- Platform information:
- Hardware: Raspberry PI 2
- OS:
osmc (build 2018.04)
- Java Runtime Environment:
openjdk version "1.8.0_171" OpenJDK Runtime Environment (build 1.8.0_171-8u171-b11-1~deb9u1-b11) OpenJDK Client VM (build 25.171-b11, mixed mode)
- openHAB version:
2.2.0 (Build)
- Issue of the topic: Cannot start openhab (
[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0]
) - Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
2018-05-27 15:39:41.273 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
java.util.concurrent.RejectedExecutionException: Task java.util.concurrent.FutureTask@1b6d686 rejected from java.util.concurrent.ThreadPoolExecutor@7e8ccc[Terminated, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0]
at java.util.concurrent.ThreadPoolExecutor$AbortPolicy.rejectedExecution(ThreadPoolExecutor.java:2063) [?:?]
at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:830) [?:?]
at java.util.concurrent.ThreadPoolExecutor.execute(ThreadPoolExecutor.java:1379) [?:?]
at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:134) [?:?]
at java.util.concurrent.Executors$DelegatedExecutorService.submit(Executors.java:681) [?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvisionInThread(FeaturesServiceImpl.java:1146) [9:org.apache.karaf.features.core:4.1.3]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.installFeatures(FeaturesServiceImpl.java:1022) [9:org.apache.karaf.features.core:4.1.3]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.installFeatures(FeaturesServiceImpl.java:915) [9:org.apache.karaf.features.core:4.1.3]
at org.apache.karaf.features.internal.service.BootFeaturesInstaller.installBootFeatures(BootFeaturesInstaller.java:107) [9:org.apache.karaf.features.core:4.1.3]
at org.apache.karaf.features.internal.service.BootFeaturesInstaller.start(BootFeaturesInstaller.java:87) [9:org.apache.karaf.features.core:4.1.3]
at org.apache.karaf.features.internal.osgi.Activator.doStart(Activator.java:273) [9:org.apache.karaf.features.core:4.1.3]
at org.apache.karaf.util.tracker.BaseActivator.run(BaseActivator.java:242) [9:org.apache.karaf.features.core:4.1.3]
For debugging purposes I’ve created fresh configuration on sdcard:
- install the freshest osmc version from image
- install java:
sudo apt-get install oracle-java8-jdk
(sudo apt-get install -f
to fix installation) - add stable openhab2 repository, add https transport package
- install openhab2
- change config in
/etc/default/openhab2
by altering ports to 8090/8091 to avoid conflicts with kodi) - set systemctl service (enable, start)
