I have been struggling with getting Philio PSP01 work in openhab2 beta 3. Documentation about the sensor is here: 3 in 1 multisensor Philio PSP01 manual (motion, Temperature, lightness) | PPT
Finally discovery found this, but it is saying that my sensor is:
PSM02 Slim Multi-Sensor
In Paper UI it’s also saying that there is a door sensor in this device, but according manufacturer guide there is no door sensor.
At some point I was getting the battery, temperature and luminescence values, but no motion detection. If I touch tamper switch then logs information. See below.
I also include the node12.xml that was created for me (after few tries)
node12.xml (9.0 KB)
So what should I do to get the motion sensor to work with PSP01?
–Ari
ps. I’m also really happy if some cloud say what motion sensor I should invest my money and time. PSP01 at least have been been a disappointment at least for time perspective.
2016-06-06 20:22:52.856 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Polling…
2016-06-06 20:22:52.858 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Polling zwave:device:94d2ecc2:node12:alarm_motion
2016-06-06 20:22:52.860 [DEBUG] [converter.ZWaveBinarySensorConverter] - NODE 12: Generating poll message for SENSOR_BINARY, endpoint 0
2016-06-06 20:22:52.862 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 12: Creating new message for application command SENSOR_BINARY_GET for MOTION
2016-06-06 20:22:52.864 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Polling zwave:device:94d2ecc2:node12:alarm_tamper
2016-06-06 20:22:52.865 [DEBUG] [converter.ZWaveBinarySensorConverter] - NODE 12: Generating poll message for SENSOR_BINARY, endpoint 0
2016-06-06 20:22:52.866 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 12: Creating new message for application command SENSOR_BINARY_GET for TAMPER
2016-06-06 20:22:52.868 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Polling zwave:device:94d2ecc2:node12:sensor_door
2016-06-06 20:22:52.870 [DEBUG] [converter.ZWaveBinarySensorConverter] - NODE 12: Generating poll message for SENSOR_BINARY, endpoint 0
2016-06-06 20:22:52.871 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 12: Creating new message for application command SENSOR_BINARY_GET for DOORWINDOW
2016-06-06 20:22:52.873 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Polling zwave:device:94d2ecc2:node12:sensor_temperature
2016-06-06 20:22:52.875 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 12: Generating poll message for SENSOR_MULTILEVEL, endpoint 0
2016-06-06 20:22:52.877 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Creating new message for command SENSOR_MULTI_LEVEL_GET
2016-06-06 20:22:52.879 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Polling zwave:device:94d2ecc2:node12:sensor_luminance
2016-06-06 20:22:52.880 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 12: Generating poll message for SENSOR_MULTILEVEL, endpoint 0
2016-06-06 20:22:52.881 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 12: Creating new message for command SENSOR_MULTI_LEVEL_GET
2016-06-06 20:22:52.883 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Polling zwave:device:94d2ecc2:node12:battery-level
2016-06-06 20:22:52.885 [DEBUG] [rnal.converter.ZWaveBatteryConverter] - NODE 12: Generating poll message for BATTERY endpoint 0
2016-06-06 20:22:52.886 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 12: Creating new message for application command BATTERY_GET
2016-06-06 20:22:52.888 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Putting message SendData in wakeup queue.
2016-06-06 20:22:52.890 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Putting message SendData in wakeup queue.
2016-06-06 20:22:52.892 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Putting message SendData in wakeup queue.
2016-06-06 20:22:52.893 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Putting message SendData in wakeup queue.
2016-06-06 20:22:52.895 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Putting message SendData in wakeup queue.
2016-06-06 20:22:52.896 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Putting message SendData in wakeup queue.
2016-06-06 20:23:16.911 [INFO ] [marthome.event.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2016-06-06T20:22:17.162+0000 to 2016-06-06T20:23:16.895+0000
2016-06-06 20:23:16.922 [INFO ] [marthome.event.ItemStateChangedEvent] - CurrentDate changed from 2016-06-06T20:22:17.162+0000 to 2016-06-06T20:23:16.895+0000
2016-06-06 20:23:17.176 [INFO ] [marthome.event.ItemStateChangedEvent] - ntp_ntp_local_dateTime changed from 2016-06-06T20:23:16.895+0000 to 2016-06-06T20:23:17.162+0000
2016-06-06 20:23:17.192 [INFO ] [marthome.event.ItemStateChangedEvent] - CurrentDate changed from 2016-06-06T20:23:16.895+0000 to 2016-06-06T20:23:17.162+0000
2016-06-06 20:23:24.529 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 0C 02 84 07 7E
2016-06-06 20:23:24.536 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_94d2ecc2_serial_sof changed from 262 to 263
2016-06-06 20:23:24.539 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-06-06 20:23:24.543 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 08 00 04 00 0C 02 84 07 7E
2016-06-06 20:23:24.549 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 08 00 04 00 0C 02 84 07 7E
2016-06-06 20:23:24.552 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 0C 02 84 07
2016-06-06 20:23:24.554 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Application Command Request (ALIVE:DONE)
2016-06-06 20:23:24.556 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Starting initialisation from DONE
2016-06-06 20:23:24.557 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1e64edf already registered
2016-06-06 20:23:24.559 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 12: Incoming command class WAKE_UP
2016-06-06 20:23:24.561 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Received Wake Up Request
2016-06-06 20:23:24.562 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Received WAKE_UP_NOTIFICATION
2016-06-06 20:23:24.563 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Is awake with 7 messages in the wake-up queue.
2016-06-06 20:23:24.565 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveWakeUpEvent
2016-06-06 20:23:24.567 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveWakeUpEvent
2016-06-06 20:23:34.665 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2016-06-06 20:23:34.668 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Message has Ack Pending: Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=12, callback=91, payload=0C 02 84 08
2016-06-06 20:23:34.668 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing ‘zwave:device:94d2ecc2:node12’ has been updated.
2016-06-06 20:23:34.668 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2016-06-06 20:23:34.674 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 0C 02 84 08 25 5B 19
2016-06-06 20:23:34.677 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 12: Sending REQUEST Message = 01 09 00 13 0C 02 84 08 25 5B 19
2016-06-06 20:23:34.688 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_94d2ecc2_serial_ack changed from 128 to 129
2016-06-06 20:23:34.691 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2016-06-06 20:23:34.695 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-06-06 20:23:34.698 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2016-06-06 20:23:34.698 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_94d2ecc2_serial_sof changed from 263 to 264
2016-06-06 20:23:34.701 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2016-06-06 20:23:34.703 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2016-06-06 20:23:34.704 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: Sent Data successfully placed on stack.
2016-06-06 20:23:34.708 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 5B 00 00 02 B2
2016-06-06 20:23:34.709 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_94d2ecc2_serial_sof changed from 264 to 265
2016-06-06 20:23:34.711 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-06-06 20:23:34.713 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 5B 00 00 02 00 00 BC
2016-06-06 20:23:34.715 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 5B 00 00 02 00 00 BC
2016-06-06 20:23:34.717 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=5B 00 00 02
2016-06-06 20:23:34.719 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 12: SendData Request. CallBack ID = 91, Status = Transmission complete and ACK received(0)
2016-06-06 20:23:34.720 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 12: Starting initialisation from DONE
2016-06-06 20:23:34.721 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@1e64edf already registered
2016-06-06 20:23:34.723 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=12, callback=91, payload=0C 02 84 08
2016-06-06 20:23:34.725 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=5B 00 00 02
2016-06-06 20:23:34.726 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=91, expected=SendData, cancelled=false transaction complete!
2016-06-06 20:23:34.728 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2016-06-06 20:23:34.729 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Went to sleep
2016-06-06 20:23:34.730 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 12: Is sleeping
2016-06-06 20:23:34.732 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2016-06-06 20:23:34.733 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 12: Response processed after 54ms/4305ms.
