So I implemented very nearly as my initial post (#1)
var Number GreenFlag = 0
rule "Startup_Initializations"
System started
GreenFlag = 0
logInfo("Startup_Initializations", ">>>>> ENTERED RULE = Startup_Initializations *****************************************************************")
logInfo("Startup_Initializations", ">>>>> OpenHAB HS5150 IS SLEEPING 30 SECONDS TO ALLOW IT TO ORGANIZE ITSELF")
Thread::sleep(30000)
logInfo("Startup_Initializations", ">>>>> OpenHAB HS5150 IS NOW AWAKE **************************************************************************")
HS_Events_Log.postUpdate("OH is Re-starting")
BreakSilence = 0
HS5150_Msg_Counter_Now = 0
Start_Time = now.toInstant.toEpochMilli
StartUp_Trigger.postUpdate(0)
OHC_MsgStamp.postUpdate(-1)
Date.postUpdate(new DateTimeType())
Rule_TimeStamp4SI = Date.state.format("%tD") + " @ " + Date.state.format("%tr")
DemoLocation.postUpdate(new PointType("37.6925300,-121.7273800"))
logInfo("Startup_Initializations", ">>>>> RUNNING RULE = Startup_Initializations at " + Rule_TimeStamp4SI + " *************************************")
AND
rule "Lets_Do_Something"
Time cron ............
Item xxx changed
if (GreenFlag == 0) return;
// more code
and all was working beautifully UNTIL OH3 started logging non-repeatable errors after I was fiddling with other rules and restarting OH3, and even restarting the Windows PC.
System started
GreenFlag = 0
Thread::sleep(30000) // this is line 355
logInfo("Startup_Initializations", ">>>>> OpenHAB HS5150 IS NOW AWAKE // this is line 356
14:25:28.182 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HS5150-1' failed: The name 'logInfo' cannot be resolved to an item or type; line 356, column 3, length 146 in HS5150
Here’s the complete log file with line 356 failure at the end:
openhab> log:tail
14:22:28.618 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'HS5150.items'
14:22:31.825 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
14:22:32.622 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'HS5150Lite.sitemap'
14:22:32.954 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'HS5150Lite.sitemap', using it anyway:
Sitemap should contain either only frames or none at all
14:22:33.034 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'HS5150.sitemap'
14:22:33.730 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'HS5150.sitemap', using it anyway:
14:22:34.402 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'HS5150.things'
14:22:39.238 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'HS5150.rules'
14:23:34.396 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'HS5150.rules', using it anyway:
The value of the local variable mailActions is not used
14:23:36.557 [INFO ] [b.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
14:23:43.853 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
14:23:47.330 [WARN ] [org.openhab.core.io.net.exec.ExecUtil] - Failed to execute commandLine '[arping, --help]'
14:23:52.536 [WARN ] [org.openhab.core.io.net.exec.ExecUtil] - Failed to execute commandLine '[arping, --help]'
14:24:00.387 [INFO ] [.io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = c86a53f2-1c89-4f8f-996c-521ad3c68bce, base URL = http://localhost:8080)
14:24:06.358 [INFO ] [hab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
14:24:30.916 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO01' changed from UNINITIALIZED to INITIALIZING
14:24:31.148 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'exec:command:ExecReStart' changed from UNINITIALIZED to INITIALIZING
14:24:31.332 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO01' changed from INITIALIZING to ONLINE
14:24:31.692 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO02' changed from UNINITIALIZED to INITIALIZING
14:24:31.956 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO02' changed from INITIALIZING to ONLINE
14:24:31.876 [INFO ] [nternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
14:24:32.028 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'exec:command:ExecReStart' changed from INITIALIZING to ONLINE
14:24:32.177 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO09' changed from UNINITIALIZED to INITIALIZING
14:24:32.249 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'exec:command:ExecShutdown' changed from UNINITIALIZED to INITIALIZING
14:24:32.257 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO09' changed from INITIALIZING to ONLINE
14:24:32.473 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO10' changed from UNINITIALIZED to INITIALIZING
14:24:32.665 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'exec:command:ExecShutdown' changed from INITIALIZING to ONLINE
14:24:32.873 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO10' changed from INITIALIZING to ONLINE
14:24:33.090 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO12' changed from UNINITIALIZED to INITIALIZING
14:24:33.330 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:topic:hsbroker:WatchManThing' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
14:24:33.698 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP20' changed from UNINITIALIZED to INITIALIZING
14:24:33.810 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO12' changed from INITIALIZING to ONLINE
14:24:33.898 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mail:smtp:GmailHP5150' changed from UNINITIALIZED to INITIALIZING
14:24:34.229 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO13' changed from UNINITIALIZED to INITIALIZING
14:24:34.557 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP20' changed from INITIALIZING to ONLINE
14:24:34.701 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mail:smtp:GmailHP5150' changed from INITIALIZING to ONLINE
14:24:35.013 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO13' changed from INITIALIZING to ONLINE
14:24:35.493 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO14' changed from UNINITIALIZED to INITIALIZING
14:24:36.013 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:hsbroker' changed from UNINITIALIZED to INITIALIZING
14:24:36.403 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO14' changed from INITIALIZING to ONLINE
14:24:36.571 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO15' changed from UNINITIALIZED to INITIALIZING
14:24:36.915 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:hsbroker' changed from INITIALIZING to OFFLINE
14:24:37.155 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO15' changed from INITIALIZING to ONLINE
14:24:37.363 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP21' changed from UNINITIALIZED to INITIALIZING
14:24:37.555 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:topic:hsbroker:WatchManThing' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
14:24:37.243 [WARN ] [.core.thing.internal.ThingManagerImpl] - Initializing handler for thing 'mqtt:broker:hsbroker' takes more than 5000ms.
14:24:37.651 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP21' changed from INITIALIZING to ONLINE
14:24:37.675 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:topic:hsbroker:WatchManThing' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE)
14:24:37.755 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP22' changed from UNINITIALIZED to INITIALIZING
14:24:37.899 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP22' changed from INITIALIZING to ONLINE
14:24:38.005 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP23' changed from UNINITIALIZED to INITIALIZING
14:24:38.101 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP23' changed from INITIALIZING to ONLINE
14:24:38.181 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP24' changed from UNINITIALIZED to INITIALIZING
14:24:38.405 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP24' changed from INITIALIZING to ONLINE
14:24:38.477 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP25' changed from UNINITIALIZED to INITIALIZING
14:24:38.693 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP25' changed from INITIALIZING to ONLINE
14:24:38.813 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP26' changed from UNINITIALIZED to INITIALIZING
14:24:38.829 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP26' changed from INITIALIZING to ONLINE
14:24:38.845 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP27' changed from UNINITIALIZED to INITIALIZING
14:24:38.877 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP27' changed from INITIALIZING to ONLINE
14:24:38.933 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP28' changed from UNINITIALIZED to INITIALIZING
14:24:39.006 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP28' changed from INITIALIZING to ONLINE
14:24:39.029 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP29' changed from UNINITIALIZED to INITIALIZING
14:24:39.155 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP29' changed from INITIALIZING to ONLINE
14:24:39.196 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP30' changed from UNINITIALIZED to INITIALIZING
14:24:39.320 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP30' changed from INITIALIZING to ONLINE
14:24:39.483 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP31' changed from UNINITIALIZED to INITIALIZING
14:24:39.643 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP31' changed from INITIALIZING to ONLINE
14:24:39.795 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP32' changed from UNINITIALIZED to INITIALIZING
14:24:39.875 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP32' changed from INITIALIZING to ONLINE
14:24:40.043 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP33' changed from UNINITIALIZED to INITIALIZING
14:24:40.091 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP33' changed from INITIALIZING to ONLINE
14:24:40.131 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP34' changed from UNINITIALIZED to INITIALIZING
14:24:40.147 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP34' changed from INITIALIZING to ONLINE
14:24:40.171 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP35' changed from UNINITIALIZED to INITIALIZING
14:24:40.184 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP35' changed from INITIALIZING to ONLINE
14:24:40.196 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP51' changed from UNINITIALIZED to INITIALIZING
14:24:40.221 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP51' changed from INITIALIZING to ONLINE
14:24:40.245 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP62' changed from UNINITIALIZED to INITIALIZING
14:24:40.405 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP62' changed from INITIALIZING to ONLINE
14:24:40.301 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '10.0.0.9' with clientid ab893704-04ce-4dd6-9ec0-7e20216aa496
14:24:40.525 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP59' changed from UNINITIALIZED to INITIALIZING
14:24:40.669 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP59' changed from INITIALIZING to ONLINE
14:24:40.725 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP60' changed from UNINITIALIZED to INITIALIZING
14:24:40.885 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP60' changed from INITIALIZING to ONLINE
14:24:40.973 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP52' changed from UNINITIALIZED to INITIALIZING
14:24:40.981 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP52' changed from INITIALIZING to ONLINE
14:24:40.989 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP63' changed from UNINITIALIZED to INITIALIZING
14:24:40.997 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP63' changed from INITIALIZING to ONLINE
14:24:41.021 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP64' changed from UNINITIALIZED to INITIALIZING
14:24:41.045 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP64' changed from INITIALIZING to ONLINE
14:24:41.053 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP65' changed from UNINITIALIZED to INITIALIZING
14:24:41.069 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP65' changed from INITIALIZING to ONLINE
14:24:41.101 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP06' changed from UNINITIALIZED to INITIALIZING
14:24:41.125 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP06' changed from INITIALIZING to ONLINE
14:24:41.141 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP08' changed from UNINITIALIZED to INITIALIZING
14:24:41.149 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP08' changed from INITIALIZING to ONLINE
14:24:41.173 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP09' changed from UNINITIALIZED to INITIALIZING
14:24:41.181 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP09' changed from INITIALIZING to ONLINE
14:24:41.221 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP98' changed from UNINITIALIZED to INITIALIZING
14:24:41.237 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP98' changed from INITIALIZING to ONLINE
14:24:41.253 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP99' changed from UNINITIALIZED to INITIALIZING
14:24:41.277 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP99' changed from INITIALIZING to ONLINE
14:24:41.317 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:hsbroker' changed from OFFLINE to ONLINE
14:24:41.365 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:topic:hsbroker:WatchManThing' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
14:24:56.843 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'IP_Robert_2G' changed from ON to OFF
14:25:28.342 [INFO ] [re.automation.internal.RuleEngineImpl] - Rule engine started.
14:25:34.872 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'IP_Peter_2G' changed from OFF to ON
I tried restarting again and got this somewhere later in the code somewhere after `OpenHAB HS5150 IS NOW AWAKE’:
14:36:47.021 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP09' changed from UNINITIALIZED to INITIALIZING
14:36:47.021 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP09' changed from INITIALIZING to ONLINE
14:36:47.037 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP98' changed from UNINITIALIZED to INITIALIZING
14:36:47.053 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP98' changed from INITIALIZING to ONLINE
14:36:47.053 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP99' changed from UNINITIALIZED to INITIALIZING
14:36:47.069 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP99' changed from INITIALIZING to ONLINE
14:36:47.320 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '10.0.0.9' with clientid 04f3f69d-8ebf-45b1-ae84-9689097e61d0
14:36:47.510 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:hsbroker' changed from OFFLINE to ONLINE
14:36:47.742 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:topic:hsbroker:WatchManThing' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
14:37:38.871 [INFO ] [.model.script.Startup_Initializations] - >>>>> OpenHAB HS5150 IS NOW AWAKE **************************************************************************
14:37:38.903 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'HS_Events_Log' changed from >>>>> Published OHOB_String: MS114 to OH is Re-starting
14:37:38.967 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HS5150-1' failed: An error occurred during the script execution: Cannot resolve proxy: HS5150.rules#/1 in HS5150
14:37:39.056 [INFO ] [re.automation.internal.RuleEngineImpl] - Rule engine started.
After rebooting the computer I get "GreenFlag cannot be resolved" even though GreenFlag is defined as a global Number variable var Number GreenFlag = 0. It looks like the initialization rule is time-lagging the other rules:
openhab> log:tail
15:04:49.699 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'HS5150.items'
15:04:52.600 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
15:04:53.384 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'HS5150Lite.sitemap'
15:04:53.676 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'HS5150Lite.sitemap', using it anyway:
15:04:53.852 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'HS5150.sitemap'
15:04:54.492 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'HS5150.sitemap', using it anyway:
15:04:55.116 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'HS5150.things'
15:04:59.235 [INFO ] [b.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
15:04:59.515 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'HS5150.rules'
15:05:50.816 [INFO ] [del.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'HS5150.rules', using it anyway:
15:05:56.490 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
15:06:05.651 [WARN ] [org.openhab.core.io.net.exec.ExecUtil] - Failed to execute commandLine '[arping, --help]'
15:06:13.359 [INFO ] [.io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = c86a53f2-1c89-4f8f-996c-521ad3c68bce, base URL = http://localhost:8080)
15:06:19.823 [INFO ] [hab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
15:06:40.940 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HS5150-1' failed: An error occurred during the script execution: Cannot resolve proxy: HS5150.rules#/1 in HS5150
15:06:41.060 [INFO ] [re.automation.internal.RuleEngineImpl] - Rule engine started.
15:06:41.327 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'exec:command:ExecReStart' changed from UNINITIALIZED to INITIALIZING
15:06:41.807 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'exec:command:ExecReStart' changed from INITIALIZING to ONLINE
15:06:41.623 [INFO ] [nternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
15:06:42.039 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'exec:command:ExecShutdown' changed from UNINITIALIZED to INITIALIZING
15:06:42.215 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'exec:command:ExecShutdown' changed from INITIALIZING to ONLINE
15:06:42.127 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HS5150-24' failed: The name 'GreenFlag' cannot be resolved to an item or type; line 3656, column 10, length 9 in HS5150
15:06:42.367 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mail:smtp:GmailHP5150' changed from UNINITIALIZED to INITIALIZING
15:06:42.834 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:hsbroker' changed from UNINITIALIZED to INITIALIZING
15:06:43.487 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mail:smtp:GmailHP5150' changed from INITIALIZING to ONLINE
15:06:43.871 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP20' changed from UNINITIALIZED to INITIALIZING
15:06:44.135 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP20' changed from INITIALIZING to ONLINE
15:06:44.383 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:hsbroker' changed from INITIALIZING to OFFLINE
15:06:44.399 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP21' changed from UNINITIALIZED to INITIALIZING
15:06:44.719 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP21' changed from INITIALIZING to ONLINE
15:06:45.143 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP22' changed from UNINITIALIZED to INITIALIZING
15:06:45.300 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP22' changed from INITIALIZING to ONLINE
15:06:45.556 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP23' changed from UNINITIALIZED to INITIALIZING
15:06:45.740 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP23' changed from INITIALIZING to ONLINE
15:06:45.900 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP24' changed from UNINITIALIZED to INITIALIZING
15:06:45.932 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP24' changed from INITIALIZING to ONLINE
15:06:46.012 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP25' changed from UNINITIALIZED to INITIALIZING
15:06:46.060 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP25' changed from INITIALIZING to ONLINE
15:06:46.116 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP26' changed from UNINITIALIZED to INITIALIZING
15:06:46.200 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP26' changed from INITIALIZING to ONLINE
15:06:46.261 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP27' changed from UNINITIALIZED to INITIALIZING
15:06:46.293 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP27' changed from INITIALIZING to ONLINE
15:06:46.357 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP28' changed from INITIALIZING to ONLINE
15:06:46.421 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP28' changed from UNINITIALIZED to INITIALIZING
15:06:46.469 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP29' changed from UNINITIALIZED to INITIALIZING
15:06:46.557 [WARN ] [.core.thing.internal.ThingManagerImpl] - Initializing handler for thing 'mqtt:broker:hsbroker' takes more than 5000ms.
15:06:46.573 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP29' changed from INITIALIZING to ONLINE
15:06:46.650 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP30' changed from UNINITIALIZED to INITIALIZING
15:06:46.746 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP30' changed from INITIALIZING to ONLINE
15:06:46.802 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP31' changed from UNINITIALIZED to INITIALIZING
15:06:46.834 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP31' changed from INITIALIZING to ONLINE
15:06:46.970 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP32' changed from INITIALIZING to ONLINE
15:06:47.018 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP32' changed from UNINITIALIZED to INITIALIZING
15:06:47.106 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP33' changed from UNINITIALIZED to INITIALIZING
15:06:47.154 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP33' changed from INITIALIZING to ONLINE
15:06:47.215 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP34' changed from UNINITIALIZED to INITIALIZING
15:06:47.303 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP34' changed from INITIALIZING to ONLINE
15:06:47.359 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP35' changed from UNINITIALIZED to INITIALIZING
15:06:47.471 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP35' changed from INITIALIZING to ONLINE
15:06:47.551 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP51' changed from UNINITIALIZED to INITIALIZING
15:06:47.591 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP51' changed from INITIALIZING to ONLINE
15:06:47.703 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP62' changed from UNINITIALIZED to INITIALIZING
15:06:47.735 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP62' changed from INITIALIZING to ONLINE
15:06:47.807 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP59' changed from UNINITIALIZED to INITIALIZING
15:06:47.909 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP59' changed from INITIALIZING to ONLINE
15:06:48.077 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:topic:hsbroker:WatchManThing' changed from UNINITIALIZED to INITIALIZING
15:06:48.101 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP60' changed from UNINITIALIZED to INITIALIZING
15:06:48.301 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:topic:hsbroker:WatchManThing' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE)
15:06:48.477 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO01' changed from UNINITIALIZED to INITIALIZING
15:06:48.511 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO01' changed from INITIALIZING to ONLINE
15:06:48.623 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO02' changed from UNINITIALIZED to INITIALIZING
15:06:48.671 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO02' changed from INITIALIZING to ONLINE
15:06:48.831 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO09' changed from UNINITIALIZED to INITIALIZING
15:06:48.855 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO09' changed from INITIALIZING to ONLINE
15:06:49.086 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO10' changed from UNINITIALIZED to INITIALIZING
15:06:49.328 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:socket:WEMO10' changed from INITIALIZING to ONLINE
15:06:49.728 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO12' changed from UNINITIALIZED to INITIALIZING
15:06:50.016 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO12' changed from INITIALIZING to ONLINE
15:06:50.008 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '10.0.0.9' with clientid cd6dc66c-af70-4b51-9490-4bdaa43fbc1d
15:06:50.480 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO13' changed from UNINITIALIZED to INITIALIZING
15:06:51.370 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO13' changed from INITIALIZING to ONLINE
15:06:51.402 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO14' changed from INITIALIZING to ONLINE
15:06:51.498 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO14' changed from UNINITIALIZED to INITIALIZING
15:06:51.510 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO15' changed from UNINITIALIZED to INITIALIZING
15:06:51.558 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'wemo:lightswitch:WEMO15' changed from INITIALIZING to ONLINE
15:06:51.566 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP60' changed from INITIALIZING to ONLINE
15:06:51.606 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP52' changed from INITIALIZING to ONLINE
15:06:51.710 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP63' changed from INITIALIZING to ONLINE
15:06:51.718 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP52' changed from UNINITIALIZED to INITIALIZING
15:06:51.734 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP63' changed from UNINITIALIZED to INITIALIZING
15:06:51.750 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP64' changed from UNINITIALIZED to INITIALIZING
15:06:51.822 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP64' changed from INITIALIZING to ONLINE
15:06:51.843 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP65' changed from UNINITIALIZED to INITIALIZING
15:06:51.897 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP65' changed from INITIALIZING to ONLINE
15:06:52.052 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP06' changed from UNINITIALIZED to INITIALIZING
15:06:52.132 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP06' changed from INITIALIZING to ONLINE
15:06:52.188 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP08' changed from UNINITIALIZED to INITIALIZING
15:06:52.222 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP08' changed from INITIALIZING to ONLINE
15:06:52.222 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP09' changed from UNINITIALIZED to INITIALIZING
15:06:52.222 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP09' changed from INITIALIZING to ONLINE
15:06:52.253 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP98' changed from UNINITIALIZED to INITIALIZING
15:06:52.253 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP98' changed from INITIALIZING to ONLINE
15:06:52.317 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP99' changed from UNINITIALIZED to INITIALIZING
15:06:52.338 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'network:pingdevice:IP99' changed from INITIALIZING to ONLINE
15:06:52.418 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:hsbroker' changed from OFFLINE to ONLINE
15:06:52.474 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:topic:hsbroker:WatchManThing' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
15:07:06.824 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'IP_Robert_2G' changed from ON to OFF
15:07:08.326 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'IP_Peter_2G' changed from ON to OFF
15:07:08.454 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'IP_Janet_5G' changed from ON to OFF
15:07:17.536 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HS5150-3' failed: The name 'GreenFlag' cannot be resolved to an item or type; line 923, column 10, length 9 in HS5150
15:07:17.560 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HS5150-24' failed: The name 'GreenFlag' cannot be resolved to an item or type; line 3656, column 10, length 9 in HS5150
15:07:17.560 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HS5150-7' failed: The name 'GreenFlag' cannot be resolved to an item or type; line 2515, column 10, length 9 in HS5150
15:07:18.048 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HS5150-7' failed: The name 'GreenFlag' cannot be resolved to an item or type; line 2515, column 10, length 9 in HS5150
15:07:17.856 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HS5150-24' failed: The name 'GreenFlag' cannot be resolved to an item or type; line 3656, column 10, length 9 in HS5150
15:07:18.200 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HS5150-7' failed: The name 'GreenFlag' cannot be resolved to an item or type; line 2515, column 10, length 9 in HS5150
15:07:54.837 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'IP_WatchMan' changed from ON to OFF
Do you have any ideas what in the world is happening or what I’m doing wrong?
