Hello.
I cannot connect openhabian SSH via putty
openhabian2 OS was reprogramed and update was done for ~50mins
and tried to connect ssh but could not with below error signal
what can be the root cause for this?
please help
thank you
I had A similar issue, due to an error during install ( could not connect to Linux server) , the only way to find out was to hook up a Monitor to the Raspberry. Then you can read what is goining on…
Hope this helps.
a
Before you hook up a monitor, did you check this documentation, more specifically the chapter “Bind Console to All Interfaces”?
no but somehow rootcause found
it was due to using fixed IP address or not
thanks for your reply
