Platform information:
- Hardware: Raspberry Pi 3 with RPI-RF-MOD
- OS: OpenHABian
- Java Runtime Environment: openjdk version “1.8.0_152” OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76) OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, mixed mode, Evaluation)
- openHAB version: 2.4.0
- RaspberryMatic CCU: Version: 3.41.11.20181222
Issue of the topic:
I would like to add my Homematic things which are controlled by a RaspberryMatic on a different Pi (IP: 192.168.188.30) But I am stuck, I do not know what the problem is. Maybe you can help me?
After the first install, some of the things were detected, but not all of them. After a fresh install of the openHABian, no things are detected, just the CCU.
But as I read the last days, I think it’s better to configure the system via text files. The bridge configuration seems to be ok, as it’s reported as online. But the HM-CC-RT-DN I wanted to add is not working.
See below for the ones I created. I also tried it with HG- in front, but I do not know if I have this HomeGear in use. I just have the RPI-RF-MOD with RaspberryMatic. But this didn’t work either.
Thanks in advance for your help! I think the openHAB eco-system is exactly the one I need and I would not like to get stuck at the beginning because of a PEBKAC on my side…
- Please post configurations (if applicable):
Items configuration related to the issue
Number WZ_Heizung_ActTemp “WZ_Heizung Ist-Temperatur [%.1f °C]” (Heating_WZ,WZ,Temperatures) {channel=“homematic:HM-CC-RT-DN:ccu:OEQ2144659:4#ACTUAL_TEMPERATURE”} -
Things
Bridge homematic:bridge:ccu “CCU Homegear Bridge” @ “Wohnzimmer” [ gatewayAddress=“192.168.188.30” ]
Thing HM-CC-RT-DN OEQ2144659 “Heizstellglied” @ “Wohnzimmer”
Sitemap configuration related to the issue
NONE -
Rules code related to the issue
NONE -
Services configuration related to the issue
NONE
- If logs where generated please post these here using code fences:
Heizstellglied
Status: OFFLINE - CONFIGURATION_ERROR Device with address ‘OEQ2144659’ not found on gateway ‘ccu’
openhab> smarthome:things list
homematic:bridge:3014Fxxxxxxxxxx (Type=Bridge, Status=ONLINE, Label=eQ3-HmIP-CCU3-App - 192.168.188.30, Bridge=null)
homematic:bridge:4bxxxx (Type=Bridge, Status=ONLINE, Label=Homematic Bridge, Bridge=null)
homematic:bridge:ccu (Type=Bridge, Status=ONLINE, Label=CCU Homegear Bridge, Bridge=null)
homematic:HM-CC-RT-DN:ccu:OEQ2144659 (Type=Thing, Status=OFFLINE (CONFIGURATION_ERROR): Device with address ‘OEQ2144659’ not found on gateway ‘ccu’, Label=Heizstellglied, Bridge=homematic:bridge:ccu)
