Platform information:
Hardware:
QNAP TVS-682
Version 4.5.4.1800
CPU: Intel(R) Core™ i3-7100 CPU @ 3.90GHz
RAM: 40 GB
Storage: 12 TB
Volume for OpenHab: 1 TB -
OS:
Linux NAS 4.14.24-qnap #1 SMP Thu Sep 23 01:25:58 CST 2021 x86_64 GNU/Linux -
Java Runtime Environment:
openjdk 11.0.10 2021-01-19 LTS
OpenJDK Runtime Environment Zulu11.45+27-CA (build 11.0.10+9-LTS)
OpenJDK 64-Bit Server VM Zulu11.45+27-CA (build 11.0.10+9-LTS, mixed mode) -
openHAB version: 3.1.0
Issue of the topic: please be detailed explaining your issue
OpenHab is listening on port 8101 but the Web-UI is not starting because of wrongpscommand inside karaf. -
If logs where generated please post these here using code fences:
[/OpenHab3] # ./OpenHab3.sh start
[/OpenHab3] # + export JAVA_HOME=/opt/OpenHab3/JDK
+ JAVA_HOME=/opt/OpenHab3/JDK
+ export JAVA=/opt/OpenHab3/JDK/bin/java
+ JAVA=/opt/OpenHab3/JDK/bin/java
+ echo Launching the openHAB runtime...
++ dirname /OpenHab3/start.sh
+ DIRNAME=/OpenHab3
+ exec /OpenHab3/runtime/bin/karaf server
ps: invalid option -- 'p'
BusyBox v1.24.1 (2021-09-23 02:31:15 CST) multi-call binary.
Usage: ps [-o COL1,COL2=HEADER] [-T]
Show list of processes
-o COL1,COL2=HEADER Select columns for display
-T Show threads
QNAP Options:
--columns N
2021-10-01 16:10:52.997 [WARN ] [org.apache.karaf.shell.ssh.Activator] - Error starting activator
java.lang.IllegalStateException: Service not tracked for class interface org.osgi.service.cm.ConfigurationAdmin
at org.apache.karaf.util.tracker.BaseActivator.getTrackedService(BaseActivator.java:369) ~[bundleFile:?]
at org.apache.karaf.util.tracker.BaseActivator.ensureStartupConfiguration(BaseActivator.java:154) ~[bundleFile:?]
at org.apache.karaf.shell.ssh.Activator.doStart(Activator.java:96) ~[bundleFile:?]
at org.apache.karaf.util.tracker.BaseActivator.run(BaseActivator.java:312) [bundleFile:?]
