- Platform information:
- Hardware: Raspberry Pi3
- OS: OpenHabian latest
- Java Runtime Environment: which java platform is used and what version
- openHAB version: latest stable
Hello guys
I have just installed latest OpenHabian on my Raspberry Pi3 and all went fine until I installed also Influxdb and Grafana. I used the openhabian-config program to install them and then did the configuration as described in the tutorial. Unfortunately when opening Grafana web interface I get nothing but a blank black screen (used Chrome and Edge with the same result).
I also tried upgrade system via openhabian-config and that however fails too. I get error messages in upgrade phase where some unauthenticated packages fail to upgrade.
Anyone having same issue and found a solution?
Thank you in advance for help.
