- Platform information:
- Hardware: Raspi 4
- OS: Linux openhabian 6.1.21
- Java Runtime Environment: openjdk version “17.0.9” 2023-10-17
OpenJDK Runtime Environment (build 17.0.9+9-Raspbian-1deb11u1rpt1)
OpenJDK Client VM (build 17.0.9+9-Raspbian-1deb11u1rpt1, mixed mode, emulated-client)
- openHAB version: 4.1.1 - release build
- Issue of the topic:
I did perform a fresh setup to migrate to OH4. Used a new SD card with the following image:
openhabian-pi-raspios32-202402051947-git4f124c2-crc903d2975.img.xz
Nothing changed there, performed initial setup, when OH was up and running installed successfully Phoscon, Mosquitto, Samba and loaded the previous config from OH 3.3.
System runs - I’,m quite happy. There are a few things which are annoying - I probably need to setup different Topics.
Starting with th probably easiest:
When I use openhabian-config - the terminal is floated with Debug info - obviously someting from the openhabian-config script. The code below is just from one session - so starting config and immediately closing it (not choosing any command). It makes it quite hard to find success or reported problems in this mess.
Any hint?
Cheers Frank
sudo openhabian-config
[sudo] password for openhabian:
2024-02-08_17:36:43_CET [openHABian] Checking for root privileges... OK
+ export UNATTENDED SILENT DEBUGMAX INTERACTIVE
+ for shfile in "${BASEDIR:-/opt/openhabian}"/functions/*.bash
+ source /opt/openhabian/functions/auth.bash
+ source /opt/openhabian/functions/backup.bash
+ source /opt/openhabian/functions/config.bash
+ source /opt/openhabian/functions/ext-storage.bash
+ source /opt/openhabian/functions/find.bash
+ source /opt/openhabian/functions/habapp.bash
+ source /opt/openhabian/functions/helpers.bash
++ ESC='\033['
++ COL_DEF='\033[39;49;00m'
++ COL_RED='\033[31;01m'
++ COL_GREEN='\033[32;01m'
++ COL_YELLOW='\033[33;01m'
++ COL_BLUE='\033[34;01m'
++ COL_MAGENTA='\033[35;01m'
++ COL_CYAN='\033[36;01m'
++ COL_LGRAY='\033[37;01m'
++ COL_DGRAY='\033[90;01m'
++ export COL_DEF COL_RED COL_GREEN COL_YELLOW COL_BLUE COL_MAGENTA COL_CYAN COL_LGRAY COL_DGRAY
+ source /opt/openhabian/functions/influxdb+grafana.bash
+ source /opt/openhabian/functions/java-jre.bash
+ source /opt/openhabian/functions/menu.bash
+ source /opt/openhabian/functions/nodejs-apps.bash
+ source /opt/openhabian/functions/nut.bash
+ source /opt/openhabian/functions/openhab.bash
+ source /opt/openhabian/functions/openhabian.bash
+ source /opt/openhabian/functions/packages.bash
+ source /opt/openhabian/functions/system.bash
+ source /opt/openhabian/functions/vpn.bash
+ source /opt/openhabian/functions/wifi.bash
+ source /opt/openhabian/functions/zram.bash
++ pwd
+ OLDWD=/home/openhabian
+ cd /opt
+ update_openhabian_conf
+ local configFile=/etc/openhabian.conf
+ local referenceConfig=/opt/openhabian/build-image/openhabian.conf
+ cp /etc/openhabian.conf /etc/openhabian.conf.BAK
+ read -r line
+ [[ # Origin: openhabian.conf =~ ^(#)?[a-zA-Z] ]]
+ echo '# Origin: openhabian.conf'
+ read -r line
+ [[ # =~ ^(#)?[a-zA-Z] ]]
+ echo '#'
+ read -r line
+ [[ # Modify your openHABian settings =~ ^(#)?[a-zA-Z] ]]
+ echo '# Modify your openHABian settings'
+ read -r line
+ [[ # Handle with care, only touch if you need to! =~ ^(#)?[a-zA-Z] ]]
+ echo '# Handle with care, only touch if you need to!'
+ read -r line
+ [[ # This file will only be used on unattended initial install. =~ ^(#)?[a-zA-Z] ]]
+ echo '# This file will only be used on unattended initial install.'
+ read -r line
+ [[ # If you want to change anything after unattended install completed, use menu in openhabian-config. =~ ^(#)?[a-zA-Z] ]]
+ echo '# If you want to change anything after unattended install completed, use menu in openhabian-config.'
+ read -r line
+ [[ '' =~ ^(#)?[a-zA-Z] ]]
+ echo ''
+ read -r line
+ [[ # ATTENTION: to disable an option a line MUST be of the format '# option=value' =~ ^(#)?[a-zA-Z] ]]
+ echo '# ATTENTION: to disable an option a line MUST be of the format '\''# option=value'\'''
+ read -r line
+ [[ # KEEP THE SPACE IT IS IMPORTANT !! =~ ^(#)?[a-zA-Z] ]]
+ echo '# KEEP THE SPACE IT IS IMPORTANT !!'
+ read -r line
+ echo ''
+ read -r line
+ [[ # Hostname to set this one to =~ ^(#)?[a-zA-Z] ]]
+ echo '# Hostname to set this one to'
+ read -r line
+ [[ hostname=openhabian =~ ^(#)?[a-zA-Z] ]]
+ parsed=hostname=openhabian
+ [[ hostname=openhabian =~ ^#[a-zA-Z] ]]
++ echo hostname=openhabian
++ cut -d= -f1
+ param=hostname
+ [[ -v hostname ]]
+ [[ openhabian == *\ * ]]
+ read -r line
+ [[ # if it exists, the default user (with its working environment) will be renamed to this username given here ... =~ ^(#)?[a-zA-Z] ]]
+ echo '# if it exists, the default user (with its working environment) will be renamed to this username given here ...'
+ read -r line
+ [[ username=openhabian =~ ^(#)?[a-zA-Z] ]]
+ parsed=username=openhabian
+ [[ username=openhabian =~ ^#[a-zA-Z] ]]
++ echo username=openhabian
++ cut -d= -f1
+ param=username
+ [[ -v username ]]
+ read -r line
+ [[ # ... and given this password. The password will be removed from this file after completion for security reasons. =~ ^(#)?[a-zA-Z] ]]
+ echo '# ... and given this password. The password will be removed from this file after completion for security reasons.'
+ read -r line
+ [[ userpw=openhabian =~ ^(#)?[a-zA-Z] ]]
+ parsed=userpw=openhabian
+ [[ userpw=openhabian =~ ^#[a-zA-Z] ]]
++ echo userpw=openhabian
++ cut -d= -f1
+ param=userpw
+ [[ -v userpw ]]
+ read -r line
+ [[ # set this to download a SSH key and authorize the owner to login as the admin user =~ ^(#)?[a-zA-Z] ]]
+ echo '# set this to download a SSH key and authorize the owner to login as the admin user'
+ read -r line
+ [[ adminkeyurl="" =~ ^(#)?[a-zA-Z] ]]
+ parsed='adminkeyurl=""'
+ [[ adminkeyurl="" =~ ^#[a-zA-Z] ]]
++ echo 'adminkeyurl=""'
++ cut -d= -f1
+ param=adminkeyurl
+ [[ -v adminkeyurl ]]
+ echo adminkeyurl=
+ read -r line
+ echo ''
+ read -r line
+ [[ # Language and timezone. See Debian documentation for valid values. =~ ^(#)?[a-zA-Z] ]]
+ echo '# Language and timezone. See Debian documentation for valid values.'
+ read -r line
+ [[ timezone=Europe/Berlin =~ ^(#)?[a-zA-Z] ]]
+ parsed=timezone=Europe/Berlin
+ [[ timezone=Europe/Berlin =~ ^#[a-zA-Z] ]]
++ echo timezone=Europe/Berlin
++ cut -d= -f1
+ param=timezone
+ [[ -v timezone ]]
+ [[ Europe/Berlin == *\ * ]]
+ read -r line
+ [[ locales="en_US.UTF-8 de_DE.UTF-8" =~ ^(#)?[a-zA-Z] ]]
+ parsed='locales="en_US.UTF-8 de_DE.UTF-8"'
+ [[ locales="en_US.UTF-8 de_DE.UTF-8" =~ ^#[a-zA-Z] ]]
++ echo 'locales="en_US.UTF-8 de_DE.UTF-8"'
++ cut -d= -f1
+ param=locales
+ [[ -v locales ]]
+ [[ en_US.UTF-8 de_DE.UTF-8 == *\ * ]]
+ read -r line
+ [[ system_default_locale="en_US.UTF-8" =~ ^(#)?[a-zA-Z] ]]
+ parsed='system_default_locale="en_US.UTF-8"'
+ [[ system_default_locale="en_US.UTF-8" =~ ^#[a-zA-Z] ]]
++ echo 'system_default_locale="en_US.UTF-8"'
++ cut -d= -f1
+ param=system_default_locale
+ [[ -v system_default_locale ]]
+ [[ en_US.UTF-8 == *\ * ]]
+ echo system_default_locale=en_US.UTF-8
+ read -r line
+ echo ''
+ read -r line
+ [[ # WiFi settings. An ethernet connection is recommended. =~ ^(#)?[a-zA-Z] ]]
+ echo '# WiFi settings. An ethernet connection is recommended.'
+ read -r line
+ [[ # If you have a RPi3 or higher, RPi0W or a supported external WiFi dongle, the WiFi =~ ^(#)?[a-zA-Z] ]]
+ echo '# If you have a RPi3 or higher, RPi0W or a supported external WiFi dongle, the WiFi'
+ read -r line
+ [[ # interface can be setup and used for the initial installation. =~ ^(#)?[a-zA-Z] ]]
+ echo '# interface can be setup and used for the initial installation.'
+ read -r line
+ [[ # Fill in your SSID and password below, leave empty or put comment in front to =~ ^(#)?[a-zA-Z] ]]
+ echo '# Fill in your SSID and password below, leave empty or put comment in front to'
+ read -r line
+ [[ # have your WiFi remain unchanged/uninitialized. Make sure your Ethernet works. =~ ^(#)?[a-zA-Z] ]]
+ echo '# have your WiFi remain unchanged/uninitialized. Make sure your Ethernet works.'
+ read -r line
+ [[ # ATTENTION: you need to escape these special characters: $, `, ", \, (newline) =~ ^(#)?[a-zA-Z] ]]
+ echo '# ATTENTION: you need to escape these special characters: $, `, ", \, (newline)'
+ read -r line
+ [[ # 'Escaping' means to put an additional \ in front of that character =~ ^(#)?[a-zA-Z] ]]
+ echo '# '\''Escaping'\'' means to put an additional \ in front of that character'
+ read -r line
+ [[ wifi_ssid="" =~ ^(#)?[a-zA-Z] ]]
+ parsed='wifi_ssid=""'
+ [[ wifi_ssid="" =~ ^#[a-zA-Z] ]]
++ echo 'wifi_ssid=""'
++ cut -d= -f1
+ param=wifi_ssid
+ [[ -v wifi_ssid ]]
+ echo wifi_ssid=
+ read -r line
+ [[ wifi_password="" =~ ^(#)?[a-zA-Z] ]]
+ parsed='wifi_password=""'
+ [[ wifi_password="" =~ ^#[a-zA-Z] ]]
++ echo 'wifi_password=""'
++ cut -d= -f1
+ param=wifi_password
+ [[ -v wifi_password ]]
+ echo wifi_password=
+ read -r line
+ echo ''
+ read -r line
+ [[ # Wi-Fi setting. Select a two-letter country code suitable for your location =~ ^(#)?[a-zA-Z] ]]
+ echo '# Wi-Fi setting. Select a two-letter country code suitable for your location'
+ read -r line
+ [[ # E.g. US (default), DE, AU, NZ... =~ ^(#)?[a-zA-Z] ]]
+ echo '# E.g. US (default), DE, AU, NZ...'
+ read -r line
+ [[ # You may infringe on local legislature otherwise =~ ^(#)?[a-zA-Z] ]]
+ echo '# You may infringe on local legislature otherwise'
+ read -r line
+ [[ # See https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 or /usr/share/zoneinfo/zone.tab =~ ^(#)?[a-zA-Z] ]]
+ echo '# See https://en.wikipedia.org/wiki/ISO_3166-1_alpha-2 or /usr/share/zoneinfo/zone.tab'
+ read -r line
+ [[ wifi_country="" =~ ^(#)?[a-zA-Z] ]]
+ parsed='wifi_country=""'
+ [[ wifi_country="" =~ ^#[a-zA-Z] ]]
++ echo 'wifi_country=""'
++ cut -d= -f1
+ param=wifi_country
+ [[ -v wifi_country ]]
+ echo wifi_country=
+ read -r line
+ echo ''
+ read -r line
+ [[ # Eventually disable all IPv6 e.g. on installation problems =~ ^(#)?[a-zA-Z] ]]
+ echo '# Eventually disable all IPv6 e.g. on installation problems'
+ read -r line
+ [[ # values: "enable", "disable" =~ ^(#)?[a-zA-Z] ]]
+ echo '# values: "enable", "disable"'
+ read -r line
+ [[ ipv6=enable =~ ^(#)?[a-zA-Z] ]]
+ parsed=ipv6=enable
+ [[ ipv6=enable =~ ^#[a-zA-Z] ]]
++ echo ipv6=enable
++ cut -d= -f1
+ param=ipv6
+ [[ -v ipv6 ]]
+ [[ enable == *\ * ]]
+ echo ipv6=enable
+ read -r line
+ echo ''
+ read -r line
+ [[ # repo and branch to clone from =~ ^(#)?[a-zA-Z] ]]
+ echo '# repo and branch to clone from'
+ read -r line
+ [[ repositoryurl=https://github.com/openhab/openhabian.git =~ ^(#)?[a-zA-Z] ]]
+ parsed=repositoryurl=https://github.com/openhab/openhabian.git
+ [[ repositoryurl=https://github.com/openhab/openhabian.git =~ ^#[a-zA-Z] ]]
++ echo repositoryurl=https://github.com/openhab/openhabian.git
++ cut -d= -f1
+ param=repositoryurl
+ [[ -v repositoryurl ]]
+ [[ https://github.com/openhab/openhabian.git == *\ * ]]
+ read -r line
+ [[ clonebranch=openHAB =~ ^(#)?[a-zA-Z] ]]
+ parsed=clonebranch=openHAB
+ [[ clonebranch=openHAB =~ ^#[a-zA-Z] ]]
++ echo clonebranch=openHAB
++ cut -d= -f1
+ param=clonebranch
+ [[ -v clonebranch ]]
+ [[ openHAB == *\ * ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # initial openHAB configuration to import (URL or filename) =~ ^(#)?[a-zA-Z] ]]
+ echo '# initial openHAB configuration to import (URL or filename)'
+ read -r line
+ [[ # the file needs to be a zip archive created from openhab-cli backup =~ ^(#)?[a-zA-Z] ]]
+ echo '# the file needs to be a zip archive created from openhab-cli backup'
+ read -r line
+ [[ # initialconfig=/boot/initial.zip =~ ^(#)?[a-zA-Z] ]]
+ echo '# initialconfig=/boot/initial.zip'
+ read -r line
+ echo ''
+ read -r line
+ [[ # debug verbosity mode =~ ^(#)?[a-zA-Z] ]]
+ echo '# debug verbosity mode'
+ read -r line
+ [[ # off, on (verbose output in log) or maximum (show every command) =~ ^(#)?[a-zA-Z] ]]
+ echo '# off, on (verbose output in log) or maximum (show every command)'
+ read -r line
+ [[ debugmode=maximum =~ ^(#)?[a-zA-Z] ]]
+ parsed=debugmode=maximum
+ [[ debugmode=maximum =~ ^#[a-zA-Z] ]]
++ echo debugmode=maximum
++ cut -d= -f1
+ param=debugmode
+ [[ -v debugmode ]]
+ [[ maximum == *\ * ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # the framebuffer on RPi is enabled by default =~ ^(#)?[a-zA-Z] ]]
+ echo '# the framebuffer on RPi is enabled by default'
+ read -r line
+ [[ framebuffer=enable =~ ^(#)?[a-zA-Z] ]]
+ parsed=framebuffer=enable
+ [[ framebuffer=enable =~ ^#[a-zA-Z] ]]
++ echo framebuffer=enable
++ cut -d= -f1
+ param=framebuffer
+ [[ -v framebuffer ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # apt timeout to wait for lock with multiple install actions going on =~ ^(#)?[a-zA-Z] ]]
+ echo '# apt timeout to wait for lock with multiple install actions going on'
+ read -r line
+ [[ apttimeout=60 =~ ^(#)?[a-zA-Z] ]]
+ parsed=apttimeout=60
+ [[ apttimeout=60 =~ ^#[a-zA-Z] ]]
++ echo apttimeout=60
++ cut -d= -f1
+ param=apttimeout
+ [[ -v apttimeout ]]
+ [[ 60 == *\ * ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # fake hardware =~ ^(#)?[a-zA-Z] ]]
+ echo '# fake hardware'
+ read -r line
+ [[ # force treating your box as if it was a ... =~ ^(#)?[a-zA-Z] ]]
+ echo '# force treating your box as if it was a ...'
+ read -r line
+ [[ # pi5, pi4, pi4_8gb, cm4, pi400, pi3, cm3, pi3+, cm3+, pi2, pi1, cm1, pi0, pi0w, pi0w2, x86 =~ ^(#)?[a-zA-Z] ]]
+ echo '# pi5, pi4, pi4_8gb, cm4, pi400, pi3, cm3, pi3+, cm3+, pi2, pi1, cm1, pi0, pi0w, pi0w2, x86'
+ read -r line
+ [[ # hw= =~ ^(#)?[a-zA-Z] ]]
+ echo '# hw='
+ read -r line
+ echo ''
+ read -r line
+ [[ # Hardware architecture =~ ^(#)?[a-zA-Z] ]]
+ echo '# Hardware architecture'
+ read -r line
+ [[ # x86_64, amd64, armv6l, armv7l, aarch64, arm64 =~ ^(#)?[a-zA-Z] ]]
+ echo '# x86_64, amd64, armv6l, armv7l, aarch64, arm64'
+ read -r line
+ [[ # hwarch= =~ ^(#)?[a-zA-Z] ]]
+ echo '# hwarch='
+ read -r line
+ echo ''
+ read -r line
+ [[ # OS distribution/release =~ ^(#)?[a-zA-Z] ]]
+ echo '# OS distribution/release'
+ read -r line
+ [[ # Valid arguments: raspios, raspbian, debian, ubuntu, stretch, buster, bullseye, bionic, focal =~ ^(#)?[a-zA-Z] ]]
+ echo '# Valid arguments: raspios, raspbian, debian, ubuntu, stretch, buster, bullseye, bionic, focal'
+ read -r line
+ [[ # osrelease= =~ ^(#)?[a-zA-Z] ]]
+ echo '# osrelease='
+ read -r line
+ echo ''
+ read -r line
+ [[ # Java version to install =~ ^(#)?[a-zA-Z] ]]
+ echo '# Java version to install'
+ read -r line
+ [[ # Valid arguments: 11, 17 =~ ^(#)?[a-zA-Z] ]]
+ echo '# Valid arguments: 11, 17'
+ read -r line
+ [[ java_opt=17 =~ ^(#)?[a-zA-Z] ]]
+ parsed=java_opt=17
+ [[ java_opt=17 =~ ^#[a-zA-Z] ]]
++ echo java_opt=17
++ cut -d= -f1
+ param=java_opt
+ [[ -v java_opt ]]
+ [[ 17 == *\ * ]]
+ echo java_opt=17
+ read -r line
+ echo ''
+ read -r line
+ [[ # install zram per default, set to "disable" to skip installation =~ ^(#)?[a-zA-Z] ]]
+ echo '# install zram per default, set to "disable" to skip installation'
+ read -r line
+ [[ zraminstall=enable =~ ^(#)?[a-zA-Z] ]]
+ parsed=zraminstall=enable
+ [[ zraminstall=enable =~ ^#[a-zA-Z] ]]
++ echo zraminstall=enable
++ cut -d= -f1
+ param=zraminstall
+ [[ -v zraminstall ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # start comitup hotspot if internet is not reachable =~ ^(#)?[a-zA-Z] ]]
+ echo '# start comitup hotspot if internet is not reachable'
+ read -r line
+ [[ hotspot=enable =~ ^(#)?[a-zA-Z] ]]
+ parsed=hotspot=enable
+ [[ hotspot=enable =~ ^#[a-zA-Z] ]]
++ echo hotspot=enable
++ cut -d= -f1
+ param=hotspot
+ [[ -v hotspot ]]
+ read -r line
+ [[ hotspotpw=openhabian =~ ^(#)?[a-zA-Z] ]]
+ parsed=hotspotpw=openhabian
+ [[ hotspotpw=openhabian =~ ^#[a-zA-Z] ]]
++ echo hotspotpw=openhabian
++ cut -d= -f1
+ param=hotspotpw
+ [[ -v hotspotpw ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # external SD card device to backup and mirror the internal SD card to =~ ^(#)?[a-zA-Z] ]]
+ echo '# external SD card device to backup and mirror the internal SD card to'
+ read -r line
+ [[ # backupdrive=/dev/sda =~ ^(#)?[a-zA-Z] ]]
+ echo '# backupdrive=/dev/sda'
+ read -r line
+ [[ storageconfig=openhab-dir =~ ^(#)?[a-zA-Z] ]]
+ parsed=storageconfig=openhab-dir
+ [[ storageconfig=openhab-dir =~ ^#[a-zA-Z] ]]
++ echo storageconfig=openhab-dir
++ cut -d= -f1
+ param=storageconfig
+ [[ -v storageconfig ]]
+ [[ openhab-dir == *\ * ]]
+ read -r line
+ [[ storagedir=/storage =~ ^(#)?[a-zA-Z] ]]
+ parsed=storagedir=/storage
+ [[ storagedir=/storage =~ ^#[a-zA-Z] ]]
++ echo storagedir=/storage
++ cut -d= -f1
+ param=storagedir
+ [[ -v storagedir ]]
+ [[ /storage == *\ * ]]
+ read -r line
+ [[ storagetapes=15 =~ ^(#)?[a-zA-Z] ]]
+ parsed=storagetapes=15
+ [[ storagetapes=15 =~ ^#[a-zA-Z] ]]
++ echo storagetapes=15
++ cut -d= -f1
+ param=storagetapes
+ [[ -v storagetapes ]]
+ [[ 15 == *\ * ]]
+ read -r line
+ [[ storagecapacity=1024 =~ ^(#)?[a-zA-Z] ]]
+ parsed=storagecapacity=1024
+ [[ storagecapacity=1024 =~ ^#[a-zA-Z] ]]
++ echo storagecapacity=1024
++ cut -d= -f1
+ param=storagecapacity
+ [[ -v storagecapacity ]]
+ [[ 1024 == *\ * ]]
+ read -r line
+ echo ''
+ read -r line
+ [[ # mail relay settings =~ ^(#)?[a-zA-Z] ]]
+ echo '# mail relay settings'
+ read -r line
+ [[ # adminmail=john.doe@foo.bar =~ ^(#)?[a-zA-Z] ]]
+ echo '# adminmail=john.doe@foo.bar'
+ read -r line
+ [[ # relayuser=john.doe@foo.bar =~ ^(#)?[a-zA-Z] ]]
+ echo '# relayuser=john.doe@foo.bar'
+ read -r line
+ [[ # relaypass=secret =~ ^(#)?[a-zA-Z] ]]
+ echo '# relaypass=secret'
+ read -r line
+ [[ # smarthost=smtp.gmail.com =~ ^(#)?[a-zA-Z] ]]
+ echo '# smarthost=smtp.gmail.com'
+ read -r line
+ [[ # smartport=587 =~ ^(#)?[a-zA-Z] ]]
+ echo '# smartport=587'
+ read -r line
+ echo ''
+ read -r line
+ [[ # Network UPS Tools =~ ^(#)?[a-zA-Z] ]]
+ echo '# Network UPS Tools'
+ read -r line
+ [[ # nutmode=netserver =~ ^(#)?[a-zA-Z] ]]
+ echo '# nutmode=netserver'
+ read -r line
+ [[ # Settings for netserver: =~ ^(#)?[a-zA-Z] ]]
+ echo '# Settings for netserver:'
+ read -r line
+ [[ # nutupsdriver=usbhid-ups =~ ^(#)?[a-zA-Z] ]]
+ echo '# nutupsdriver=usbhid-ups'
+ read -r line
+ [[ # nutupsdescr="" =~ ^(#)?[a-zA-Z] ]]
+ echo '# nutupsdescr=""'
+ read -r line
+ [[ # Settings for netclient: =~ ^(#)?[a-zA-Z] ]]
+ echo '# Settings for netclient:'
+ read -r line
+ [[ # nutupsname=ups =~ ^(#)?[a-zA-Z] ]]
+ echo '# nutupsname=ups'
+ read -r line
+ [[ # nutupshost=xxx.xxx.xxx.xx =~ ^(#)?[a-zA-Z] ]]
+ echo '# nutupshost=xxx.xxx.xxx.xx'
+ read -r line
+ [[ # nutupsuser=monuser =~ ^(#)?[a-zA-Z] ]]
+ echo '# nutupsuser=monuser'
+ read -r line
+ [[ # nutupspw=secret =~ ^(#)?[a-zA-Z] ]]
+ echo '# nutupspw=secret'
+ read -r line
+ echo ''
+ read -r line
+ [[ # Tailscale VPN =~ ^(#)?[a-zA-Z] ]]
+ echo '# Tailscale VPN'
+ read -r line
+ [[ # preauthkey=tskey-xxxxxxxxxxxxxxxxx =~ ^(#)?[a-zA-Z] ]]
+ echo '# preauthkey=tskey-xxxxxxxxxxxxxxxxx'
+ read -r line
+ [[ # tstags=tag:client =~ ^(#)?[a-zA-Z] ]]
+ echo '# tstags=tag:client'
+ read -r line
+ echo ''
+ read -r line
+ [[ # Custom log files =~ ^(#)?[a-zA-Z] ]]
+ echo '# Custom log files'
+ read -r line
+ [[ # custom_log_files=("/var/log/foo.log" "/var/log/bar.log") =~ ^(#)?[a-zA-Z] ]]
+ echo '# custom_log_files=("/var/log/foo.log" "/var/log/bar.log")'
+ read -r line
+ echo ''
+ read -r line
+ [[ # vim: filetype=sh =~ ^(#)?[a-zA-Z] ]]
+ echo '# vim: filetype=sh'
+ read -r line
+ [[ -f /etc/init.d/openhabian-config ]]
+ config_ipv6
+ local aptConf=/etc/apt/apt.conf.d/S90force-ipv4
+ local sysctlConf=/etc/sysctl.d/99-sysctl.conf
+ [[ enable == \d\i\s\a\b\l\e ]]
+ [[ enable == \e\n\a\b\l\e ]]
+ grep -qs '^[[:space:]]*# Disable all IPv6 functionality' /etc/sysctl.d/99-sysctl.conf
+ [[ -n '' ]]
+ apt_update
+ export PID_APT=5366
+ PID_APT=5366
+ nohup apt-get update
+ whiptail_check
++ command -v whiptail
+ [[ -x /usr/bin/whiptail ]]
+ load_create_config
+ local 'questionText=\nWelcome to openHABian!\n\nPlease provide the name of your Linux user i.e. the account you normally log in with.\n\nTypical user names are '\''pi'\'' or '\''ubuntu'\''.'
+ local input
+ [[ -f /etc/openhabian.conf ]]
++ timestamp
++ printf '%(%F_%T_%Z)T\n' -1
+ echo -n '2024-02-08_17:36:44_CET [openHABian] Loading configuration file '\''/etc/openhabian.conf'\''... '
2024-02-08_17:36:44_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... ++ getent group openhabian
+ [[ ! -n openhabian:x:1000:openhabian ]]
+ id -u openhabian
+ source /etc/openhabian.conf
++ hostname=openhabian
++ username=openhabian
++ userpw=openhabian
++ adminkeyurl=
++ timezone=Europe/Berlin
++ locales='en_US.UTF-8 de_DE.UTF-8'
++ system_default_locale=en_US.UTF-8
++ wifi_ssid=
++ wifi_password=
++ wifi_country=
++ ipv6=enable
++ repositoryurl=https://github.com/openhab/openhabian.git
++ clonebranch=openHAB
++ debugmode=maximum
++ framebuffer=enable
++ apttimeout=60
++ java_opt=17
++ zraminstall=enable
++ hotspot=enable
++ hotspotpw=openhabian
++ storageconfig=openhab-dir
++ storagedir=/storage
++ storagetapes=15
++ storagecapacity=1024
+ echo OK
OK
+ openhabian_console_check
+ [[ -z 1 ]]
++ tput cols
+ [[ 317 -ge 120 ]]
+ return 0
+ openhabian_update_check
+ [[ -z 1 ]]
+ local branch
+ local introText
+ local unsupportedOSText
+ branch=openHAB
+ introText='Additions, improvements or fixes were added to the openHABian configuration tool. Would you like to update now and benefit from them? The update will not automatically apply changes to your system.\n\nUpdating is recommended.'
+ unsupportedOSText='You are running an old Linux release that is no longer officially supported.\nWe recommend upgrading to the most current stable release of your distribution (or current Long Term Support version for distributions that offer LTS).\nDo you really want to continue using openHABian on this system?'
++ timestamp
++ get_git_revision
++ local branch
++ local commitDate
++ local shorthash
+++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
++ branch=openHAB
+++ git -C /opt/openhabian log --pretty=format:%aI -n 1
++ commitDate=2024-02-06T16:24:27+01:00
+++ git -C /opt/openhabian log --pretty=format:%h -n 1
++ shorthash=a497e54
++ echo '[openHAB]{2024-02-06T16:24:27+01:00}(a497e54)'
+ echo '2024-02-08_17:36:44_CET [openHABian] openHABian configuration tool version: [openHAB]{2024-02-06T16:24:27+01:00}(a497e54)'
++ timestamp
+ echo -n '2024-02-08_17:36:44_CET [openHABian] Checking for changes in origin branch openHAB... '
2024-02-08_17:36:44_CET [openHABian] Checking for changes in origin branch openHAB... + is_stretch
+ [[ '' == \s\t\r\e\t\c\h ]]
++ cat /etc/os-release
+ [[ PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" =~ stretch ]]
+ return 1
+ is_xenial
+ [[ '' == \x\e\n\i\a\l ]]
VERSION_ID="11"
ID=raspbian
ID_LIKE=debian
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" =~ xenial ]]
+ return 1
+ git -C /opt/openhabian config user.email openhabian@openHABian
+ git -C /opt/openhabian config user.name openhabian
+ git -C /opt/openhabian fetch --quiet origin
++ git -C /opt/openhabian rev-parse openHAB
++ git -C /opt/openhabian rev-parse '@{u}'
+ [[ a497e5431ceefab91728de8d7abdaa8c86568dbe == a497e5431ceefab91728de8d7abdaa8c86568dbe ]]
+ echo OK
OK
+ openhabian_announcements
+ [[ -z 1 ]]
+ local altReadNews
+ local newsFile
+ local readNews
+ altReadNews=/tmp/NEWS.md
+ newsFile=/opt/openhabian/NEWS.md
+ readNews=/opt/openhabian/docs/NEWS.md
+ cmp --silent /opt/openhabian/NEWS.md /opt/openhabian/docs/NEWS.md
++ timestamp
+ echo -n '2024-02-08_17:36:45_CET [openHABian] Switching to branch openHAB... '
2024-02-08_17:36:45_CET [openHABian] Switching to branch openHAB... + git -C /opt/openhabian checkout --quiet openHAB
+ echo OK
OK
++ timestamp
+ echo '2024-02-08_17:36:45_CET [openHABian] Checking openHAB Signing Key expiry.'
+ check_keys openhab
+ local repoKey=/usr/share/keyrings/openhab.gpg
++ timestamp
+ echo -n '2024-02-08_17:36:45_CET [openHABian] Checking expiry date of apt keys... '
2024-02-08_17:36:45_CET [openHABian] Checking expiry date of apt keys... + [[ ! -f /usr/share/keyrings/openhab.gpg ]]
++ gpg --with-colons --fixed-list-mode --show-keys /usr/share/keyrings/openhab.gpg
++ cut -d: -f7
++ awk NF
+ gpgKeys='1915194593
1915211934'
++ date +%s
+ currentTime=1707410205
+ [[ -n 1915194593
1915211934 ]]
+ IFS=
+ read -r keyExpiry
+ diff=207784388
+ daysLeft=2404
+ [[ 2404 -lt 30 ]]
+ IFS=
+ read -r keyExpiry
+ diff=207801729
+ daysLeft=2405
+ [[ 2405 -lt 30 ]]
+ IFS=
+ read -r keyExpiry
+ echo OK
OK
+ return 0
+ jsscripting_npm_check openhab
+ '[' openhab == '' ']'
+ '[' '!' -d /etc/openhab/automation/js/node_modules/openhab ']'
+ return 0
+ jsscripting_npm_check openhab_rules_tools
+ '[' openhab_rules_tools == '' ']'
+ '[' '!' -d /etc/openhab/automation/js/node_modules/openhab_rules_tools ']'
+ local 'introText=Additions, improvements or fixes were added to openhab_rules_tools (npm package) for JS Scripting. Would you like to update now and benefit from them?'
+ local 'breakingText=\n\nThis update includes BREAKING CHANGES!'
+ local data
+ local wantedVersion
+ local latestVersion
+ node_is_installed
++ command -v npm
+ [[ -x '' ]]
+ return 1
++ timestamp
+ echo -n '2024-02-08_17:36:45_CET [openHABian] Installing prerequsites for openhab_rules_tools for JS Scripting (NodeJS)... '
2024-02-08_17:36:45_CET [openHABian] Installing prerequsites for openhab_rules_tools for JS Scripting (NodeJS)... + cond_redirect nodejs_setup
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ nodejs_setup \033[39;49;00m'
$ nodejs_setup
+ nodejs_setup
+ node_is_installed
++ command -v npm
+ [[ -x '' ]]
+ return 1
+ local keyName=nodejs
+ local link=https://nodejs.org/dist/v18.16.1/node-v18.16.1-linux-armv7l.tar.xz
+ local myDistro
+ local temp
++ lsb_release -sc
+ myDistro=bullseye
+ [[ bullseye == \n\/\a ]]
++ mktemp /tmp/openhabian.XXXXX
+ temp=/tmp/openhabian.MrpDN
+ [[ -z '' ]]
+ is_armv6l
+ [[ '' == \a\r\m\v\6\l ]]
+ case "$(uname -m)" in
++ uname -m
+ return 1
+ [[ -z '' ]]
+ add_keys https://deb.nodesource.com/gpgkey/nodesource.gpg.key nodejs
+ local repoKey=/usr/share/keyrings/nodejs.gpg
++ timestamp
+ echo -n '2024-02-08_17:36:45_CET [openHABian] Adding required keys to apt... '
2024-02-08_17:36:45_CET [openHABian] Adding required keys to apt... + curl -fsL https://deb.nodesource.com/gpgkey/nodesource.gpg.key
+ gpg --dearmor
+ echo OK
OK
++ timestamp
+ echo -n '2024-02-08_17:36:45_CET [openHABian] Adding NodeSource repository to apt... '
2024-02-08_17:36:45_CET [openHABian] Adding NodeSource repository to apt... + echo 'deb [signed-by=/usr/share/keyrings/nodejs.gpg] https://deb.nodesource.com/node_18.x bullseye main'
+ echo 'deb-src [signed-by=/usr/share/keyrings/nodejs.gpg] https://deb.nodesource.com/node_18.x bullseye main'
+ [[ -n '' ]]
+ cond_redirect apt-get update
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ apt-get update \033[39;49;00m'
$ apt-get update
+ apt-get update
Reading package lists... Done
E: Could not get lock /var/lib/apt/lists/lock. It is held by process 5366 (apt-get)
N: Be aware that removing the lock file is not a solution and may break your system.
E: Unable to lock directory /var/lib/apt/lists/
+ return 100
+ echo 'FAILED (update apt lists)'
+ return 1
+ return 1
+ echo FAILED
FAILED
+ return 1
+ show_main_menu
+ local choice
+ local version
+ local javaVersion
+++ get_git_revision
+++ local branch
+++ local commitDate
+++ local shorthash
++++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
+++ branch=openHAB
++++ git -C /opt/openhabian log --pretty=format:%aI -n 1
+++ commitDate=2024-02-06T16:24:27+01:00
++++ git -C /opt/openhabian log --pretty=format:%h -n 1
+++ shorthash=a497e54
+++ echo '[openHAB]{2024-02-06T16:24:27+01:00}(a497e54)'
++ whiptail --title 'openHABian Configuration Tool — [openHAB]{2024-02-06T16:24:27+01:00}(a497e54)' --menu 'Setup Options' 24 118 16 --cancel-button Exit --ok-button Execute '00 | About openHABian' 'Information about the openHABian project and this tool' '' '' '01 | Select Branch' 'Select the openHABian config tool version ("branch") to run' '02 | Upgrade System' 'Update all installed software packages (incl. openHAB) to their latest version' '03 | Install openHAB' 'Install or upgrade to latest openHAB' '04 | Import config' 'Import an openHAB configuration from file or URL' '' '' '10 | Apply Improvements' 'Apply the latest improvements to the basic openHABian setup ►' '20 | Optional Components' 'Choose from a set of optional software components ►' '30 | System Settings' 'A range of system and hardware related configuration steps ►' '40 | openHAB Related' 'Switch the installed openHAB version or apply tweaks ►' '50 | Backup/Restore' 'Manage backups and restore your system ►'
+ choice=
+ RET=1
+ '[' 1 -eq 1 ']'
+ return 255
+ system_check_default_password
+ is_pi
+ is_pifive
+ [[ '' == \p\i\5 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]17[0-9a-fA-F]$' /proc/cpuinfo
+ return 1
+ is_pifour
+ [[ '' == \p\i\4 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]11[0-9a-fA-F]$' /proc/cpuinfo
+ return 0
+ return 0
+ local algo
+ local defaultPassword
+ local defaultUser
+ local generatedPassword
+ local introText
+ local originalPassword
+ local salt
+ is_pi
+ is_pifive
+ return 1
+ is_pifour
+ return 0
+ return 0
+ id -u pi
+ is_pi
+ is_pifive
+ return 1
+ is_pifour
+ return 0
+ return 0
+ defaultUser=openhabian
+ defaultPassword=openhabian
++ grep -w openhabian /etc/shadow
++ cut -d: -f2
+ originalPassword='$XXX'
++ echo '$XXX'
++ cut '-d$' -f2
+ algo=6
+ introText='The default password was detected on your system! That is a serious security concern. Bad guys or malicious programs in your subnet are able to gain root access!\n\nPlease set a strong password by typing the command '\''passwd openhabian'\''!'
++ echo '$XXX'
++ cut '-d$' -f3
+ salt=pPlfo1Mb4OMxbF1U
+ export algo defaultPassword salt
++ perl -le 'print crypt("$ENV{defaultPassword}","\$$ENV{algo}\$$ENV{salt}\$")'
+ generatedPassword='XXX'
++ timestamp
+ echo -n '2024-02-08_17:36:58_CET [openHABian] Checking for default openHABian username:password combination... '
2024-02-08_17:36:58_CET [openHABian] Checking for default openHABian username:password combination... ++ id -u openhabian
+ [[ -n 1000 ]]
+ [[ $XXX == XXX ]]
+ [[ -n 1 ]]
+ whiptail --title 'Default password detected' --msgbox 'The default password was detected on your system! That is a serious security concern. Bad guys or malicious programs in your subnet are able to gain root access!\n\nPlease set a strong password by typing the command '\''passwd openhabian'\''!' 11 80
+ echo FAILED
FAILED
++ timestamp
+ echo -e '2024-02-08_17:37:00_CET [openHABian] We hope you got what you came for! See you again soon ;)'
+ cd /home/openhabian
openhabian@openhabian:~ $
