I have just installed openhab2 with mosquitto and the mqtt gateway on my raspi. I made a motion sensor with an arduino nano, which totally works in openhab.The item entry is:
Number PIR “Bewegungsmelder” {mqtt=">[broker:mysensors-out/10/1/1/0/16:state:default]"}
Now I wanted to create a switch, which is basically a 433MHz module sending a 24 bit string to control a 433MHz wall plug.
Item entry:
Switch SW2 “Lampe” {mqtt=">[broker:mysensors-in/11/1/1/0/16:command:on:000000000000000000000111],[broker:mysensors-in/11/1/1/0/16:command:off:000000000000000000000110]"}
Now when I add the switch to my basic ui and I toggle it, nothing happens. When I send the 24 bit via mqtt.fx to the topic mysensors-in/11/1/1/0/16 it works. But when I toggle the switch in openhab, I don’t see an entry in mqtt.fx
What did I do wrong?
