Are there any examples of connecting to openHAB2 REST API using python + websockets? I’m interested in getting item state change notifications without polling item states.
I tried the python notification example (see https://github.com/appzer/openhab/wiki/Samples-REST#python) with no luck (it’s the exact same example, I just enabled tracelog, changed IP and item name):
import websocket #need to run pip install websocket-client to get this module
class WSClient():
def __init__(self):
websocket.enableTrace(True) #True for debugging
def connect(self, url):
print("connecting to %s" % url)
self.ws = websocket.WebSocketApp(url,
on_message = self.on_message,
on_error = self.on_error,
on_close = self.on_close)
self.ws.on_open = self.on_open
self.ws.run_forever()
def on_message(self, ws, message):
print("Received:")
print(message)
def on_error(self, ws, error):
print(error)
def on_close(self, ws):
print("connection closed")
def on_open(self, ws):
print("connected")
def close(self, ws):
ws.close()
if __name__ == "__main__":
try:
client = WSClient()
client.connect("ws://192.168.178.42:8080/rest/items/switch_hm_motionDetection_lowBat/state?Accept=application/json")
except (KeyboardInterrupt, SystemExit):
print("System exit Received - Exiting program")
client.close()
print(" **** Program Ended ****")
It gives me the following output:
connecting to ws://192.168.178.42:8080/rest/items/switch_hm_motionDetection_lowBat/state?Accept=application/json
--- request header ---
GET /rest/items/switch_tvOn/state?Accept=application/json HTTP/1.1
Upgrade: websocket
Connection: Upgrade
Host: 192.168.178.42:8080
Origin: http://192.168.178.42:8080
Sec-WebSocket-Key: hEBfauXHBMLur7tkyxZg8g==
Sec-WebSocket-Version: 13
--- response header ---
HTTP/1.1 200 OK
Content-Type: text/plain
Content-Length: 4
Server: Jetty(9.3.22.v20171030)
Handshake status 200
connection closed
The function on_message is never called.
Looking at the wireshark log I see the following:
State information for item switch_hm_motionDetection_lowBat (OFF) is transferred, but is not received from my websocket client.
I tried different examples using socketIO-client and now I have seen every possible error (at least it feal’s like it)…
Another attempt maybe worth mentioning:
import websocket as ws
ws.enableTrace(True)
ohsocket = ws.WebSocket()
ohsocket.settimeout(20)
ohsocket.connect("ws://192.168.178.42:8080/rest/items/", header={"X-Atmosphere-Transport":"websocket", "Accept":"application/json"})
gives me the following ouput:
GET /rest/items/ HTTP/1.1
Upgrade: websocket
Connection: Upgrade
Sec-WebSocket-Key: bIMaDJx431bYUKLNKK1h3A==
X-Atmosphere-Transport: websocket
Accept: application/json
HTTP/1.1 200 OK
Content-Type: application/json
Transfer-Encoding: chunked
Traceback (most recent call last):
File "/home/seven/dev/workspace_eclipse/openhabExt/src/main_websockets.py", line 100, in <module>
File "/usr/local/lib/python3.4/dist-packages/websocket/_core.py", line 216, in connect
self.handshake_response = handshake(self.sock, *addrs, **options)
File "/usr/local/lib/python3.4/dist-packages/websocket/_handshake.py", line 69, in handshake
status, resp = _get_resp_headers(sock)
File "/usr/local/lib/python3.4/dist-packages/websocket/_handshake.py", line 135, in _get_resp_headers
raise WebSocketBadStatusException("Handshake status %d", status)
websocket._exceptions.WebSocketBadStatusException: Handshake status 200
Do you have an idea how to use python websockets with openHAB2?
Sebastian
PS: The following website did not bring light into darkness either…
