Hello Stefan,
thank you for your reply.
I integrated all your points as mentioned above but I still do not get any data written into InfluxDB.
(BTW, those parameters like token etc. were given by me in the graphical UI but now I’ve put them into the …/services/influxdb.cfg also.)
However, the problem remains: No data written to the data base.
I turned the log level to DEBUG and here is what I got:
2024-04-30 07:39:51.640 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2024-04-30 07:40:23.378 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService] : BundleComponentActivator : ComponentHolder created.
2024-04-30 07:40:23.388 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService] : ConfigurableComponentHolder configuration updated for pid org.openhab.influxdb with change count 11
2024-04-30 07:40:23.391 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService] : Dependency Manager created $000interface=org.openhab.core.items.ItemRegistry, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=null, parameter=0
2024-04-30 07:40:23.393 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService] : Dependency Manager created $001interface=org.openhab.core.items.MetadataRegistry, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=null, parameter=1
2024-04-30 07:40:23.396 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService] : Component created: DS=DS14, implementation=org.openhab.persistence.influxdb.InfluxDBPersistenceService, immediate=false, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=modified configuration-pid=[org.openhab.influxdb]
2024-04-30 07:40:23.398 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService] : Component Services: scope=singleton, services=[org.openhab.core.persistence.PersistenceService, org.openhab.core.persistence.QueryablePersistenceService]
2024-04-30 07:40:23.400 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService] : Component Properties: {service.config.label=InfluxDB Persistence Service, service.config.category=persistence, service.config.description.uri=persistence:influxdb, service.config.factory=false, service.pid=org.openhab.influxdb}
2024-04-30 07:40:23.403 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService] : Querying state disabled
2024-04-30 07:40:23.406 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService] : Querying state disabled
2024-04-30 07:40:23.409 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService] : Component can not be activated since it is in state disabled
2024-04-30 07:40:23.411 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService] : Querying state disabled
2024-04-30 07:40:23.413 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Updating target filters
2024-04-30 07:40:23.415 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : No change in target property for dependency $000: currently registered: false
2024-04-30 07:40:23.417 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : No existing service listener to unregister for dependency $000
2024-04-30 07:40:23.418 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Setting target property for dependency $000 to null
2024-04-30 07:40:23.420 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : New service tracker for $000, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.items.ItemRegistry), initialReferenceFilter (objectClass=org.openhab.core.items.ItemRegistry)
2024-04-30 07:40:23.421 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : dm $000 tracker reset (closed)
2024-04-30 07:40:23.425 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.items.ItemRegistry}={service.id=183, service.bundleid=149, service.scope=bundle, component.name=org.openhab.core.internal.items.ItemRegistryImpl, component.id=21} (enter)
2024-04-30 07:40:23.427 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : dm $000 tracking 1 SingleStatic active: false trackerOpened: false optional: false
2024-04-30 07:40:23.429 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.items.ItemRegistry}={service.id=183, service.bundleid=149, service.scope=bundle, component.name=org.openhab.core.internal.items.ItemRegistryImpl, component.id=21} (exit)
2024-04-30 07:40:23.431 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : dm $000 tracker opened
2024-04-30 07:40:23.433 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : registering service listener for dependency $000
2024-04-30 07:40:23.435 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : No change in target property for dependency $001: currently registered: false
2024-04-30 07:40:23.436 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : No existing service listener to unregister for dependency $001
2024-04-30 07:40:23.438 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Setting target property for dependency $001 to null
2024-04-30 07:40:23.439 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : New service tracker for $001, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.items.MetadataRegistry), initialReferenceFilter (objectClass=org.openhab.core.items.MetadataRegistry)
2024-04-30 07:40:23.441 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : dm $001 tracker reset (closed)
2024-04-30 07:40:23.444 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : dm $001 tracking 2 SingleStatic added {org.openhab.core.items.MetadataRegistry}={service.id=182, service.bundleid=149, service.scope=bundle, component.name=org.openhab.core.internal.items.MetadataRegistryImpl, component.id=26} (enter)
2024-04-30 07:40:23.446 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : dm $001 tracking 2 SingleStatic active: false trackerOpened: false optional: false
2024-04-30 07:40:23.448 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : dm $001 tracking 2 SingleStatic added {org.openhab.core.items.MetadataRegistry}={service.id=182, service.bundleid=149, service.scope=bundle, component.name=org.openhab.core.internal.items.MetadataRegistryImpl, component.id=26} (exit)
2024-04-30 07:40:23.449 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : dm $001 tracker opened
2024-04-30 07:40:23.451 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : registering service listener for dependency $001
2024-04-30 07:40:23.452 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Changed state from disabled to unsatisfiedReference
2024-04-30 07:40:23.454 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Component enabled
2024-04-30 07:40:23.458 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : ActivateInternal
2024-04-30 07:40:23.460 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Querying state unsatisfiedReference
2024-04-30 07:40:23.462 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Querying state unsatisfiedReference
2024-04-30 07:40:23.464 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Activating component from state unsatisfiedReference
2024-04-30 07:40:23.465 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Querying state unsatisfiedReference
2024-04-30 07:40:23.467 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Querying state unsatisfiedReference
2024-04-30 07:40:23.468 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Changed state from unsatisfiedReference to satisfied
2024-04-30 07:40:23.470 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : registration change queue [registered]
2024-04-30 07:40:23.478 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Checking constructor public org.openhab.persistence.influxdb.InfluxDBPersistenceService(org.openhab.core.items.ItemRegistry,org.openhab.core.items.MetadataRegistry)
2024-04-30 07:40:23.479 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : getReferenceClass: Looking for interface class org.openhab.core.items.ItemRegistry through loader of org.openhab.persistence.influxdb.InfluxDBPersistenceService
2024-04-30 07:40:23.481 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : getParameterClass: Found class org.openhab.core.items.ItemRegistry
2024-04-30 07:40:23.482 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : getReferenceClass: Looking for interface class org.openhab.core.items.MetadataRegistry through loader of org.openhab.persistence.influxdb.InfluxDBPersistenceService
2024-04-30 07:40:23.484 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : getParameterClass: Found class org.openhab.core.items.MetadataRegistry
2024-04-30 07:40:23.486 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Found constructor with 2 arguments : public org.openhab.persistence.influxdb.InfluxDBPersistenceService(org.openhab.core.items.ItemRegistry,org.openhab.core.items.MetadataRegistry)
2024-04-30 07:40:23.487 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : This thread collected dependencies
2024-04-30 07:40:23.489 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : getService (single component manager) dependencies collected.
2024-04-30 07:40:23.490 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Querying state satisfied
2024-04-30 07:40:23.491 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Querying state satisfied
2024-04-30 07:40:23.493 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : For dependency $000, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.items.ItemRegistry}={service.id=183, service.bundleid=149, service.scope=bundle, component.name=org.openhab.core.internal.items.ItemRegistryImpl, component.id=21}] service: [null]]]
2024-04-30 07:40:23.495 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : For dependency $001, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.items.MetadataRegistry}={service.id=182, service.bundleid=149, service.scope=bundle, component.name=org.openhab.core.internal.items.MetadataRegistryImpl, component.id=26}] service: [null]]]
2024-04-30 07:40:23.503 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : getting activate: activate
2024-04-30 07:40:23.504 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Locating method activate in class org.openhab.persistence.influxdb.InfluxDBPersistenceService
2024-04-30 07:40:23.509 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Declared Method org.openhab.persistence.influxdb.InfluxDBPersistenceService.activate([interface org.osgi.service.component.ComponentContext]) not found
2024-04-30 07:40:23.511 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Found activate method: public void org.openhab.persistence.influxdb.InfluxDBPersistenceService.activate(java.util.Map)
2024-04-30 07:40:23.513 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : invoking activate: activate: parameters [org.apache.felix.scr.impl.helper.ReadOnlyDictionary]
2024-04-30 07:40:23.515 [DEBUG] [.influxdb.InfluxDBPersistenceService] - InfluxDB persistence service is being activated
2024-04-30 07:40:23.520 [DEBUG] [.influxdb.InfluxDBPersistenceService] - Loaded configuration {component.name=org.openhab.persistence.influxdb.InfluxDBPersistenceService, url=http://127.0.0.1:8086, retentionPolicy=openhab, service.config.category=persistence, token=<MyToken>, service.config.description.uri=persistence:influxdb, user=openhab, version=V2, service.config.label=InfluxDB Persistence Service, service.pid=[org.openhab.influxdb, org.openhab.influxdb], service.config.factory=false, component.id=319, password=OpenHAB2024, db=TuxNet}
2024-04-30 07:40:24.202 [DEBUG] [rnal.influx2.InfluxDB2RepositoryImpl] - Succesfully connected to InfluxDB. Instance ready=class Ready
2024-04-30 07:40:24.505 [DEBUG] [rnal.influx2.InfluxDB2RepositoryImpl] - database status is OK
2024-04-30 07:40:24.506 [DEBUG] [.influxdb.InfluxDBPersistenceService] - InfluxDB persistence service is now activated
2024-04-30 07:40:24.507 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : invoked activate: activate
2024-04-30 07:40:24.507 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Set implementation object for component
2024-04-30 07:40:24.508 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.4.2 (266)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(319)] : Changed state from satisfied to active
The InfluxDB seems to be ready because I could access the UI and upload some testfile through the UI.
In some older chat I found the hint to look in /var/log/syslog, in order to see if OH is attempting to write something to the InfluxDB.
Such an entry I would guess should appear every minute but it doesn’t.
I think OK currently is not trying to write data to the InfluxDB although the InfluxDB is connected.
Do you have other hints for me?
Support is much appreciated!!
Thank you in advance.
Wolfgang
