I did a clean installation (64-bit) openhabian on RP4.
openhabian-config says [openHAB]{2023-12-31T13:09:51+01:00}(9ac4ddd)
Version: 4.1.1 (Build)
When choosing [02] Upgrade System it failed and as I had debugging on, I could look through the logs and saw a hint saying I should the following manually
sudo dpkg --configure -a
After that it worked well.
I am posting this because I wonder if someone has an idea why this may have happened in the first place and how we can avoid that?
