Questions to get started:
- Are you using the test zwave binding from here?
- Has the opener been securely included? (look in Habmin> Configuration> Things> Opener> Attributes> Using Security?.. it should be a green checkmark)
- Do you get events in the log when you manually trigger the garage door? (From the log above, it looks like you do not have debugging turned on for the binding. Enter
log:set DEBUG org.openhab.binding.zwavein the Karaf console.)
