OpenHab2 and Linear NGD00Z-4 Garage Door Controller
Your Channel looks odd. Confirm it in Paper UI> Configuration> Things> your opener, and verify the Chanel you have configured matches. If it does, you’ll need to enabled debug logging for the zwave binding and see why the door is not reporting.
Wait a second… your Items start with a number… I’m pretty sure you can’t do that!
Nope…
You should be seeing errors in VS Code, on OH startup, or after saving the file.
