I am wondering if anyone has a more in-depth guide for installing and setting up the bluetooth binding on a RPi3 running openhabian?
Bluetooth is working, using sudo hcitool scan/lescan is showing all the devices in the home. But the guide in the bluetooth binding is a bit out of my depth. And I also believe the link to download bluecove from googlecode is invalid.
But I think this is a very tricky binding (I do not use it…) because as far as I understood the docs, you will have to build the driver for your GNU/Linux platform.
