Hi all, i’m running a fresh install of Openhabian on my Raspberry Pi 2.
I downloaded the Rpi image, then upgraded to the latest snapshot using the openhabian-config tool.
I have a Digi XStick XU-Z11. I have flashed the stick with coordinator API Firmware using XCTU Software from Digi. But I’m not able to add the stick to the “Things” using the zigbee binding in openhab.
The status is unknown. But i know openhab can talk to the stick, because i can see it in the log (TX RX)
I also know that the current config of the stick is OK, because i made a test with the Mozilla IoT Gateway, and the stick is detected on first boot, and i can add my zigbee light switchs.
I also try the following:
Added the lsusb physical address of the stick to the /sys/bus/usb-serial/drivers/ftdi_sio/new_id
Added the java EXTRA_OPTS in /etc/default/openhab2
Make sure that openhabian user is in the tty, dialout groups
Give the OS the ability to use the serial port using openhabian-config tool (/boot/cmdline.txt and config.txt)
Here is the events.log and openhab.log, with the debug option.
[10:20:17] openhabian@rpi2:/var/log/openhab2$ cat events.log
2019-03-04 10:05:25.244 [hingStatusInfoChangedEvent] - 'zigbee:coordinator_xbee:f13b8c2a' changed from UNINITIALIZED to INITIALIZING
2019-03-04 10:05:25.441 [hingStatusInfoChangedEvent] - 'zigbee:coordinator_xbee:f13b8c2a' changed from INITIALIZING to UNKNOWN
2019-03-04 10:05:32.751 [me.event.ThingUpdatedEvent] - Thing 'zigbee:coordinator_xbee:f13b8c2a' has been updated.
[10:22:20] openhabian@rpi2:/var/log/openhab2$ cat openhab.log
2019-03-04 10:04:56.087 [DEBUG] [org.openhab.binding.zigbee ] - BundleEvent [unknown:512] - org.openhab.binding.zigbee
2019-03-04 10:04:56.161 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=125, service.bundleid=214, service.scope=bundle, component.name=org.openhab.binding.zigbee.discovery.ZigBeeDiscoveryService, component.id=10} - org.openhab.binding.zigbee
2019-03-04 10:04:56.174 [DEBUG] [org.openhab.binding.zigbee ] - BundleEvent STARTING - org.openhab.binding.zigbee
2019-03-04 10:04:56.180 [DEBUG] [org.openhab.binding.zigbee ] - BundleEvent STARTED - org.openhab.binding.zigbee
2019-03-04 10:04:56.211 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBeeDiscoveryService
2019-03-04 10:04:56.283 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.openhab.binding.zigbee.converter.ZigBeeChannelConverterProvider}={service.id=126, service.bundleid=214, service.scope=bundle, component.name=org.openhab.binding.zigbee.internal.converter.ZigBeeDefaultChannelConverterProvider, component.id=11} - org.openhab.binding.zigbee
2019-03-04 10:04:56.836 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.openhab.binding.zigbee.converter.ZigBeeChannelConverterFactory}={service.id=127, service.bundleid=214, service.scope=bundle, component.name=org.openhab.binding.zigbee.internal.converter.ZigBeeChannelConverterFactoryImpl, component.id=12} - org.openhab.binding.zigbee
2019-03-04 10:04:56.892 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.openhab.binding.zigbee.discovery.ZigBeeDiscoveryParticipant}={service.id=128, service.bundleid=214, service.scope=bundle, component.name=org.openhab.binding.zigbee.discovery.internal.ZigBeeDefaultDiscoveryParticipant, component.id=13} - org.openhab.binding.zigbee
2019-03-04 10:04:56.902 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.type.DynamicCommandDescriptionProvider}={service.id=129, service.bundleid=214, service.scope=bundle, component.name=org.openhab.binding.zigbee.internal.converter.warningdevice.DynamicWarningCommandDescriptionProvider, component.id=14} - org.openhab.binding.zigbee
2019-03-04 10:04:56.921 [DEBUG] [org.openhab.binding.zigbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=130, service.bundleid=214, service.scope=bundle, component.name=org.openhab.binding.zigbee.internal.ZigBeeHandlerFactory, component.id=15} - org.openhab.binding.zigbee
2019-03-04 10:04:56.957 [DEBUG] [org.openhab.binding.zigbee.cc2531 ] - BundleEvent [unknown:512] - org.openhab.binding.zigbee.cc2531
2019-03-04 10:04:56.973 [DEBUG] [org.openhab.binding.zigbee.cc2531 ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=131, service.bundleid=215, service.scope=bundle, component.name=org.openhab.binding.zigbee.cc2531.internal.CC2531HandlerFactory, component.id=16} - org.openhab.binding.zigbee.cc2531
2019-03-04 10:04:56.981 [DEBUG] [org.openhab.binding.zigbee.cc2531 ] - BundleEvent STARTING - org.openhab.binding.zigbee.cc2531
2019-03-04 10:04:56.987 [DEBUG] [org.openhab.binding.zigbee.cc2531 ] - BundleEvent STARTED - org.openhab.binding.zigbee.cc2531
2019-03-04 10:04:57.004 [DEBUG] [org.openhab.binding.zigbee.ember ] - BundleEvent [unknown:512] - org.openhab.binding.zigbee.ember
2019-03-04 10:04:57.024 [DEBUG] [org.openhab.binding.zigbee.ember ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=132, service.bundleid=216, service.scope=bundle, component.name=org.openhab.binding.zigbee.ember.internal.EmberHandlerFactory, component.id=17} - org.openhab.binding.zigbee.ember
2019-03-04 10:04:57.035 [DEBUG] [org.openhab.binding.zigbee.ember ] - BundleEvent STARTING - org.openhab.binding.zigbee.ember
2019-03-04 10:04:57.041 [DEBUG] [org.openhab.binding.zigbee.ember ] - BundleEvent STARTED - org.openhab.binding.zigbee.ember
2019-03-04 10:04:57.061 [DEBUG] [org.openhab.binding.zigbee.ember ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.usbserial.UsbSerialDiscoveryParticipant}={service.id=133, service.bundleid=216, service.scope=bundle, component.name=org.openhab.binding.zigbee.ember.internal.discovery.ZigBeeEmberUsbSerialDiscoveryParticipant, component.id=18} - org.openhab.binding.zigbee.ember
2019-03-04 10:04:57.065 [DEBUG] [org.openhab.binding.zigbee.telegesis] - BundleEvent [unknown:512] - org.openhab.binding.zigbee.telegesis
2019-03-04 10:04:57.083 [DEBUG] [org.openhab.binding.zigbee.telegesis] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.usbserial.UsbSerialDiscoveryParticipant}={service.id=134, service.bundleid=217, service.scope=bundle, component.name=org.openhab.binding.zigbee.telegesis.internal.discovery.ZigBeeTelegesisUsbSerialDiscoveryParticipant, component.id=19} - org.openhab.binding.zigbee.telegesis
2019-03-04 10:04:57.090 [DEBUG] [org.openhab.binding.zigbee.telegesis] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=135, service.bundleid=217, service.scope=bundle, component.name=org.openhab.binding.zigbee.telegesis.internal.TelegesisHandlerFactory, component.id=20} - org.openhab.binding.zigbee.telegesis
2019-03-04 10:04:57.098 [DEBUG] [org.openhab.binding.zigbee.telegesis] - BundleEvent STARTING - org.openhab.binding.zigbee.telegesis
2019-03-04 10:04:57.103 [DEBUG] [org.openhab.binding.zigbee.telegesis] - BundleEvent STARTED - org.openhab.binding.zigbee.telegesis
2019-03-04 10:04:57.119 [DEBUG] [org.openhab.binding.zigbee.xbee ] - BundleEvent [unknown:512] - org.openhab.binding.zigbee.xbee
2019-03-04 10:04:57.135 [DEBUG] [org.openhab.binding.zigbee.xbee ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=136, service.bundleid=218, service.scope=bundle, component.name=org.openhab.binding.zigbee.xbee.internal.XBeeHandlerFactory, component.id=21} - org.openhab.binding.zigbee.xbee
2019-03-04 10:04:57.145 [DEBUG] [org.openhab.binding.zigbee.xbee ] - BundleEvent STARTING - org.openhab.binding.zigbee.xbee
2019-03-04 10:04:57.150 [DEBUG] [org.openhab.binding.zigbee.xbee ] - BundleEvent STARTED - org.openhab.binding.zigbee.xbee
2019-03-04 10:05:04.755 [WARN ] [.internal.element.HttpContextElement] - Registered http context [null] did not contain a valid http context id
2019-03-04 10:05:22.487 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-03-04 10:05:24.970 [DEBUG] [org.openhab.binding.zigbee.xbee ] - ServiceEvent REGISTERED - {org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler}={service.id=328, service.bundleid=218, service.scope=singleton} - org.openhab.binding.zigbee.xbee
2019-03-04 10:05:25.212 [DEBUG] [ding.zigbee.xbee.handler.XBeeHandler] - Initializing ZigBee XBee serial bridge handler.
2019-03-04 10:05:25.216 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_xbee:f13b8c2a].
2019-03-04 10:05:25.224 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 19
2019-03-04 10:05:25.227 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 28821
2019-03-04 10:05:25.229 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID 5A3D8FBF202EA641
2019-03-04 10:05:25.250 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key F78A13EDD0B5E37C5E735312E74A68EB
2019-03-04 10:05:25.253 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key 5A6967426565416C6C69616E63653039
2019-03-04 10:05:25.256 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_initialise found, initializeNetwork=false
2019-03-04 10:05:25.258 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key String F78A13EDD0B5E37C5E735312E74A68EB
2019-03-04 10:05:25.265 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network key final array F78A13EDD0B5E37C5E735312E74A68EB
2019-03-04 10:05:25.268 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key String 5A6967426565416C6C69616E63653039
2019-03-04 10:05:25.274 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link key final array 5A6967426565416C6C69616E63653039
2019-03-04 10:05:25.392 [DEBUG] [ding.zigbee.xbee.handler.XBeeHandler] - ZigBee XBee Coordinator opening Port:'/dev/ttyUSB0' PAN:7095, EPAN:5A3D8FBF202EA641, Channel:19
2019-03-04 10:05:25.434 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2019-03-04 10:05:26.446 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2019-03-04 10:05:26.450 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2019-03-04 10:05:26.490 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://10.195.198.112:8080
2019-03-04 10:05:26.495 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://10.195.198.112:8443
2019-03-04 10:05:26.511 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2019-03-04 10:05:26.532 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Adding supported cluster 1280
2019-03-04 10:05:26.544 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - ClusterMatcher starting
2019-03-04 10:05:26.925 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - ClusterMatcher adding cluster IAS_ZONE
2019-03-04 10:05:26.933 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Adding supported cluster 25
2019-03-04 10:05:26.936 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - ClusterMatcher adding cluster OTA_UPGRADE
2019-03-04 10:05:26.949 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Loading ZigBee network state: Start.
2019-03-04 10:05:26.990 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Loading ZigBee network state: Done.
2019-03-04 10:05:26.995 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee dongle initialize.
2019-03-04 10:05:26.996 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to UNINITIALISED
2019-03-04 10:05:26.998 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 9600 baud, flow control FLOWCONTROL_OUT_NONE.
2019-03-04 10:05:27.006 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=UNINITIALISED
2019-03-04 10:05:27.193 [DEBUG] [ding.zigbee.handler.ZigBeeSerialPort] - Serial port [/dev/ttyUSB0] is initialized.
2019-03-04 10:05:27.216 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - XBeeFrameHandler clearing receive buffer.
2019-03-04 10:05:27.320 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - XBeeFrameHandler cleared receive buffer.
2019-03-04 10:05:27.332 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee dongle reset 1.
2019-03-04 10:05:27.347 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - XBeeFrameHandler thread started
2019-03-04 10:05:27.366 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeSetSoftwareResetCommand [frameId=1]
2019-03-04 10:05:27.370 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeSetSoftwareResetCommand [frameId=1]
2019-03-04 10:05:27.381 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 04 08 01 46 52 5E
2019-03-04 10:05:27.512 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 05 88 01 46 52 00 DE
2019-03-04 10:05:27.623 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeSoftwareResetResponse [frameId=1, commandStatus=OK]
2019-03-04 10:05:28.457 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-03-04 10:05:28.993 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-03-04 10:05:29.507 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-03-04 10:05:29.568 [DEBUG] [com.zsmartsystems.zigbee ] - BundleEvent STARTING - com.zsmartsystems.zigbee
2019-03-04 10:05:29.595 [DEBUG] [com.zsmartsystems.zigbee ] - BundleEvent STARTED - com.zsmartsystems.zigbee
2019-03-04 10:05:29.644 [DEBUG] [m.zsmartsystems.zigbee.dongle.cc2531] - BundleEvent STARTING - com.zsmartsystems.zigbee.dongle.cc2531
2019-03-04 10:05:29.660 [DEBUG] [m.zsmartsystems.zigbee.dongle.cc2531] - BundleEvent STARTED - com.zsmartsystems.zigbee.dongle.cc2531
2019-03-04 10:05:29.678 [DEBUG] [om.zsmartsystems.zigbee.dongle.ember] - BundleEvent STARTING - com.zsmartsystems.zigbee.dongle.ember
2019-03-04 10:05:29.702 [DEBUG] [om.zsmartsystems.zigbee.dongle.ember] - BundleEvent STARTED - com.zsmartsystems.zigbee.dongle.ember
2019-03-04 10:05:29.729 [DEBUG] [smartsystems.zigbee.dongle.telegesis] - BundleEvent STARTING - com.zsmartsystems.zigbee.dongle.telegesis
2019-03-04 10:05:29.743 [DEBUG] [smartsystems.zigbee.dongle.telegesis] - BundleEvent STARTED - com.zsmartsystems.zigbee.dongle.telegesis
2019-03-04 10:05:29.756 [DEBUG] [com.zsmartsystems.zigbee.dongle.xbee] - BundleEvent STARTING - com.zsmartsystems.zigbee.dongle.xbee
2019-03-04 10:05:29.769 [DEBUG] [com.zsmartsystems.zigbee.dongle.xbee] - BundleEvent STARTED - com.zsmartsystems.zigbee.dongle.xbee
2019-03-04 10:05:29.795 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 02 8A 01 74
2019-03-04 10:05:29.803 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeModemStatusEvent [status=WATCHDOG_TIMER_RESET]
2019-03-04 10:05:29.815 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 02 8A 06 6F
2019-03-04 10:05:29.817 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeModemStatusEvent [status=COORDINATOR_STARTED]
2019-03-04 10:05:29.817 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeSetApiEnableCommand [frameId=2, mode=2]
2019-03-04 10:05:29.820 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeSetApiEnableCommand [frameId=2, mode=2]
2019-03-04 10:05:29.830 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 05 08 02 41 50 02 62
2019-03-04 10:05:29.956 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 05 88 02 41 50 00 E4
2019-03-04 10:05:29.960 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeApiEnableResponse [frameId=2, commandStatus=OK, mode=null]
2019-03-04 10:05:29.967 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeSetApiModeCommand [frameId=3, mode=3]
2019-03-04 10:05:29.969 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeSetApiModeCommand [frameId=3, mode=3]
2019-03-04 10:05:29.975 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 05 08 03 41 4F 03 61
2019-03-04 10:05:30.099 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 05 88 03 41 4F 00 E4
2019-03-04 10:05:30.103 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeApiModeResponse [frameId=3, commandStatus=OK, mode=null]
2019-03-04 10:05:30.110 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeGetHardwareVersionCommand [frameId=4]
2019-03-04 10:05:30.113 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeGetHardwareVersionCommand [frameId=4]
2019-03-04 10:05:30.119 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 04 08 04 48 56 55
2019-03-04 10:05:30.243 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 88 04 48 56 00 19 4A 72
2019-03-04 10:05:30.247 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeHardwareVersionResponse [frameId=4, commandStatus=OK, hardwareVersion=19 4A]
2019-03-04 10:05:30.253 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeGetFirmwareVersionCommand [frameId=5]
2019-03-04 10:05:30.255 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeGetFirmwareVersionCommand [frameId=5]
2019-03-04 10:05:30.260 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 04 08 05 56 52 4A
2019-03-04 10:05:30.388 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 88 05 56 52 00 21 A7 02
2019-03-04 10:05:30.392 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeFirmwareVersionResponse [frameId=5, commandStatus=OK, firmwareVersion=21 A7]
2019-03-04 10:05:30.398 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeGetDetailedVersionCommand [frameId=6]
2019-03-04 10:05:30.400 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeGetDetailedVersionCommand [frameId=6]
2019-03-04 10:05:30.405 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 04 08 06 56 4C 4F
2019-03-04 10:05:30.531 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 05 88 06 56 4C 02 CD
2019-03-04 10:05:30.535 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeDetailedVersionResponse [frameId=6, commandStatus=INVALID_COMMAND]
2019-03-04 10:05:30.541 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeGetIeeeAddressHighCommand [frameId=7]
2019-03-04 10:05:30.543 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeGetIeeeAddressHighCommand [frameId=7]
2019-03-04 10:05:30.548 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 04 08 07 53 48 55
2019-03-04 10:05:30.677 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 09 88 07 53 48 00 00 13 A2 00 20
2019-03-04 10:05:30.681 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeIeeeAddressHighResponse [frameId=7, commandStatus=OK, ieeeAddress=00 13 A2 00]
2019-03-04 10:05:30.688 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeGetIeeeAddressLowCommand [frameId=8]
2019-03-04 10:05:30.690 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeGetIeeeAddressLowCommand [frameId=8]
2019-03-04 10:05:30.696 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 04 08 08 53 4C 50
2019-03-04 10:05:30.835 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 09 88 08 53 4C 00 41 58 72 BD 08
2019-03-04 10:05:30.839 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeIeeeAddressLowResponse [frameId=8, commandStatus=OK, ieeeAddress=41 58 72 BD]
2019-03-04 10:05:30.844 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee IeeeAddress=0013A200415872BD
2019-03-04 10:05:30.851 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeSetZigbeeStackProfileCommand [frameId=9, stackProfile=2]
2019-03-04 10:05:30.854 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeSetZigbeeStackProfileCommand [frameId=9, stackProfile=2]
2019-03-04 10:05:30.858 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 05 08 09 5A 53 02 3F
2019-03-04 10:05:30.994 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 05 88 09 5A 53 00 C1
2019-03-04 10:05:30.997 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeZigbeeStackProfileResponse [frameId=9, commandStatus=OK, stackProfile=null]
2019-03-04 10:05:31.003 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeSetEncryptionEnableCommand [frameId=10, enableEncryption=true]
2019-03-04 10:05:31.006 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeSetEncryptionEnableCommand [frameId=10, enableEncryption=true]
2019-03-04 10:05:31.011 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 05 08 0A 45 45 01 62
2019-03-04 10:05:31.138 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 05 88 0A 45 45 00 E3
2019-03-04 10:05:31.141 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeEncryptionEnableResponse [frameId=10, commandStatus=OK, enableEncryption=null]
2019-03-04 10:05:31.152 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeSetEncryptionOptionsCommand [frameId=11, encryptionOptions=[ENABLE_TRUST_CENTRE]]
2019-03-04 10:05:31.154 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeSetEncryptionOptionsCommand [frameId=11, encryptionOptions=[ENABLE_TRUST_CENTRE]]
2019-03-04 10:05:31.160 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 05 08 0B 45 4F 02 56
2019-03-04 10:05:31.282 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 05 88 0B 45 4F 00 D8
2019-03-04 10:05:31.285 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeEncryptionOptionsResponse [frameId=11, commandStatus=OK]
2019-03-04 10:05:31.291 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeSetCoordinatorEnableCommand [frameId=12, enable=true]
2019-03-04 10:05:31.293 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeSetCoordinatorEnableCommand [frameId=12, enable=true]
2019-03-04 10:05:31.298 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 05 08 0C 43 45 01 62
2019-03-04 10:05:31.425 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 05 88 0C 43 45 02 E1
2019-03-04 10:05:31.428 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeCoordinatorEnableResponse [frameId=12, commandStatus=INVALID_COMMAND]
2019-03-04 10:05:31.435 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeSetNetworkKeyCommand [frameId=13, networkKey=00000000000000000000000000000000]
2019-03-04 10:05:31.439 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeSetNetworkKeyCommand [frameId=13, networkKey=00000000000000000000000000000000]
2019-03-04 10:05:31.448 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 14 08 0D 4E 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 51
2019-03-04 10:05:31.585 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 05 88 0D 4E 4B 00 D1
2019-03-04 10:05:31.588 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeNetworkKeyResponse [frameId=13, commandStatus=OK]
2019-03-04 10:05:31.595 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeSetLinkKeyCommand [frameId=14, linkKey=5A6967426565416C6C69616E63653039]
2019-03-04 10:05:31.599 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeSetLinkKeyCommand [frameId=14, linkKey=5A6967426565416C6C69616E63653039]
2019-03-04 10:05:31.608 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 14 08 0E 4B 59 5A 69 67 42 65 65 41 6C 6C 69 61 6E 63 65 30 39 8D
2019-03-04 10:05:31.745 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 05 88 0E 4B 59 00 C5
2019-03-04 10:05:31.748 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeLinkKeyResponse [frameId=14, commandStatus=OK]
2019-03-04 10:05:31.754 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeSetSaveDataCommand [frameId=15]
2019-03-04 10:05:31.755 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeSetSaveDataCommand [frameId=15]
2019-03-04 10:05:31.759 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 04 08 0F 57 52 3F
2019-03-04 10:05:31.890 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 05 88 0F 57 52 00 BF
2019-03-04 10:05:31.894 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeSaveDataResponse [frameId=15, commandStatus=OK]
2019-03-04 10:05:31.899 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeGetPanIdCommand [frameId=16]
2019-03-04 10:05:31.901 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeGetPanIdCommand [frameId=16]
2019-03-04 10:05:31.905 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 04 08 10 4F 49 4F
2019-03-04 10:05:32.034 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 07 88 10 4F 49 00 70 95 CA
2019-03-04 10:05:32.037 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeePanIdResponse [frameId=16, commandStatus=OK, panId=28821]
2019-03-04 10:05:32.043 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeGetExtendedPanIdCommand [frameId=17]
2019-03-04 10:05:32.045 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeGetExtendedPanIdCommand [frameId=17]
2019-03-04 10:05:32.048 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 04 08 11 4F 50 47
2019-03-04 10:05:32.216 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 0D 88 11 4F 50 00 5A 3D 8F BF 20 2E A6 41 AD
2019-03-04 10:05:32.229 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeExtendedPanIdResponse [frameId=17, commandStatus=OK, extendedPanId=5A3D8FBF202EA641]
2019-03-04 10:05:32.234 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to INITIALISING
2019-03-04 10:05:32.240 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeGetOperatingChannelCommand [frameId=18]
2019-03-04 10:05:32.243 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeGetOperatingChannelCommand [frameId=18]
2019-03-04 10:05:32.242 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2019-03-04 10:05:32.248 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 04 08 12 43 48 5A
2019-03-04 10:05:32.384 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 06 88 12 43 48 00 13 C7
2019-03-04 10:05:32.388 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeOperatingChannelResponse [frameId=18, commandStatus=OK, channel=19]
2019-03-04 10:05:32.399 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_19, PanID=28821, EPanId=5A3D8FBF202EA641
2019-03-04 10:05:32.403 [DEBUG] [.zigbee.dongle.xbee.ZigBeeDongleXBee] - XBee dongle startup.
2019-03-04 10:05:32.406 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to ONLINE
2019-03-04 10:05:32.406 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE queue: 1: XBeeGetOperatingChannelCommand [frameId=19]
2019-03-04 10:05:32.408 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE: XBeeGetOperatingChannelCommand [frameId=19]
2019-03-04 10:05:32.413 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - TX XBEE Data: 00 04 08 13 43 48 59
2019-03-04 10:05:32.614 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE Data: 00 06 88 13 43 48 00 13 C6
2019-03-04 10:05:32.687 [DEBUG] [ongle.xbee.internal.XBeeFrameHandler] - RX XBEE: XBeeOperatingChannelResponse [frameId=19, commandStatus=OK, channel=19]
2019-03-04 10:05:32.693 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise done. channel=CHANNEL_19, PanId=28821 EPanId=5A3D8FBF202EA641
2019-03-04 10:05:32.760 [DEBUG] [tsystems.zigbee.ZigBeeNetworkManager] - Adding supported cluster 1280
2019-03-04 10:05:32.763 [DEBUG] [com.zsmartsystems.zigbee.ZigBeeNode ] - ClusterMatcher adding cluster IAS_ZONE
