openhabian etc … // MQTT.fx: Mosquitto is running and connecting
InfluxDB+grafana: …
InfluxDB
admin / PW
openhab / PW
grafana / PW
database: openhab
grafana
admin / PW
InfluxDB should be configured with OpenHAB: Yes
=> "There was an error or interruption during the execution of: "
"20 | Optional Components"
configuration: No external hardware (Sensors …)
logs: … unfortunatey I do not find where installation logs are written - if there are logs at all.
The location of installation log could be mentioned in the docs.
This is my very first post - to be precise my first reply to an existing post - so I say a friendly hello to everybody.
After invoking menu item 24 - InfluxDB+Gafana in openhabian-config, entering the requested passwords the installation started. Then the already mentioned message appeared: “There was an error or interuption…”
I started menu item 24 directly after a fresh openHAB 3.02 installation with the latest openhabian (“main”) on a Raspi4. Debug mode was set to maximum in file openhabian.conf. The resulting log output was app. 1200 lines. As a novice member I’m not allowed to include files, so I present an excerpt of the log here (to my opinion the important part):
$ sed -i -e s|# store-enabled = true|store-enabled = false|g /etc/influxdb/influxdb.conf
+ sed -i -e 's|# store-enabled = true|store-enabled = false|g' /etc/influxdb/influxdb.conf
+ return 0
+ cond_redirect systemctl restart influxdb.service
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ systemctl restart influxdb.service \033[39;49;00m'
+ systemctl restart influxdb.service
+ return 0
+ cond_echo '\nCheck if InfluxDB is running... '
+ [[ -z '' ]]
+ echo -e '\033[33;01m\nCheck if InfluxDB is running... \033[39;49;00m'
+ cond_redirect curl --retry 6 --retry-connrefused --user hans:Susi9596 --insecure http://localhost:8086/query
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --retry 6 --retry-connrefused --user hans:Susi9596 --insecure http://localhost:8086/query \033[39;49;00m'
+ curl --retry 6 --retry-connrefused --user hans:Susi9596 --insecure http://localhost:8086/query
curl: (7) Failed to connect to localhost port 8086: Connection refused
+ return 7
+ echo FAILED
FAILED
+ return 1
+ return 1
+ echo FAILED
FAILED
+ return 1
+ '[' 1 -ne 0 ']'
+ whiptail --msgbox 'There was an error or interruption during the execution of:\n "20 | Optional Components"\n\nPlease try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md how to proceed.' 14 80
I’ve done this procedure over and over with the same reproducable results. I don’t know if this problem has already been solved, so I kindly ask for help.
