I would like to control my EQ3-thermo controllers with openhab by using a nanoCUL USB-device 868 MHz…
In openhab1 probably the solution would be a MAX! - Binding, but this is not supported in OpenHAB 3.
The Homatic - Binding requires an IP-address, but the nanoCUL is connected to /dev/ttyUSB0.
Are there any examples available, how to connect these components?
You can connect your Max devices via Homegear and Homematic Binding to Oh3
I,m running 40+ Max devices without any problems via 4 CUNX but it is also possible with a CUL.
If you run a Openhabian Image install Homegear via “Openhabian-Config”, additionally run
“apt install homegear-management homegear-adminui” then you can configure everything via Homegear AdminUI
otherwise follow the instructions on this Page,
Once you add Devices to Homegear, Homematic Binding will autodiscover new things.
