openHABian frontail install error
I am trying to install Frontail on a fresh install of Ubuntu 17.10 via openhabian-config. Unfortunately, I get this error:
2018-01-24_21:40:30_CST [openHABian] Installing the openHAB Log Viewer (frontail)...
$ npm install -g frontail
npm WARN deprecated connect@2.11.0: connect 2.x series is deprecated
npm ERR! code 1
npm ERR! Command failed: /usr/bin/git clone --depth=1 -q -b master git://github.com/zipang/daemon.node.git /home/dome/.npm/_cacache/tmp/git-clone-cac570e3
npm ERR! /home/dome/.npm/_cacache/tmp/git-clone-cac570e3/.git: Permission denied
npm ERR!
npm ERR! A complete log of this run can be found in:
npm ERR!     /home/dome/.npm/_logs/2018-01-25T03_40_31_678Z-debug.log
FAILED (frontail)
I get the same error when I execute:
npm i frontail -g
I answered my own question - after a subsequent fresh install, the error message is more helpful. 17.10 (artful) apparently isn’t supported yet.
Using Lubuntu I ran into the same issue (“artful”)…
Try (with sudo)
apt install npm
npm i frontail -g
Then tested with
frontail /var/log/syslog
and it was working.
Nevertheless if you have a different host name than “openhabianpi”, it won´t work out of the box (known issue), as the device name in the startup screen is wrong.
Run
grep -i -w -R 'openhabiandevice' / 2>/dev/null
This will give you the file where the entry is wrong. For me it was
/srv/openhab2-conf/services/dashboard.cfg
Use e.g. nano to correct the link.
To revise my previous answer:
It seems that there is an issue with node7.x no longer supported, switching to node 8.x did the trick and resulted in frontail being installed from the openhabian-config directly.
So i uninstalled node, then ran
sudo curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
apt-get install nodejs
sudo openhabian-config
In the optional components i triggered the LogViewer installation, this ran through without the previous errors.
After that Frontail is running on port 9001.
Hope this helps,
Thomas
Unrelated to this content but may help someone given the title. I was having a repeated install error when reaching the install of Frontail on my raspberry pi 3 with the config tool. Moved to a different SD card and the problem disappeared, I think it had to do with the size of the card? The 2GB card failed but a 4GB card work.
Reviving this topic as I had the issue that I couldn’t install frontail on a fresh Openhabian (OH3) installation.
Here’s what I did, maybe it helps somebody at some point.
sudo apt-get remove nodejs
sudo curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
sudo apt-get install -y nodejs
sudo openhabian-config //install frontail
Thank you @mancer . I have the same issue when installing frontail. Guess downgrade to nodejs 12 helps.
UPDATE: ok, this issue has nothing todo with frontail, I also get this error for other actions in openhabian-config, so please ignore my note below, sorry :slight_smile:
UPDATE2: ok, if anybody else runs into certification faults (also with apt-get upgrade), here the solution: clean reinstall after resetting the FritzBox (router) config for that client (the raspi). Not sure what the reason was, maybe me, not beeing patient during initial installation phase.
Hey, I am reopening this thread since I ran into the same (or comparable) issue in OH4.
My setup:
openHAB 4.0.0.M3
openhabian 1.8
Raspbian GNU/Linux 11 (bullseye)
Kernel = Linux 6.1.21-v8+
Platform = Raspberry Pi 4 Model B Rev 1.1
What I did:
Fresh install. All fine, no issues.
But no Log Viewer available from the beginning.
Tried to install as documented here Rules Blockly - Before Using | openHAB (sudo openhabian-config → option 20 → option 21 → error)
Error:
There was an error or interruption during the execution of:                  │
                          │   "20 | Optional Components"                                                 │
                          │ Please try again. If the error persists, please read                         │
                          │ /opt/openhabian/docs/openhabian-DEBUG.md or                                  │
                          │ https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md how │
                          │ to proceed.        │
In the console log I get these errors:
2023-07-07_14:57:46_CEST [openHABian] Installing Frontail prerequsites (NodeJS)...
$ nodejs_setup
2023-07-07_14:57:47_CEST [openHABian] Adding required keys to apt... curl: (77) error setting certificate verify locations:  CAfile: /etc/ssl/certs/ca-certificates.crt CApath: /etc/ssl/certs
gpg: no valid OpenPGP data found.
FAILED
set debugmode=maximum in openhabian.conf, record the window output and retry installing to see what’s exactly the command that fails
