Edited - see below
Hello, I have a question about RAW copy (option 54 in openhabian-config):
To upgrade from v4.1.0 to v4.1.1 I wanted to create a copy of the SD card first.
When I create the raw copy via option 54, the message FAILED (e2fsck) appears.
See third last line in the first code block.
When I check the two partitions with e2fsck I get following results (see the second code block)
This happens also with unused/new SD cards.
xxxxx@yyyyy:~ $ sudo openhabian-config
2024-01-13_14:24:55_CET [openHABian] Checking for root privileges... OK
2024-01-13_14:24:55_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2024-01-13_14:24:55_CET [openHABian] openHABian configuration tool version: [openHAB]{2023-12-31T13:09:51+01:00}(9ac4ddd)
2024-01-13_14:24:55_CET [openHABian] Checking for changes in origin branch openHAB... OK
2024-01-13_14:24:56_CET [openHABian] Switching to branch openHAB... OK
2024-01-13_14:24:56_CET [openHABian] Checking openHAB Signing Key expiry.
2024-01-13_14:24:56_CET [openHABian] Checking expiry date of apt keys... OK
blockdev: cannot open /dev/sda1: Datei oder Verzeichnis nicht gefunden
raw device copy of /dev/mmcblk0p1 is larger than /dev/sda1... blockdev: cannot open /dev/sda2: Datei oder Verzeichnis nicht gefunden
raw device copy of /dev/mmcblk0p2 is larger than /dev/sda2... Checking that no-one is using this disk right now ... OK
Disk /dev/sda: 29,72 GiB, 31914983424 bytes, 62333952 sectors
Disk model: STORAGE DEVICE
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x90ac96be
Old situation:
>>> Script header accepted.
>>> Created a new DOS disklabel with disk identifier 0x05ba41dd.
/dev/sda1: Created a new partition 1 of type 'W95 FAT32 (LBA)' and of size 256 MiB.
Partition #1 contains a vfat signature.
/dev/sda2: Created a new partition 2 of type 'Linux' and of size 14,7 GiB.
Partition #2 contains a ext4 signature.
/dev/sda3: Done.
New situation:
Disklabel type: dos
Disk identifier: 0x05ba41dd
Device Boot Start End Sectors Size Id Type
/dev/sda1 8192 532479 524288 256M c W95 FAT32 (LBA)
/dev/sda2 532480 31399935 30867456 14,7G 83 Linux
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
Taking a raw partition copy, be prepared this may take long such as 20-30 minutes for a 16 GB SD card
FAILED (e2fsck)
2024-01-13_14:31:58_CET [openHABian] Checking for default openHABian username:password combination... OK
2024-01-13_14:31:58_CET [openHABian] We hope you got what you came for! See you again soon ;)
xxxxx@yyyyy:~ $ sudo e2fsck /dev/sda1
e2fsck 1.46.2 (28-Feb-2021)
ext2fs_open2: Bad magic number in super-block
e2fsck: Superblock invalid, trying backup blocks...
e2fsck: Bad magic number in super-block while trying to open /dev/sda1
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
/dev/sda1 contains a vfat file system labelled 'boot'
xxxxx@yyyyy:~ $ sudo e2fsck /dev/sda2
rootfs: clean, 114243/932672 files, 2716848/3858432 blocks
Can I ignore this, because the copy works perfectly?
EDIT:
After a little research I think I understand that I can ignore the message, because e2fsck only refers to ext2/3/4 file systems and the partition with the invalid superblock in question is FAT32.
Could someone confirm this for me ?
