I am trying to use Linear NGD00Z-4 Garage Door Controller with OH2. It needs the Security Classes to be included.
I am able to successfully include it in the network with OpenHab2. However, it only shows 1 channel: “BARRIER_POSITION” with type Number. There is no channel to Open/Close the Garage Door.
Yes, fundamentally you are right about the install - take a look a few posts down from the top of the thread - there are some instructions and also some comments about how to resolve the dependencies.
I reset my controller, deleted the original OH2 binding and then added the binding from above.
I then turned on Secure Mode for All Devices.
Then tried to Include the Linear NGD00Z Garage Door to the network.
Habmin reported that Secure Inclusion failed. I then tried Secure Inclusion from PaperUI and switched to Habmin to check the status. This time Habmin reported that Secure Inclusion succeeded.
As per this post (Anybody interested in BARRIER_OPERATOR Zwave Command Class?), the 2nd channel should be: BARRIER_OPERATOR zWave Command Class and it has been available in OH2 for a long time. Then why do I not see the BARRIER_OPERATOR channel ?
Issue #2:
PS: Also after using the Secure Binding, I am no longer able to control my dimmers. They show unknown even though the device exists in the database (Reference ID: 556, Manufacturer: 001d. Type: 3201:0001). I was able to get the dimmers working with the latest snapshot binding.
@Chris - Could you please update the Secure zWave Binding to include the latest Database changes ?
Not without seeing a logfile. I would suggest to delete the XML for this device, restart the binding and send me the log by creating a ticket on my website and I’ll take a look when I get a chance - probably in a few days.
@Chris how about the missing updates for the Leviton Dimmers (Reference ID: 556, Manufacturer: 001d. Type: 3201:0001). They are not recognized by the development z-Wave binding, but are recognized by the SNAPSHOT binding.
Would you be able to update the Dev binding to recognize the above Dimmers ?
The latest code resolved the Dimmers. So thanks for that.
For Garage Door Controller (NGD00Z-4), I noticed in the log file:
2017-04-07 14:22:24.053 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising cmd channel zwave:device:dfa4d57c:node33:barrier_position for DecimalType
2017-04-07 14:22:24.053 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Initialising state channel zwave:device:dfa4d57c:node33:barrier_position for DecimalType
It seems it is creating the Barrier_Position channel for both the Command Channel and State Channel. Is this a bug ?
Apart from the BARRIER_OPERATOR and BARRIER_POSITION, there should also be an ALARM channel to report Battery and Block problems with the controller. I see that in the XML but they are never instantiated.
Ticket #T9JHVYw2PKX has all of the log files and XML file.
Was this ever resolved? I saw for the zwave device database entry for the NGD00Z-4 you updated BARRIER_POSITION to BARRIER_STATE. I have mine connected securely and I’m trying to send it 255 mapped to a switch to BARRIER_STATE but nothing happens.
Is it true that BARRIER_OPERATOR and BARRIER_STATE use the same channel? I see BARRIER_OPERATOR nowhere.
I tried going into the Karaf Console but it just shows I’m not using 2.2 snapshot:
openhab-binding-zwave1 | 1.11.0.SNAPSHOT | | Uninstalled | openhab-addons-legacy-2.2.0-SNAPSHOT | Z-Wave Binding (1.x)
openhab-binding-zwave | 2.2.0.SNAPSHOT | | Uninstalled | addons-2.2.0-SNAPSHOT | Z-Wave Binding
I just looked at the XML in the binding and see BARRIER_STATE and all the other channels you are seeing. I didnt realize the device database was updated back in April. I haven’t deleted (or reinitialized) the Things for my garage openers, which would have picked up these changes!
So, I reinitialized them and am in the same state as you (I’m also on 2.2.0 snapshot). I swapped my items from barrier_operator to barrier_state and everything is behaving as before. I tried the other channels and nothing came through. Which I’m not surprised about, since the device does not use the ALARM CC (http://products.z-wavealliance.org/products/1298/classes).
The items for one of my garage doors:
Switch GarageAttached_Door "Garage Door (Attached) [MAP(garagedoor.map):%s]" <garagedoor> (gGarageAttached,gLock,gGarageDoor,gSleep_Security)
Number GarageAttached_Door_Position "Garage Door (Attached) [MAP(garagedoor.map):%s]" <garagedoor> (gGarageAttached,gGarageDoor,gSleep_Security) {channel="zwave:device:07cb40a2:node177:barrier_state"}
This rule sends a 255 or 0 to open and close the door, based on the switch state:
rule "Lock: Update garage door barrier_state after switch state change events (GarageAttached_Door)"
Item GarageAttached_Door changed
if (GarageAttached_Door.state == ON) {//closed
GarageAttached_Door_Position.sendCommand("0")
logDebug("Rules", "Lock: Update garage door barrier_state after switch state change events (GarageAttached_Door_Position) [{}]",GarageAttached_Door_Position.state)
else if (GarageAttached_Door.state == OFF) {
GarageAttached_Door_Position.sendCommand("255")
The number items change if the remote for the garage doors are used, so this rule keeps the state of the switch correct:
rule "Lock: Update garage door states after barrier_state events (GarageAttached_Door_Position)"
Item GarageAttached_Door_Position received update
if (GarageAttached_Door_Position.state == 255 && GarageAttached_Door.state == ON) {
GarageAttached_Door.postUpdate(OFF)
logDebug("Rules", "Lock: Update garage door states after barrier_state events (GarageAttached_Door) [{}]",GarageAttached_Door.state)
else if (GarageAttached_Door_Position.state == 0 && GarageAttached_Door.state == OFF) {
GarageAttached_Door.postUpdate(ON)
EDIT: Here is an updated version that uses a lambda to avoid duplication of code when more than one NGD00Z is being used.
@ashgupta, you added a number of channels that this device does not support. I’m thinking these should be removed to clean up the database, but I don’t know your reasoning for adding them and don’t want to mess anything up!
