openHab2 on pine64
Hi all
I try to install openhab2 on pine64 ( debian 8.0)
I have problem with Aoen USB Z Stick.
I can’t force wave to works.
I get Serial Error: Port /dev/ttyUSB0 does not exist. I try almost everything.
May by is it problem wit java. In log file i found
java.lang.UnsatisfiedLinkError: /opt/openhab2/userdata/tmp/libNRJavaSerial_root_0/libNRJavaSerial.so: /opt/openhab2/userdata/tmp/libNRJavaSerial_root_0/libNRJavaSerial.so: wrong ELF class: ELFCLASS32 (Possible cause: can’t load IA 32-bit .so on a ARM-bit platform)
I suspect there’s an issue with the serial port drivers not working on the 64bit machines…
Exactly, see also my post here.
Ok
Many thanks
i am also facing issue with odroid c2
anybody got solution on this…?
