Issue of the topic: After power failure, the program is running but cant get any interface except the SSH including myopenhab cloud which return openHAB connection error: Connection refused
when i check the open ports, port 8080 is missing…
openhabian@openhabian:/var/log/openhab $ more openhab.log
2021-06-17 22:21:56.559 [ERROR] [rvice.jetty.internal.JettyServerImpl] - Exception while starting Jetty
java.lang.reflect.InvocationTargetException: null
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.JettyServerImpl.start(JettyServerImpl.java:160) [bundleFile
at org.ops4j.pax.web.service.jetty.internal.ServerControllerImpl$Stopped.start(ServerControllerImpl.jav
a:486) [bundleFile:?]
at org.ops4j.pax.web.service.jetty.internal.ServerControllerImpl.start(ServerControllerImpl.java:82) [b
undleFile:?]
at org.ops4j.pax.web.service.jetty.internal.ServerControllerFactoryImpl$1.start(ServerControllerFactory
Impl.java:164) [bundleFile:?]
at org.ops4j.pax.web.service.jetty.internal.ServerControllerImpl$Unconfigured.configure(ServerControlle
rImpl.java:795) [bundleFile:?]
at org.ops4j.pax.web.service.jetty.internal.ServerControllerImpl.configure(ServerControllerImpl.java:98
) [bundleFile:?]
at org.ops4j.pax.web.service.internal.Activator.updateController(Activator.java:418) [bundleFile:?]
at org.ops4j.pax.web.service.internal.Activator.lambda$scheduleUpdateFactory$1(Activator.java:344) [bun
dleFile:?]
Caused by: java.lang.ClassFormatError: Unexpected error from weaving hook.
at org.eclipse.osgi.internal.weaving.WeavingHookConfigurator.processClass(WeavingHookConfigurator.java:
73) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.processClass(ClasspathManager.java:674)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:645) ~
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:578)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java
:538) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) ~[org.
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) ~[org.eclipse.os
gi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) ~[org.eclipse
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[org.eclipse.osgi-3.
12.100.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[org.eclipse.osgi-3.
12.100.jar:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[org.eclip
at java.lang.ClassLoader.loadClass(ClassLoader.java:522) ~[?:?]
at org.eclipse.jetty.util.TypeUtil.<clinit>(TypeUtil.java:196) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.newArray(XmlConfiguration.java:1158) ~[
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.itemValue(XmlConfiguration.java:1578) ~
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.value(XmlConfiguration.java:1475) ~[?:?
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.newObj(XmlConfiguration.java:1011) ~[?:
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.itemValue(XmlConfiguration.java:1574) ~
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.access$500(XmlConfiguration.java:369) ~
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration$AttrOrElementNode.getList(XmlConfigurat
ion.java:1704) ~[?:?]
ion.java:1680) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.call(XmlConfiguration.java:894) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.configure(XmlConfiguration.java:512) ~[
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.configure(XmlConfiguration.java:400) ~[
at org.eclipse.jetty.xml.XmlConfiguration.configure(XmlConfiguration.java:340) ~[?:?]
... 17 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: Index 1852260077 out of bounds for length 4645
at org.objectweb.asm.ClassReader.readInt(ClassReader.java:3377) ~[?:?]
at org.objectweb.asm.ClassReader.getFirstAttributeOffset(ClassReader.java:3218) ~[?:?]
at org.objectweb.asm.ClassReader.accept(ClassReader.java:464) ~[?:?]
at org.objectweb.asm.ClassReader.accept(ClassReader.java:391) ~[?:?]
at org.apache.aries.spifly.dynamic.ClientWeavingHook.weave(ClientWeavingHook.java:60) ~[?:?]
at org.eclipse.osgi.internal.weaving.WovenClassImpl.call(WovenClassImpl.java:163) ~[org.eclipse.osgi-3.
12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.notifyHookPrivileged(ServiceRegistry.java:
1298) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.notifyHooksPrivileged(ServiceRegistry.java
:1278) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.weaving.WovenClassImpl.callHooks(WovenClassImpl.java:255) ~[org.eclipse.os
gi-3.12.100.jar:?]
67) ~[org.eclipse.osgi-3.12.100.jar:?]
gi-3.12.100.jar:?]
12.100.jar:?]
12.100.jar:?]
... 17 more
2021-06-17 22:21:56.653 [ERROR] [j.pax.web.service.internal.Activator] - Unable to start pax web server: Except
java.lang.RuntimeException: Exception while starting Jetty
at org.ops4j.pax.web.service.jetty.internal.JettyServerImpl.start(JettyServerImpl.java:198) ~[?:?]
a:486) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.ServerControllerImpl.start(ServerControllerImpl.java:82) ~[
Impl.java:164) ~[?:?]
rImpl.java:795) ~[?:?]
dleFile:?]
Caused by: java.lang.reflect.InvocationTargetException
at org.ops4j.pax.web.service.jetty.internal.JettyServerImpl.start(JettyServerImpl.java:160) ~[?:?]
... 12 more
gi-3.12.100.jar:?]
12.100.jar:?]
12.100.jar:?]
... 12 more
12.100.jar:?]
gi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:645) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:578) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.newArray(XmlConfiguration.java:1158) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.itemValue(XmlConfiguration.java:1578) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.value(XmlConfiguration.java:1475) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.newObj(XmlConfiguration.java:1011) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.itemValue(XmlConfiguration.java:1574) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.access$500(XmlConfiguration.java:369) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration$AttrOrElementNode.getList(XmlConfiguration.java:1704) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration$AttrOrElementNode.getList(XmlConfiguration.java:1680) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.configure(XmlConfiguration.java:512) ~[?:?]
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.configure(XmlConfiguration.java:400) ~[?:?]
... 12 more
2021-06-17 22:22:19.135 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Asia/Jerusalem'.
2021-06-17 22:22:19.154 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '32.42180751361153,35.52492499351502'.
2021-06-17 22:22:19.159 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'iw_IL'.
2021-06-17 22:22:19.162 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to 'SI'.
2021-06-17 22:23:10.772 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2021-06-17 22:23:18.065 [INFO ] [o.internal.handler.AstroThingHandler] - Scheduled Positional job astro:sun:ff44695785 every 60 seconds
2021-06-17 22:23:23.124 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2021-06-17 22:23:25.414 [WARN ] [core.thing.internal.ThingManagerImpl] - Initializing handler for thing 'systeminfo:computer:openhabian' takes more than 5000ms.
2021-06-17 22:23:27.035 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = xxxxxxx, base URL =
http://localhost:8080)
2021-06-17 22:23:31.487 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2021-06-17 22:23:36.778 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2021-06-17 22:23:36.780 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2021-06-17 22:23:40.426 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 12: Restore from config: Error. Data invalid, ignoring config.
2021-06-17 22:24:09.114 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxxxxxxxxx, base
URL = http://localhost:8080)
2021-06-17 22:24:10.206 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = XXXXXXX, base URL =
2021-06-17 22:28:26.857 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 727193 failed: Connection refused
2021-06-17 22:28:26.859 [WARN ] [io.openhabcloud.internal.CloudClient] - Request Failure: Connection refused
2021-06-17 22:28:26.861 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: Connection refused
2021-06-17 22:28:26.983 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 727197 failed: Connection refused
2021-06-17 22:28:26.988 [WARN ] [io.openhabcloud.internal.CloudClient] - Request Failure: Connection refused
2021-06-17 22:28:26.990 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: Connection refused
2021-06-17 22:32:48.873 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 728423 failed: Connection refused
2021-06-17 22:32:48.878 [WARN ] [io.openhabcloud.internal.CloudClient] - Request Failure: Connection refused
2021-06-17 22:32:48.880 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: Connection refused
2021-06-17 22:32:49.006 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 728425 failed: Connection refused
2021-06-17 22:32:49.011 [WARN ] [io.openhabcloud.internal.CloudClient] - Request Failure: Connection refused
2021-06-17 22:32:49.014 [WARN ] [io.openhabcloud.internal.CloudClient] - Response Failure: Connection refused
2021-06-17 22:39:14.166 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 12: Device discovery could not resolve to a thingType! Manufacturer data not known.
Do you have a backup that you can put on another SD card? When an RPi doesn’t work after a power failure, it’s often due to the SD card getting corrupted.
You’ll need an SD card if that’s what you were running. You can’t just swap in a USB stick.
If you don’t have a backup, then see if you can start openhabian-config and make one. Then you can copy it off of this system and restore it over a fresh build of OH. But don’t reuse the old SD card.
I would generally recommend making periodic backups of your entire system (or using the backup tools built into openHABian), and always having a spare SD card ready to swap in. That’s not much consolation now, but it’s something to think about in the future.
If you have frequent power outages, then you might want to consider adding a small UPS to shut down your RPi cleanly and avoid SD corruption. But you can also buy a bunch of SD cards for the price of a UPS.
