Hi there!
I recently started “investigating” home automation and openHAB.
I have a Raspberry Pi3 with the Razberry addon, openHAB2 snapshot installed and just 1 ZWave switch - for begin with.
Problem is, that even if the thing linked to the switch seems properly setup (it was discovered and created automatically), I am unable to turn it on, off or read the meter value…
I have to point out that, using z-way-server or openzwave-control-panel, the switch function normally.
So the problem seems to be with openHAB2 configuration…
The switch is node 2 in the zwave network and you can see the thing screenshot below:
items:
Switch Light_Switch "Light Switch" (LightSwitch) {channel="zwave:device:73ed5f0c:node2:switch_dimmer"}
Number Light_Switch_Watts "Light switch power consumption [%.1f W]" (LightSwitch) {zwave="zwave:device:73ed5f0c:node2:meter_watts"}
in the sitemap I have:
Switch item= Light_Switch
Text item=Light_Switch_Watts
Well, as I said toggling the switch does nothing… Does not turn on the light…
Here are lines from openHAB log (I enabled DEBUG for zwave) and it seems that the message goes through the zwave network…
What should I try next?
13:21:35.511 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'Light_Switch' received command ON
13:21:35.515 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Command received zwave:device:73ed5f0c:node2:switch_dimmer --> ON
13:21:35.518 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 2: Creating new message for command SWITCH_MULTILEVEL_SET
13:21:35.521 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
13:21:35.524 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 0. Queue={}
13:21:35.525 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 02 03 26 01 63 25 21 A7
13:21:35.528 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0A 00 13 02 03 26 01 63 25 21 A7
13:21:35.546 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
13:21:35.559 [INFO ] [marthome.event.ItemStateChangedEvent] - Light_Switch changed from OFF to ON
13:21:35.561 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_73ed5f0c_serial_ack changed from 64 to 65
13:21:35.562 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_73ed5f0c_serial_sof changed from 109 to 110
13:21:35.570 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:21:35.572 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
13:21:35.573 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 21 00 00 02 C8
13:21:35.578 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
13:21:35.579 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
13:21:35.580 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: Sent Data successfully placed on stack.
13:21:35.582 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_73ed5f0c_serial_sof changed from 110 to 111
13:21:35.590 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:21:35.593 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 21 00 00 02 00 00 C6
13:21:35.595 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 21 00 00 02 00 00 C6
13:21:35.596 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=21 00 00 02
13:21:35.598 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 33, Status = Transmission complete and ACK received(0)
13:21:35.599 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Starting initialisation from DONE
13:21:35.610 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@c993fa already registered
13:21:35.612 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=2, callback=33, payload=02 03 26 01 63
13:21:35.613 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=21 00 00 02
13:21:35.614 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=33, expected=SendData, cancelled=false transaction complete!
13:21:35.615 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
13:21:35.619 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
13:21:35.621 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 2: Response processed after 70ms/3000ms.
As I said, the switch doesn’t turn on and of course no reading for the power meter…
From time to time I see some error though…
class=SendData[0x13], type=Request[0x00], priority=Get, dest=2, callback=41, payload=02 02 26 02
13:26:03.823 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=29 00 00 03
13:26:03.824 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=41, expected=ApplicationCommandHandler, cancelled=false MISMATCH
13:26:08.771 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 2: Timeout while sending message. Requeueing - 1 attempts left!
13:26:09.286 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 2: Got an error while sending data. Resending message.
13:26:09.288 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 3. Queue={}
13:26:09.291 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 2
13:26:09.295 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 02 02 26 02 25 2A CE
13:26:09.299 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 09 00 13 02 02 26 02 25 2A CE
13:26:09.310 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
13:26:09.313 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_73ed5f0c_serial_ack changed from 71 to 72
13:26:09.320 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_73ed5f0c_serial_sof changed from 123 to 124
13:26:09.340 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:26:09.342 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
13:26:09.343 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 2A 00 00 02 C3
13:26:09.345 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
13:26:09.347 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
13:26:09.347 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_73ed5f0c_serial_sof changed from 124 to 125
13:26:09.348 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: Sent Data successfully placed on stack.
13:26:09.360 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:26:09.362 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 2A 00 00 02 00 00 CD
13:26:09.364 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 2A 00 00 02 00 00 CD
13:26:09.366 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=2A 00 00 02
13:26:09.368 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 42, Status = Transmission complete and ACK received(0)
13:26:09.369 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Starting initialisation from DONE
13:26:09.370 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@c993fa already registered
13:26:09.372 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=2, callback=42, payload=02 02 26 02
13:26:09.375 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=2A 00 00 02
13:26:09.376 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=42, expected=ApplicationCommandHandler, cancelled=false MISMATCH
13:26:14.321 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 2: Timeout while sending message. Requeueing - 0 attempts left!
13:26:14.323 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 2: Got an error while sending data. Resending message.
13:26:14.324 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 3. Queue={}
13:26:14.325 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 2
13:26:14.328 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 02 02 26 02 25 2B CF
13:26:14.331 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 09 00 13 02 02 26 02 25 2B CF
13:26:14.343 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
13:26:14.352 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_73ed5f0c_serial_ack changed from 72 to 73
13:26:14.359 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_73ed5f0c_serial_sof changed from 125 to 126
13:26:14.371 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:26:14.373 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
13:26:14.378 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_73ed5f0c_serial_sof changed from 126 to 127
13:26:14.378 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
13:26:14.376 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 2B 00 00 02 C2
13:26:14.380 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
13:26:14.382 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: Sent Data successfully placed on stack.
13:26:14.401 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:26:14.405 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 2B 00 00 02 00 00 CC
13:26:14.408 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 2B 00 00 02 00 00 CC
13:26:14.411 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=2B 00 00 02
13:26:14.414 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 43, Status = Transmission complete and ACK received(0)
13:26:14.417 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Starting initialisation from DONE
13:26:14.418 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@c993fa already registered
13:26:14.422 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=2, callback=43, payload=02 02 26 02
13:26:14.426 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=2B 00 00 02
13:26:14.428 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=43, expected=ApplicationCommandHandler, cancelled=false MISMATCH
