i am new to openhab2 but quite familiar with homematic. I try to sync a HM variable to openhab, therefore i created in HM a Switch as discribed in the binding-doc, and in openhab an item to do the ‘Action=Reload_Variables’.
The Config.log looks good, but the GUI did not change status of the variable.
The modifications I have mentioned have been done after the OH2 release and are only available in the snapshots builds.
You are mentioning a “config.log” in your first post. I don’t know this log file. Or do you mean openhab.log? If the log shows that the value has changed it may also be a problem of the GUI (I know there are some discussions about update problems in the Basic UI).
In which GUI did you see the problem? Basic UI or also on the “Control” page of Paper UI?
Martin, sorry the name of the log ist events.log in /var/log/openhab2.
The Problem is in BasicUI, …not checked in PaperUI. I will try to use snapshot build, …but have to read the doc in advance.
