openHABian hassle-free openHAB Setup
This is a shout out to RPi+Razberry+openHAB users:
Please help solve the still unclear issue with the Razberry and openHABian, especially in combination with a RPi3 with Bluetooth. There is a ticket for that topic in the issue tracker. Input from users with experience with the hardware and/or willing to gather the needed intel, please step forward :wink:
https://github.com/ThomDietrich/openhabian/issues/33
I looked into the script you are talking about and found more details regarding the problem that both Razberry and Bluetooth use the same UART pins 14 and 15. That’s the reason why Bluetooth indeed needs to be disabled! (CPU freq changes do not seem mandatory) (The following has to be done additionally to Serial Port activation through openhabian-config)
I’m not sure about the differences between these two solution but I would recommend the one used in the official installation script:
# Disable bluetooth Raspberry Pi 3
RPI_BOARD_REVISION=`grep Revision /proc/cpuinfo | cut -d: -f2 | tr -d " "`
if [[ $RPI_BOARD_REVISION ==  "a02082" || $RPI_BOARD_REVISION == "a22082" ]]
	echo "Raspberry Pi 3 Detected. Disabling Bluetooth"
	systemctl disable hciuart
	# Add "dtoverlay=pi3-miniuart-bt" to /boot/config.txt if needed
	if [[ ! `grep "dtoverlay=pi3-miniuart-bt" /boot/config.txt` ]]
		echo "Adding 'dtoverlay=pi3-miniuart-bt' to /boot/config.txt"
		echo "dtoverlay=pi3-miniuart-bt" >> /boot/config.txt
	fi
	echo "!!! Update Raspberry Pi 3 Firmware for stability work with commands:"
	echo "sudo apt-get install rpi-update"
	echo "sudo rpi-update"
fi
Btw.: The “hciuart” service is disabled during the mentioned installation script.
Btw. 2: A “UZB” was mentioned and successfully tested without disabling Bluetooth (the above instructions). I’m too lazy too google what UZB is, I’ll leave this here just for reference.
Hey guys,
loosing the list of installed bindings is in fact a current problem in openHAB which is worked on with effort! Current plans are to remove the cause of this problem this Thursday. Please do not overrate this hickup of a beta snapshot :wink:
Apart from the problem, I can still recommend installing bindings through addons.cfg as this will act as an instant backup of your setup.
@UglyKidJoe: “I’ll use updates more sparingly” is not the conclusion you should draw from that :smiley:
The command your screenshot shows should work with the default setup. I’d guess the IP address is the problem. This has to be the IP of your broker, which is the openHABianPi itself (localhost). In this you can just ignore this option.
mosquitto_sub -t 'owntracks/#'
is it possible to install this on a USB drive… i tried changing the cmdline.txt to root=/dev/sda2 but that didn’t work anything else i should be doing?
  • Use the “Move root to USB” feature in the menu after you finished installation on SD card (this will still need the SD to be present)
  • Set inside installer-config.txt usbroot= # set to 1 to install to first USB disk. This was not tested by me.
sorry can you please clearify that for me. where do i find the MOVE ROOT TO USB. once i downloaded the “openhabian-ua-netinst-20160915-git9e034e7” i used Wind32Diskimage to put the image on my sd card..
also inside the installer-config.txt
do i replace the
“hostname=openHABianPi boot_volume_label=openHABian disable_root=1 username=pi userpw=raspberry user_is_admin=1 timeserver=0.pool.ntp.org timezone=Europe/Berlin”
with
“usbroot= # set to 1 to install to first USB disk”
Okay, the openHABian menu is something you will find after installing the system on an SD card.
If you do not have any prior experience with openHABian I would recommend to go with an sd card. There is no eminent reason to prefer an USB stick and you can still switch at any point if you really want to.
Regarding the option, after booting the system and connecting via SSH you will be able to execute sudo openhabian-config to see the menu mentioned in all previous update postings here (scroll up). There you will find the menu entry “Move root to USB”.
As for the installer-config.txt: Your quote tells me that you are on Windows and use the default Notepad. Microsoft Notepad does not support Linux line endings, that’s why everything is cluttered together from your point of view. That’s not your fault, MS doesn’t care that millions of users run into that problem at some point in their life. A very general suggestion: Install the way better Notepad++ and use it from here on out!
After you got a sane view on the content of the file, just add usbroot=1 at the end.
Thanks for quick reply…
i was able to install the image on 2gb SD and run it.. it did not finish installing the whole thing due to lack of space. I was able to boot my pi with the SD and moved the stuff on my USB… (i don’t have a big SD card). if i ran every single option on the openhabian-config. would that be the complete installation? or do i really need to start with 8bg micro sd?
thank jay
While the initial setup a lot of things are done. I can not vouch for a full openhabian setup on your system from where you are starting. If you really want to work with the 2GB card (imho not worth it) you can however continue as you did. The important steps can be executed through the first few menu entries. Start with Update and then continue. Good luck!
To not have to deal with this and in order to avoid possible problems, my personal approach would be to buy an SD card and be done with it.
16GB is what I would recommend to remarkably reduce wear / increase the chance that your data does not get corrupted.
Perhaps you can point me to the problem:
After about one day the ssh-connection isn’t working anymore. I was connected and then all commands like nano, ls, cp etc were replied by “command not found”. OpenHAB webinterfaces still work as expected. This was the second time now. As I don’t have a display at the raspberry I can’t tell what’s on the console :frowning:
EDIT: Now there is no ssh working anymore even after hard reboot by power cable. OpenHAB still starts expected :frowning:
Okay I’ll try to “point you to your problem” :slight_smile:
Your description is very awkward. Sounds to me like the problem is actually something different. If your system does not respond on an SSH connection, that’s normally the sign for a boot or network problem - in other words I never encountered problems with openssh itself. The fact that your openHAB is still responding disproves that…
Did you do any changes to the system recently? Change something for the pi user, change settings in sshd.conf, add firewall rules, change your surrounding infrastructure?
Is samba still working? Maybe this problem is the first sign of a corrupt sd card → random parts of your system are not functional anymore… Because of that possibility I would recommend to do a backup of your system before anything else. Your best way for that is to use Win32DiskImager (if you are on Windows).
If i was writing something wrong with “point to” sorry … i’m german and trying to do my best in english :slight_smile:
Didn’t change anything other than installing and migrating to your system 2 days ago :slight_smile:
Samba isn’t working anymore too. I’ll try a new sd-card today. Perhaps this will fix
First time user here. Just started freshly with the openHABian image you provided. Looks like almost everything worked but Java8 seems to be broken, right?
[openHABian] Installing Oracle Java 8 from Web Upd8 repository...
$ apt -y install oracle-java8-installer
Reading package lists... Done
Building dependency tree
oracle-java8-installer is already the newest version.
oracle-java8-installer set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up oracle-java8-installer (8u111+8u111arm-1~webupd8~0) ...
Using wget settings from /var/cache/oracle-jdk8-installer/wgetrc
Downloading Oracle Java 8...
--2016-11-10 13:41:53--  http://download.oracle.com/otn-pub/java/jdk/8u111-b14/jdk-8u111-linux-arm32-vfp-hflt.tar.gz
Resolving download.oracle.com (download.oracle.com)... 109.193.192.24, 109.193.192.19
Connecting to download.oracle.com (download.oracle.com)|109.193.192.24|:80... connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
Location: https://edelivery.oracle.com/otn-pub/java/jdk/8u111-b14/jdk-8u111-linux-arm32-vfp-hflt.tar.gz [following]
--2016-11-10 13:41:53--  https://edelivery.oracle.com/otn-pub/java/jdk/8u111-b14/jdk-8u111-linux-arm32-vfp-hflt.tar.gz
Resolving edelivery.oracle.com (edelivery.oracle.com)... 104.84.166.125, 2a02:26f0:136:290::2d3e, 2a02:26f0:136:2a0::2d3e
Connecting to edelivery.oracle.com (edelivery.oracle.com)|104.84.166.125|:443... connected.
Location: https://www.oracle.com/splash/edelivery/index.html [following]
--2016-11-10 13:41:53--  https://www.oracle.com/splash/edelivery/index.html
Resolving www.oracle.com (www.oracle.com)... 104.84.166.125, 2a02:26f0:136:2a0::2d3e, 2a02:26f0:136:290::2d3e
Connecting to www.oracle.com (www.oracle.com)|104.84.166.125|:443... connected.
HTTP request sent, awaiting response... 503 Service Unavailable
2016-11-10 13:41:53 ERROR 503: Service Unavailable.
download failed
Oracle JDK 8 is NOT installed.
dpkg: error processing package oracle-java8-installer (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of oracle-java8-set-default:
 oracle-java8-set-default depends on oracle-java8-installer; however:
  Package oracle-java8-installer is not configured yet.
dpkg: error processing package oracle-java8-set-default (--configure):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
Updating FireMotD available updates count ...
E: Sub-process /usr/bin/dpkg returned an error code (1)
FAILED
[13:42:23] pi@openHABianPi:~$ sudo openhabian-config
[openHABian] Checking for root privileges... OK
[openHABian] Updating myself... Already on 'master'
Your branch is up-to-date with 'origin/master'.
OK - No remote changes detected. You are up to date!
Bye Bye! :
I just selected the “Java 8” menu entry and everything went just fine. This looks like a short term temporary problem with either the server or your internet connection:
Easiest solution: Restart the installation
Maybe it went fine because you already have it installed. I am locate din Germany and if I point Firefox to
then I get this:
Sounds rather like the source has changed???
I’m in Germany as well. I’m confronted with the same error message but that’s not the problem.
We are using webupd8team’s Java 8 installer and this one takes care of whatever steps are needed.
Did you try to just reinstall Java through the menu?
Yes it simply doesn’t work. Download failed. 503 Moved temporarily:
Okay, never experienced anything similar. Possibly a problem with your locale/timezone settings or the DNS server used in your network. Just try flashing the image again, hopefully it will work a second time. if you by any chance did that before, do not change installer-config.txt.
