Will be able to try&report back tomorrow again. Thx in advance
The issue has been resolved by Oracle. It seems they fixed the links because I can download the JDK packages within Firefox, too. I started from scratch now again anyways and flashed the image onto my sdcard.
While trying to install Grafana / Influxdb from menu (opened with sudo):
Everyone,
please pay close attention to
Do not upgrade 2016-11-11
I want to emphasize, that apt upgrade is currently in fact breaking your openHAB system.
This is a short time error which will probably be solved soon.
Please stay clear from upgrading for a couple of days.
A fresh openHABian installation will also be unable to start openHAB.
In all cases this is only a temporary problem and you will be able to apt upgrade to the soon to be released working release.
Update - Fix available 2016-11-13
A solution is available.
- New installations are no problem anymore.
- Users who did an upgrade in between and are desperately waiting for an upgrade: Do it now!
sudo apt update && sudo apt -y upgrade - Users still on a previous build, you may also update now.
Everyone: There might still be smaller problems. If you are on a stable setup right now, it wouldnāt hurt to wait for a few more days for things to settleā¦
If you have all or most settings for your system in the configuration folder under /etc/openhab2/ itās also a good idea to do a clean reinstallation:
# Make backup
cp -arp /etc/openhab2 /home/pi/openhab2-conf-bak
# Remove and reinstall openHAB
sudo apt update
sudo apt purge openhab2-offline
sudo apt install openhab2-offline
# Restore Backup
#sudo rm -rf /etc/openhab2
sudo cp -arp /home/pi/openhab2-conf-bak /etc/openhab2
sudo systemctl restart openhab2.service
Additional openHABian step: You will see this error:
Iāve already implemented the needed changes in openHABian. Please execute sudo openhabian-config, then first select āUpdateā to retrieve these changes, then select āBasic Setupā to apply them to your system.
This also affects a clean install.
It results in a broken OH2 Installation
But this post might show a solution:
Yes, I have tested this on a openHABian install and it should do the trick for now, for clarity:
cp /usr/share/openhab2/runtime/karaf/etc/* /var/lib/openhab2/etc/
sudo sed -i -e 's|/usr/share/openhab2/runtime/karaf/bin/|/usr/share/openhab2/runtime/bin/|g' /etc/init.d/openhab2 /usr/lib/systemd/system/openhab2.service
sudo sed -i -e 's|OPENHAB_USERDATA="${OPENHAB_HOME}/userdata"|OPENHAB_USERDATA="/var/lib/openhab2"|g' /usr/share/openhab2/runtime/bin/oh2_dir_layout
sudo sed -i -e 's|OPENHAB_CONF="${OPENHAB_HOME}/conf"|OPENHAB_CONF="/etc/openhab2"|g' /usr/share/openhab2/runtime/bin/oh2_dir_layout
sudo sed -i -e 's|OPENHAB_LOGDIR="${OPENHAB_USERDATA}/logs"|OPENHAB_LOGDIR="/var/log/openhab2"|g' /usr/share/openhab2/runtime/bin/oh2_dir_layout
sudo systemctl daemon-reload
sudo service openhab2 start
Thank Benjy, running the above worked for me, however as per the comment from ThomDietrich, dont upgrade at the moment.
I needed to do a fresh install this morning and didnāt think to look at the site first.
saw this too late - and made an update today.
Now I canāt start the Karaf console anymore. I get:
ssh: connect to host localhost port 8101: Connection refused
Could this have the same cause?
After doing the changes mentioned by Benjy, it should work again. You might need to restart openHAB once or twice to kickstart the reinitialization.
Everyone, a fix for the problems from the last few days is available.
Iāve updated the posting a few comments up with all details: openHABian hassle-free openHAB Setup - #285
Firstly, thank you for your hard work in pulling this together, the manual setup process is very frustrating and this is very well thought through and executed.
I noticed the openhab.log and events.log are located in /var/log/openhab2/, so I added this folder to the samba config file by using nano to edit the file
sudo nano /etc/samba/smb.conf
and pasting the following at the end of the file
[openHAB-logs]
comment=openHAB2 logs
path=/var/log/openhab2/
browseable=Yes
writeable=no
only guest=no
public=no
create mask=0777
directory mask=0777
That way I can access the logs from my windows device without having to login to the RaPi using Putty.
Any possibility of enhancing the OpenHABian RaPi image to include this and expose the logs via samba?
Hey @BlinkyBill, thanks!
Thatās an excellent idea. I did not think of it yet as I am using the ssh console plus the alias command openhablog. Of course a solution without the need for SSH is desirable. Did you see this alternative idea: New optional component frontail Ā· Issue #28 Ā· openhab/openhabian Ā· GitHub
Would you prefer this solution over the solution in samba? Feel invited to comment on the issue!
Thanks again for your project @ThomDietrich,
The frustrating thing with using Putty t access the logs is itās not very friendly to filter, search, etc. Then there is the challenge to copy that info to the text tool of your choice ā¦
I use Notepad++ to view the logs, as it has great find, count etc. functionality. I also use it to edit sitemaps, rules, etc.
Iād prefer samba to access the logs directly, so I can easily search etc. If you go with the approach discussion in https://github.com/ThomDietrich/openhabian/issues/28 this would be great to view the log tail, but if someone wants more search horsepower, they will probably copy/paste to the tool of their choice (so make that easy to do).
Thanks again.
Oh Linux actually offers all of this in more than powerful ways. Notepad++ is nice and my daily driver on a windows PC as well but it can not compete. Anyhow I do of course understand that you are used to Notepad++ and want to look at logs there instead of learning to work with new tools.
If you are actually interested, check he tutorials here: https://linuxjourney.com - Tools you might find useful are tail (look), grep (filter & find), wc (count), vim (complex edits), piping (copy toā¦) and so on. Thatās definitely better than āprobably copy/paste to the tool of their choiceā.
Yet again openHABian is intended to address a wide user base and Yes, I have no problem sharing the openhab log folder. Iāll not have the time today. If you know how, please feel free to create a Pull Request, otherwise just a simple Issue. Thanks!
Thanks for your insight. I totally agree with your comments about the power of linux, but Iām confined in a windows world to access RaPis etc. Yes, I could dual-boot into ubuntu, but the rest of my non-openhab world is on windows, so I would be constantly toggling between the two.
What would you suggest the best log viewing solution would be for someone who only has a windows device to access their RaPi?
Thank you again.
Just successfully installed: openhabian-ua-netinst-20160915-git9e034e7.img (steady heartbeat green light). Connected to the openHAB2 portal (8080). Using the PAPER UI, installed the WeMo binding and searched for WeMo things. It found none, so I set up a couple manually (WeMo switch & WeMo lightswitch) using the appropriate UDNs (WeMo called them 'Device IDās). Both items show in the Control panel of the Paper UI, but do not work. Am I missing something? FYI, Iām new to Linux and RPi3.
openHABian is the system you used to get openHAB2 onto your RPi. Everything from here on out is unrelated. You might need to read up on the binding documentation,check your log or follow guides posted here in the forum. These are the things I would do and I can only help you this far without knowing what ādo not workā meansā¦
Hey @BlinkyBill, I thought about what you asked. My preferred solution is putty definitely. There is no more direkt, responsive and capable solution out there plus its what you get with every base Linux system. You can define a putty configuration to automatically start tracking your log files and by the use of grc you can color them to increase visibility. Let me know if you are interested in details.
Iām not against your samba solution, Iām however certain that itās the worse alternative⦠Still I see the appeal and as I said, please create a GitHub PullRequest/Issue.
Did you check the linked issue? Frontail might be for you.
Another solution I was thinking to implement for a longer time is logstash to store and filter log messages. However this is probably another level of interest
āDo not workā means when I click on a switch in the Control, it does not turn the WeMo device on or off.
Then you definitely need to check the log. Log in via Putty/SSH and type openhablog
