhab2.service
ββ19723 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
ββ19805 /bin/sh /usr/share/openhab2/runtime/bin/karaf daemon
ββ19806 /usr/bin/java -version
ββ19807 awk -F " /version/ {print $2}
ββ19808 sed -e s/_.//g; s/^1.//g; s/β¦//g; s/-.*//g;
Oct 25 23:46:58 raspberry systemd[1]: Started openHAB 2 - empowering the smart home.
pi@raspberry:~ $
Any thoughts on troubleshooting this?
