Just had to reboot again
Some data of log and screen
2023-02-08 12:43:33.478 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘l_keuken_SmokeSensor_LastUpdated’ changed from 2023-02-08T12:38:33.207+0100 to 2023-02-08T12:43:33.473+0100
2023-02-08 12:43:38.478 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber ‘org.openhab.core.io.monitor.internal.EventLogger@aae5e5’ takes more than 5000ms.
2023-02-08 13:09:06.824 [ERROR] [omponents.UIComponentSitemapProvider] - Cannot build sitemap page_763dd9b007
java.lang.ArrayIndexOutOfBoundsException: Index 1 out of bounds for length 1
at org.openhab.core.ui.internal.components.UIComponentSitemapProvider.addWidgetMappings(UIComponentSitemapProvider.java:324) ~[?:?]
at org.openhab.core.ui.internal.components.UIComponentSitemapProvider.buildWidget(UIComponentSitemapProvider.java:215) ~[?:?]
Using username “openhabian”.
Linux openhabian 5.15.84-v7l+ #1613 SMP Thu Jan 5 12:01:26 GMT 2023 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Feb 6 22:13:52 2023 from 192.168.0.110
############### openhabian ##################################################
Ip = 192.168.0.155
Release = Raspbian GNU/Linux 11 (bullseye)
Kernel = Linux 5.15.84-v7l+
Platform = none
Uptime = 1 day(s). 15:2:4
CPU Usage = 62.56% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
CPU Load = 1m: 4.08, 5m: 3.74, 15m: 3.41
Memory = Free: 0.57GB (15%), Used: 3.22GB (85%), Total: 3.79GB
Swap = Free: 2.99GB (100%), Used: 0.00GB (0%), Total: 2.99GB
Root = Free: 17.17GB (63%), Used: 10.05GB (37%), Total: 28.41GB
Updates = 15 apt updates available.
Sessions = 1 session(s)
Processes = 135 running processes of 32768 maximum processes
_ _ _ ____ _
___ ___ ___ ___ | | | | / \ | __ ) () ____ ___
/ _ \ / _ \ / _ \ / _ \ | || | / _ \ | _ \ | | / _ \ / _
| () | () | /| | | || _ | / ___ \ | |) )| || () || | | |
_/| / _/|| |||| ||// _|/ || _|||| | |
|| openHAB 3.4.1 - Release Build
Looking for a place to get started? Check out ‘sudo openhabian-config’ and the
documentation at openHABian | openHAB
The openHAB dashboard can be reached at http://openhabian:8080
To interact with openHAB on the command line, execute: ‘openhab-cli --help’
openhabian@openhabian:~ $ sudo /bin/systemctl status openhab.service
[sudo] password for openhabian:
● openhab.service - openHAB - empowering the smart home
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor prese>
Drop-In: /etc/systemd/system/openhab.service.d
└─override.conf
Active: active (running) since Mon 2023-02-06 22:11:33 CET; 1 day 15h ago
Docs: Introduction | openHAB
https://community.openhab.org
Main PID: 949 (java)
Tasks: 189 (limit: 4915)
CPU: 43min 45.266s
CGroup: /system.slice/openhab.service
└─949 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/ope>
Warning: journal has been rotated since unit was started, output may be incompl>
lines 1-14/14 (END)…skipping…
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
└─override.conf
CPU: 43min 45.266s
└─949 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.userdata=/var/lib/openhab -Dopenhab.logdir=/var/log/openhab -Dfelix.c>
Warning: journal has been rotated since unit was started, output may be incomplete.
