Hi all,
I am new to OpenHAB and try to get my (also new) Homematic components into it. I am stuck now and don’t know where I could change anything to get it working.
What is working right now:
HMCFGUSB2 is recognized by hmland
homegear can successfully talk to hmland
using homegear I paired HMCFGUSB2 with HM-TC-IT-WM-W-EU and in the log I can see it receives messages, I can also query the values using homegear on the command line
when I open the homegear interface in the browser on port 2001 the list shows the successful connection of HM-TC-IT-WM-W-EU
OpenHAB2 beta 3 is up and running, I was able to add astro and AVM Fritz bindings as well as the Homematic binding (all three are shown on Paper UI under configuration > bindings
But Homematic binding does not communicate with homegear, no things are discovered. My FritzBox was successfully added for example, so I assume OH2 is working in general and it must be something with the Homematic binding. This is the config for the binding stored in conf/services/homematic.cfg (I removed the comments just for this posting to keep it short)
If you use OH2 than you should delete the homematic: in your configuration. I assume you have created a homematic.cfp in the services folder.
After that you should go to the paper UI and refresh the in basket. There you should find a brindge and if you add this bride as thing you can refresh the inbasket a second time. Now you schould find yoir new homematic things.
thank you for the quick reply. I removed “homematic:” from the config (the conf/services/avmfritz.cfg has a prefix “fritzbox:” for every item though…). However, is there a command to reload the config without restarting OH2? Starting OH2 takes very long (at least on my DS414).
I stopped OH2, made the change and started OH2 again. But still nothing appears in the inbox. Clicking “search for things” and then “homematic” does not find anything. It’s still the same behavior as before. Any other ideas? Maybe I need to change something in the config regarding the port?
I have done nothng special. Created the configuration with host and callback host, installed the homematic binding in papaerUI and them let the system search. First it found the bridge and then all the other items.
