Hi there, I am relativly new to openHAB. I hope that someone can help me to configure Telldus LIVE
The documentation says that for Telldus LIVE, you must configure it manually, and put this into your config:
Bridge tellstick:telldus-live:2 “Tellstick ZWave” [publicKey=“XXX”, privateKey=“YYYY”, token= “ZZZZ”, tokenSecret=“UUUU”]
You need to create a THING file with that information.
Thing files live in the Conf/Things directory. The file extension is .things
So create a file called telldus.things (with the data you posted above - make sure you put your individual information for publickey, privatekey, token, and tokensecret) and place it in the directory path I just listed.
You should then be able to go into PaperUI and see your device online if you have inserted the correct information,
